Which Formula Should I Use for Calculating Power in an AC Circuit?
The discussion centers on the appropriate formula for calculating power in an AC circuit. Participants confirm that the correct formula is P = Vrms.Irms.cosφ, which calculates real power in watts (W). The formula P = V.I is identified as representing instantaneous power in volt-amperes (VA). This distinction is crucial for accurately determining power consumption in AC systems.
  • Understanding of AC circuit principles
  • Familiarity with root mean square (RMS) values
  • Knowledge of power factor (cosφ)
  • Basic electrical engineering concepts
  • Research the implications of power factor on energy efficiency
  • Learn about the differences between real power, reactive power, and apparent power
  • Explore the use of power analyzers for measuring AC power
  • Study the effects of harmonics on power calculations in AC circuits
Electrical engineers, technicians working with AC circuits, and students studying electrical power systems will benefit from this discussion.
hquang001
TL;DR
When the teacher ask me to find real power of an AC Circuit, which formula should i use ?
Should i use P = V.I or P = Vrms.Irms.cosφ ?
P = Vrms.Irms.cosφ
Real or average or active power = Vrms.Irms.cosφ (W)
Instantaneous power = V.I (VA)
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 16 ·
