Real Analysis: Stolz–Cesàro Proof
5 replies · 4K views · last reply
Homework Helper
1. Let xn and yn be sequences in R with yn+1 > yn > 0 for all natural numbers n and that yn→∞.
(a) Let m be a natural number. Show that for n > m
[tex]\frac{x_n}{y_n} = \frac{x_m}{y_n} + \frac{1}{y_n} \sum_{k=m+1}^{n} (x_k - x_{k-1})[/tex]
(b) Deduce from (a) or otherwise that
[tex]|\frac{x_n}{y_n}| \leq |\frac{x_m}{y_n}| + \sup_{k>m} | \frac{ x_k - x_{k-1} }{ y_k - y_{k-1} } |[/tex]
(c) Assuming [tex]\frac{x_n-x_{n-1}}{y_n-y_{n-1}} \to 0[/tex], show [itex]x_n/y_n \to 0[/itex].
(d) Assuming [tex]\frac{x_n-x_{n-1}}{y_n-y_{n-1}} \to L[/tex], show [itex]x_n/y_n \to L[/itex].
N/A
(a) was fine.
(b) Would the question be more correct to use sup k>m+1 instead, since a k-1 index is in the inside expression?
I'm not sure if this was the right thing to do as the question probably intended the sum to remain unsimplified, but I replaced it with xn-xm.
Using the triangle inequality and that y is strictly increasing so that yn-ym < yn, we get
[tex]| \frac{x_n}{y_n} | \leq | \frac{x_m}{y_n} | + | \frac{x_n-x_m}{y_n-y_m} |[/tex]
Then I'm not really sure what I can validly do after that.
(c) If (b) is assumed, then if we take the limit of both sides, it reduces to the statement that [tex]| \frac{x_n}{y_n} | - | \frac{x_m}{y_n} | \leq 0[/tex] holds true for large n.
I don't think that's the right direction to go, certainly since it seems to imply x is decreasing when that was never given. Don't know what to do.
(d) No idea, but if I had (c) this one would probably be similar.
[tex]\left| \frac{x_n}{y_n} \right| \leq | \frac{x_m}{y_n} | + | \frac{x_n-x_m}{y_n-y_m} |[/tex]
you probably already know this, but the 2nd equation doesn't imply the first because sup(all that stuff) could be smaller than [tex]\left| \frac{x_n-x_m}{y_n-y_m} \right|[/tex]
The most obvious path is to prove that
[tex]\sup_{k>m}\left|y_n\frac{\Delta x_k}{\Delta y_k} \right| \geq \left| \sum_{k=m+1}^{n} \Delta x_k\right|[/tex]
and then apply triangle inequality.
First, restate it as an existence question, remove the sup and ask: does there exist a [tex]k[/tex] that makes the inequality true?
[STRIKE]An idea:
It reduces to finding [tex]m+1\leq k \leq n[/tex] such that
[tex]\frac{y_n}{\Delta y_k}\geq n-m[/tex] (1)
and
[tex]\Delta x_k \geq \frac{|x_n-x_m|}{n-m}[/tex] (2)
It is easy to to find a [tex]k[/tex] that satisfies each condition individually, but I can't see how to find one that satisfies both simultaneously =(
[/STRIKE]
edit: the above approach won't work, I found a counterexample to it.
For c),
to find N such that [tex]\frac{x_n}{y_n}<\varepsilon[/tex] for n>N,
first find an m such that [tex]\frac{ \Delta x_k }{\Delta y_k } < \frac \varepsilon 2[/tex] for k>m, then use part b) and finish it off.
My mind started thinking clearly and I figured these out finally. If anyone's interested in the solutions send me a PM and I'll post them here.
boboYO, I didn't see the edit until just now, my final solution for (c) didn't make any use of (b) and was quite long =[ Could you tell me how we could have used (b) to finish it off. When I see it I bet I'll kick myself.
see what you think of this
let [itex]\Delta x_j = x_j-x_{j-1}[/itex]
then, let k>m be the the supremum index, then
[tex]| \frac{\Delta x_k }{ \Delta y_k }| \geq | \frac{\Delta x_j }{ \Delta y_j }|, \forall j>m[/tex]
rearranging, knowing that [itex]\Delta y_j > 0[/itex], then summing from m+1 upto n:
[tex]| \frac{\Delta x_k }{ \Delta y_k }| \sum \Delta y_j \geq \sum |\Delta x_j |\geq |\sum \Delta x_j|[/tex]
so
[tex]\sup_{k>m}| \frac{\Delta x_k }{ \Delta y_k }| \geq |\frac{x_n-x_m}{y_n-y_m}|\geq |\frac{x_n-x_m}{y_n}| \geq |\frac{x_n}{y_n}| - |\frac{x_m}{y_n}|[/tex]
then for c) choose M such that
[tex]\frac{x_m-x_{m-1}}{y_m-y_{m-1}} < \epsilon, \forall m>M[/tex]
then for n,m>M
[tex]|\frac{x_n}{y_n}| \leq |\frac{x_m}{y_n}| + \epsilon[/tex]
[itex]x_m[/itex] is just a number, and as [itex]y_n[/itex] is unbounded as n increases, we should be able to choose N>M so that for all n>N
[tex]|\frac{x_m}{y_n}|\leq \epsilon[/tex]
then for n>N>M
[tex]|\frac{x_n}{y_n}| \leq 2\epsilon[/tex]
which should be pretty close...
this part threw me for a bit above
[tex]\sup_{k>m}| \frac{\Delta x_k }{ \Delta y_k }| \geq |\frac{x_n-x_m}{y_n-y_m}|[/tex]
but I'm thinking maybe the continuous analogue is something like the mean value theorem, except that the maximum gradient must be >= the average
not 100% there is no holes...
