Receiving AM Radio Signals from Philadelphia
To receive the 610 AM radio station from Philadelphia while located in State College, PA, a user needs a high-quality AM radio receiver that supports an external antenna. A dipole antenna, approximately 767 feet in length, is recommended for optimal reception, ideally mounted at least half a wavelength above the ground. Users should also consider directional placement of the antenna towards Philadelphia for improved signal strength, particularly during nighttime when AM signals propagate better. Additional enhancements like adding director and reflector elements can further boost gain.
  • Understanding of AM radio signal propagation
  • Familiarity with antenna design, specifically dipole antennas
  • Knowledge of radio frequency calculations, including wavelength and frequency
  • Experience with radio receiver specifications and features
  • Research the construction and installation of dipole antennas for AM reception
  • Learn about the effects of terrain on radio signal propagation
  • Explore advanced antenna designs, such as log-periodic arrays for increased gain
  • Investigate radio receivers specifically designed for long-distance AM listening
Amateur radio enthusiasts, hobbyists interested in long-distance AM reception, and anyone looking to enhance their radio listening experience in mountainous regions.
zeus00
AM radio -- please help!
Hello,
Here is some background info. I don't know if it is all necessary to find a solution but here it is anyway:
I am currently living in State College, PA. I would like to be able to listen to an AM radio station broadcasting from Philadelphia, PA. Philadelphia is about 200 miles from State College. State College is located in the mountains and is approximately 1200 feet above sea level. Philadelphia is at sea level.
The radio station I am interested in receiving is 610 AM.
What would I need to do to receive this radio station?
Do AM waves travel through mountains or such obstacles that may be in the way? Would I need to buy an AM radio receiver? If so, what should I look for (any suggestions on what radio to buy)?
I cannot think of any other questions...I'd really appreciate any help that can be provided! Thanks so much!
Computer science news on Phys.org
Does the Radio station not stream over the internet?
AM radio not available online
No, unfortunately they do not stream online...any suggestions?
Thanks!
As opposed to what? Stealing or building one?
You can buy some higher end receivers geared towards short wave listening but they have good performance on AM too. Just make sure you get one that requires an outside antenna. Anything else is going to have no better reception than the average radio. Now for the outside antenna. You need a fairly long wire antenna to receive 610 KHz. Build a 'dipole' antenna. It is a half wave electrical length. This is about 767 feet long for 610. It is split in the center by an insulator. The feedline (antenna cable) connects to the center. Ideally any antenna should be at least a half wave length above the ground. I don't see this happening with you. The best way to support an antenna like this is from the center and ends.
Ummm...that's very interesting.
Averagesupernova, assuming that was a serious answer (was it?), what's the reason behind the half-wavelength antenna size you suggested.
Also, how did you arrive at 767 feet? I thought you might be using c=f\lambda but that gives me
\frac{\lambda}{2} = \frac{c}{2f} = \frac{2.998e8 * 3.281}{2*610,000} = 806 \text{ft.}
so should I be calculating it some other way?
Speed of light in metal vs speed of light in a vacuum
Electromagnetic waves propagate slower through metal than they do through the air or through vacuum. If his answer is 767, and your answer is 806, then the conversion factor is 95.16 percent (IOW, he may have been assuming light travels ~95% as fast in metal as it does in a vacuum).
Hmmmm. Sorry I hadn't checked back in on this sooner. Yes, it IS a serious answer. How I arrived at the length of 767 is from a somewhat standard formula used for a half wave dipole. It is: 468/frequency in Mhz = length in feet for a half wave dipole. The formula is not perfect. Surrounding objects can affect the tuning of the antenna. For what you want to use it for it is close enough. But, if you want to get REALLY technical you need to get some test equipment and adjust the length of the antenna based on measurements with the test equipment.
You also asked what the reason for the half wave type antenna was. ANY decent antenna needs to be resonant. Some antennas are not half wave physically but they still form a resonant circuit. The reason I suggested what I did was because it is a simple design. It is indeed large, but simple with few components.
Now I know what your next question is. Can I get by with a shortened antenna? The answer is yes, but at reduced performance. What you can do is wind coils and insert them midway down each shortened leg of the dipole. This adds inductance so to counter it and keep the resonant frequency where you want it, the length is shortened.
If you need to know any more I would suggest reading a book. Start with amateur radio.
Averagesupernova said:
...somewhat standard formula used for a half wave dipole. It is: 468/frequency in Mhz = length in feet for a half wave dipole...
By your discussion it sounds like you may have done some hamming. Nice job recommending a dipole for 610KHz. I agree, he may hear a better signal if this antenna was mounted at least 1/2 \lambda above the ground. As you point out, this is impractical. The best thing would be to string it as high as he can.
An additional point worth mentioning; to improve gain (signal strength), if he knows the compass direction to the station in Philly (approximately southeast from State College), he should mount the dipole perpendicular to that direction. Since zeus00 does mention the station is 200 miles away, the best time to hear it, would be after dark.
If he is ready to try something with more gain, perhaps a log-periodic array pointed E-SE, is in order. :biggrin:
Back on a serious note, he could improve his dipole by adding director and reflector elements. Even adding a single reflector (0.1 \lambda behind and parallel to the dipole), can improve gain up to 6dB.
glossary: \lambda = wavelength
I suggest a phased array ferrite antenna for high gain with a high Q LC
front end tuned to the station you want. This is experimental of course and
would require a large plot of land to space the individual antennas, but hey-
Why not?
Granted, a dipole with an additional element(s) is starting to push the limit of practicality. A phased array for 610KHz (vertical antenna farm) would be over the top. I don't see it as feasible for a student to build, to receive his/her favorite AM broadcast station. (Each vertical element would be about 384 ft high, require suitable guying, using a minimum of two elements at a spacing of 1/2\lambda or 767ft. In other words it would like the photo on this page.) :rolleyes:
No, you misunderstood (though it's probably over the top anyway.)
I'm suggesting small ferrite loop antennas like the ones in any common
AM handheld receiever, but yes spaced as you depict. This is NOT outside the
realm of expertise of a dedicated amateur radio operator.
  • · Replies 46 ·
  • · Replies 20 ·
  • · Replies 39 ·
11K
