Recommended books, articles and links on transistors
9 replies · 4K views · last reply
Voq
If you have any material (books, links, articles) on transistors i would appreciate that. I am looking for a way to get more general knowledge on subject. Thank you.
there are 100's of tutorials text and videos online
google how does a transistor work tutorials
Voq - if you want to gain more and deeper knowledge on "how a transistoir works", I think the following hint is very important:
Comparing different knowledge sources (books, articles, internet contributions) you will - surprisingly - notice that two different explanations still exist:
1.) BJT as a current-controlled device: The collector current Ic is a result of (and will be controlled by) the base current Ib
2.) BJT as a voltage-controlled device: The collector current Ic is a result of (and will be controlled by) the base-emitter voltage Vbe.
Apparently, only one answer (physical working principle) can be correct. In the past, this subject was already intensively discussed - also in this forum.
An answer to this question may be of less inportance as long as you are using only formulas and design strategies readily available for building transistor amplifiers.
However, if you want to know what`s really going on and if you want to discover new application areas it is of great importance to know if answer 1) or answer 2) gives the correct description.
In this context, I recommend all BJT-related contributions from the universities of Berkeley and Stanford as well as from the MIT.
(Don`t rely on some obscure and simplified online tutorials) .
For example, see here: http://web.eng.ucsd.edu/ece/courses/ECE65/Spring2014/FN-Notes/main/BJT.pdf
I was diverted by some external forces. But still i will check links in hope to get some order of knowledge. Thanks. In the meantime i found nice picture. And found out there is 109 of them in laptop.
  • Close-up of a square surface-mount integrated circuit chip with many fine metal pins along all four edges, soldered onto a green printed circuit board.
A couple old ones that really cover the basics are both the GE and the RCA Transistor Manual. Being part of the early literature, they avoided much of the deep theoretical and leaned more toward the practical use and the "why." They are circa 1964 and 1967 respectively so may be hard to find, but IMHO well worth some effort.
Front and spine cover of the General Electric Transistor Manual, light-weight edition, with a blue and orange spiral of printed circuit schematics and the words Circuits, Applications, Characteristics, Theory.
Cover of the RCA Transistor Manual, Technical Series SC-13, with red and black lettering and line symbols for bipolar transistors, MOS field-effect transistors, thyristors (SCRs and triacs), and silicon rectifiers and other diodes; suggested price $2.00; Radio Corporation of America, Electronic Components and Devices, Harrison, N.J.
Cheers,
Tom
Edit:
I just Googled the titles and found hits for scans of both of them.
http://www.introni.it/pdf/GE - Transistor Manual 1964.pdf
For hardcopy try Google books.
and https://books.google.com/books/about/RCA_transistor_manual.html?id=o05rAAAAMAAJ
end Edit
  • Front and spine cover of the General Electric Transistor Manual, light-weight edition, with a blue and orange spiral of printed circuit schematics and the words Circuits, Applications, Characteristics, Theory.
  • Cover of the RCA Transistor Manual, Technical Series SC-13, with red and black lettering and line symbols for bipolar transistors, MOS field-effect transistors, thyristors (SCRs and triacs), and silicon rectifiers and other diodes; suggested price $2.00; Radio Corporation of America, Electronic Components and Devices, Harrison, N.J.
They are both correct? Current is dependent on a voltage, so there must always be a voltage for there to be a current.
Front cover of the Dover book Basic Theory and Application of Transistors, with two orange panels showing crystal lattice diagrams labelled P-TYPE GERMANIUM and N-TYPE GERMANIUM with dots and circles for charge carriers.
Written for the incoming army recruit with only a HS education It covers the basics of junction transistors including physics,equivalent circuits, parameters , bias stabilization characteristic curves and more with applications to analog circuits related to communication with a bit of pulse/logic applications included. Available on line and downloadable at https://archive.org/details/BasicTheoryApplicationsOfTransistors
  • Front cover of the Dover book Basic Theory and Application of Transistors, with two orange panels showing crystal lattice diagrams labelled P-TYPE GERMANIUM and N-TYPE GERMANIUM with dots and circles for charge carriers.
Gleem - I was involved in teaching electronics (in Germany) for more than 25 years.
However, I must admit that I never have heard about the book as recommended by you.
I had a short look inside the book - and I must say: Excellent.!
Thanks for giving the link - I only can recommend this (old) transistor manual.
Thank you very much for materials. I appreciate it. I still need them so I am checking them all.
