Really a virtual particle sea?
The discussion revolves around the concept of virtual particles in quantum field theory (QFT) and their relationship to the vacuum state, particularly in the context of harmonic oscillators. Participants explore the implications of the ground state of the harmonic oscillator, the nature of vacuum fluctuations, and the definitions and interpretations of virtual particles.
  • Some participants argue that the ground state of the harmonic oscillator is orthogonal to all excitation states, suggesting that the vacuum should be empty of particles.
  • Others propose that virtual particles exist for a very short time, as dictated by the Heisenberg uncertainty principle, and thus do not qualify as traditional excitation states.
  • There is a discussion about the implications of the time-energy uncertainty principle and its relation to the behavior of virtual particles.
  • Some participants assert that all particles are excitation states of fields, while others challenge the comparison between virtual particles and excitation states.
  • There is a contention regarding the definition and existence of virtual particles in QFT, with some stating that the concept is misleading and not well-defined by quantum theory.
  • Questions arise about whether the notion of virtual particles applies universally in QFT or is limited to perturbative methods.
Participants express differing views on the nature and existence of virtual particles, with no consensus reached on their definitions or implications. The discussion remains unresolved regarding the relationship between virtual particles and excitation states.
Limitations include varying interpretations of quantum field theory and the ambiguity surrounding the concept of virtual particles, particularly in non-perturbative contexts.
jostpuur
I've often heard the argument that vacuum is full of virtual particle pairs that get created and annihilated, but in fact the ground state of the harmonic oscillator is orthogonal to all excitation states, so shouldn't the vacuum, when in ground state, actually be empty of all particles? What is this virtual particle sea stuff really?
The point is that the virtual particles do not exist long enough to be classified as "excitation states" ! They are a bit special in the sense that their lifetime is very limited (determined by the Heisenberg uncertainty principle).
It was Dirac who came up with the idea that the vacuum was filled with virtual positron and electron pairs (the reason that they were pairs has to do with conservation laws like that of electrical charge). You can break up such a pair and make the particles real when you have enough energy coming from some interaction between two charged particles that were placed inside the vaccuum.
I understand that when an oscillator is in ground state, there is a nonzero probability to observe it arbitrarily far from the origo. For example, in vacuum there is a nonzero probability for fields to have arbitrarily large values. I've thought that this is quantum fluctuation.
However, I don't understand how an oscillator, when in ground state, could have a nonzero probability to be on an excitation state! Orthogonal is orthogonal: Zero overlapping. :confused:
I just remembered that the time energy uncertainty principle was the particularly mysterious one. What ever it means, I would prefer sticking with the Schrödinger's equation, which at least is not wrong. According to SE, an energy eigenstate remains as an eigenstate.
look up 'dielectric'.
Again, the virtual particles popping up cannot be compared to the excitation states you are referring to. The vacuum fluctuations only exist for a short amount of time and their energy is uncertain. While they become real for this short period, total energy conservation is not respected ! This is allowed because of the Heisenberg uncertainty principle. In between final and initial states of a process, energy is uncertain during a certain amount of time, so...
What do you mean ? That it is incorrect ?
marlon
All particles are excitation states of fields.
So excitation states exist only for short amount of time?
Not really. Statement, whose meaning is not clear, cannot be incorrect yet.
When a system is on an energy eigenstate [itex]|\psi_n\rangle[/itex] corresponding to an energy [itex]E_n[/itex], then according to the SE the time evolution is trivial phase rotation
[tex] |\psi(t)\rangle = e^{-i(t-t_0)E_n/\hbar}|\psi_n\rangle.[/tex]
I have never seen Heisenberg uncertainty principle
[tex] \Delta E\;\Delta t \geq \hbar[/tex]
used in arguing that there would be some fluctuation in the time evolution of a system. It is always the phase rotation only.
Try a Google on Leon Van Hove and correlation, or "resonance". It will help you get to the next level.
Regards,
Reilly Atkinson
You did not get the point. I meant to say that virtual particles do not follow the rules of total energy conservation. Your excitation states DO !
Vacuum fluctuations do YES
What is not clear about it ?
marlon
You are right. The vacuum does not contain any particles. The concept of a "virtual particle" or a "virtual state" is not even defined by general principles of quantum theory. Thus, it is misleading to think in terms of "virtual" anything.
Nevertheless, in the vacuum the value of the field, and consequently the value of energy, is uncertain. Consequently, the average energy is larger than zero.
See also
http://xxx.lanl.gov/abs/quant-ph/0609163 [Found. Phys. 37 (2007) 1563]
especially Sec. 9.3.
In QFT virtual particles do "exist" in the sense that they arise due to vibrations of quantum fields. To such field one can assign particle like concepts such as momentum ! That how basic QFT works : assign particle like concepts to field vibrations
marlon
Hello,
is what you wrote true in QFT in general or only in pertubative QFT ?
I have some idea of what is a "virtual" particle in QFT. But, when it is no more pertubative, I do not understand.
Barmecides said:
Hello,
You are right, a notion of a "virtual particle" makes sense only as an "interpretation" of some mathematical terms in the perturbative method of calculation.
Barmecides said:
Hello,
If you take into account how the notion of particle arises in QFT, i don't quite get your point here. Could you elaborate ?
marlon
marlon, do you agree that particles are excitations, corresponding to some Fourier modes, of fields?
Here you explain so
but here you explain the opposite
This gets complicated.
So when virtual particles exist for short time, then the excitation states exist only for a short time? So the virtual particles are excitation states, after all?
Are all particles excitation states, or are they not?
marlon
Sorry marlon,
this was a mistake in writing. I was only meaning that "I have some idea of what is a "virtual" particle in perturbative QFT" and only in perturbative QFT because I think this is an artefact of perturbative approximation of quantum mecanics.
But, if you can proove the contrary, I will be eager for an explanation as my current understanding might be wrong.
Here you explain so
Indeed particles arise due to fluctuations of quantum fields !
Indeed, virtual particles exist for a short amount of time. Do you agree with that ?
If you do agree with that, i don't see what the problem is. Virtual particles are not the same as the excitation states the OP referred to because such states are on mass shell, virtual particles are not. They are not, BY DEFINITION ! Such particles don't even respect total energy conservation, so why would the "ordinary" rules apply to them ?
marlon
Not fully. You are using the term "fluctuations" very vaguely. I though the fluctuations would be associated for example with the zero-point energy, and other uncertainty relation related things. The particles are excitation states of the infinite dimensional oscillator, as we can think a field to be. The excitation states are a different thing as fluctuations. Right now I'm not convinced that you know what you are talking about at all, and I'll say my point as clearly as possibly:
Suppose a one dimensional harmonic oscillator is in the ground state,
[tex] \Psi(x) = e^{-x^2/2}.[/tex]
Now, the following two claims are true:
(1) The x-variable has non-zero probabilities for having arbitrarily large values.
(2) The oscillator has zero amplitudes for being on higher excitation states
[tex] \Psi(x)=H_n(x) e^{-x^2/2},\quad n\geq 1[/tex]
With the quantum field case these two facts become the following:
(1) The field has non-zero probabilities for having arbitrarily large values, and this is fluctuation of the quantum field.
(2) The field has zero amplitudes for being on higher excitation states, and hence zero probabilities for particles to exist.
I think you are confusing the zero-point energy fluctuation with the excitation states.
Excitations of fields are on-shell particles. If virtual particles are not on-shell, then they are not excitations of fields. If they are not excitations of fields, then what are they?
Regards,
Reilly Atkinson
Googling didn't help much. All I got was some very technical stuff, seemingly directed for experts of some field. Nothing pedagogical.
  • · Replies 31 ·
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 46 ·
