Uncovering the Truth: Recording Lightspeed with a Trillion FPS Camera
  • Context: Undergrad
  • Thread starter Thread starter Mohd Abdullah
    Lightspeed
The discussion revolves around the recording of light using a trillion frames per second camera, questioning the implications of such a recording, the nature of light pulses, and whether the speed of light was effectively measured or merely observed. The scope includes conceptual understanding, technical details of the recording process, and the interpretation of the results presented in a video.
  • Some participants question whether light exists before it is recorded, noting that light is generated as a pulse from a laser.
  • There is a discussion about whether the recording actually measures the speed of light or simply captures the motion of a light pulse.
  • Some argue that the video demonstrates the ability to visualize light pulse movement rather than measure its speed, suggesting that measuring speed can be done more accurately through other methods.
  • Participants clarify that the recording involves multiple light pulses rather than a single photon, emphasizing the nature of the light being captured.
  • Concerns are raised about the methodology used in the recording, including whether the technique can accurately represent the speed of light.
  • Some participants highlight that the video merges multiple pulses and does not represent a single pulse of light, questioning the implications of this for measuring speed.
  • There is a mention of existing literature on high-speed photography and its applications in various fields, suggesting a broader context for the discussion.
  • Some participants express curiosity about the existence of phenomena faster than light, with responses clarifying that nothing moves faster than light in a vacuum.
Participants exhibit a mix of agreement and disagreement regarding the interpretation of the recording. While some agree that the recording does not measure the speed of light, others emphasize the significance of the visual representation of light pulse movement. The discussion remains unresolved on several points, particularly regarding the implications of capturing multiple pulses versus a single pulse.
Limitations include the dependence on definitions of speed measurement, the nature of light pulses, and the methodology used in the recording process. The discussion does not resolve these complexities.
Readers interested in high-speed imaging, the physics of light, and the methodologies of measuring light phenomena may find this discussion relevant.
Mohd Abdullah
Had anyone already watched this?
He said they successfully recorded the speed of light using a trillion fps camera that they had created. But isn't light already there even before someone started to record it? Not to mention that light is not actually accelerating.
Thoughts?
Science news on Phys.org
Hi,
No. The light is generated in the laser as a light pulse.
No one claims that it is accelerating.
BvU said:
Hi,
I see. So, is it really they successfully recorded the speed of light?
You can say that, yes. They managed to reconstruct light pulse movement through a scene.
But was this what they wanted to do? All they stated in the video was to detect the motion the light pulse. They didn't say they wanted to actually measure the speed of light (which can be done in more accurate manner via other means).
BTW, in case anyone mistook this as actually observing the motion of ONE photon, this is not the case. Note the word "photons" being used. The laser is sending a light PULSE, not a single photon at a time.
Zz.
Zz.
So if I understand you, they don't actually recorded the speed of light. Right?
What do you mean that it can be done in more accurate manner via other means?
Look at the video again. That wasn't the main purpose of the demo. If you really want to know what they were studying, you need to find the relevant papers that this group has published using this setup.
This is not the technique used to determine the book or reference value of "c" in vacuum that we all have been using. The CODATA standard describes the methodology on how c was determined.
Zz.
There weren't measuring the speed of light. They were recording a scene at a high enough rate to discern the motion of a light pulse passing through the scene. They are saying the have slowed the action down so that you can witness things that happen at the speed of light. This is much much harder than merely measuring the speed of light. People have long used similar techniques to witness fast dynamics in chemical reactions for example (look up pump-probe experiments) but you have to be impressed that they can image like this.
It's also clear that they use a lot of pulses to make the video. They explained how they use a mirror to scan the scene in one dimension but I wonder if they also use multiple pulses and a time delay to scan in the other dimension? So although they can apparently slow down a pulse its not the same pulse in each frame?
There are published papers regarding those experiments but it seems someone need to pay for it to read it. One of them is an article entitled 'Sequentially timed all-optical mapping photography' by K. Nakagawa and his other members that was published in 10 August 2014. It can be bought online at nature.com. The review is something like "High-speed photography is a powerful tool for studying fast dynamics in photochemistry, spintronics, phononics, fluidics, and plasma physics. Currently, the pump–probe method is the gold standard for time-resolved imaging, but it requires repetitive measurements for image construction and therefore falls short in probing non-repetitive or difficult-to-reproduce events. Here, we present a motion-picture camera that performs single-shot burst image acquisition without the need for repetitive measurements, yet with equally short frame intervals (4.4 trillion frames per second) and high pixel resolution (450 × 450 pixels). The principle of this method—‘motion picture femtophotography’—is all-optical mapping of the target's time-varying spatial profile onto a burst stream of sequentially timed photographs with spatial and temporal dispersion. To show the camera's broad utility we use it to capture plasma dynamics and lattice vibrational waves, both of which were previously difficult to observe with conventional methods in a single shot and in real time."
Thoughts?
Doc Al said:
You might want to check out this MIT news article from about 5 years ago: Trillion-frame-per-second video
Ha! Trillion frames per second! Think how many hard drives it would take to video your grandma's 80th birthday party with that!
Are there something faster than light in the universe that even no matter how advanced the technology, no matter how fast the camera is, we will never be able to record a single frame of it?
No, there is nothing that moves faster than light.
...in a vacuum.
Light in other media can go a lot slower or even stopped..
The video is not even the record of a single pulse of light, but many pulses, merged with a computer afterwards (~1:30 in the video).
Exactly. (That was my point in posting the link to the MIT news site earlier. It discusses such 'details'.)
CWatters said:
...in a vacuum.
But can we stop light in a vacuum?
What is the difference if they record a single pulse of light compare to many pulses of light? Does it mean they didn't really record something moving at the speed of light?
They are taking a snapshot of many different pulses. How do you think this is a measurement of the speed of each light pulse?
I take many photos of the vehicles moving in front of my house at various times. Does that mean that I had recorded the speed of each of these vehicles?
Zz.
Every video camera records light, which moves at the speed of light. And if you move far away enough, the propagation of a light pulse across the field of view can look arbitrarily slow, even on a real time video.
No.
Zz.
I will say again that the point here was not to measure the speed of light. However in reply to Zz ...
A snapshot certainly doesn't show EACH cars speed. However if you can believe all of the cars are going the exact same speed, and you trigger a timer when they cross a particular point in the road and you take each of your photographs at precise delay intervals after the trigger then yes the photographs are a precise measure of the shared constant speed of the cars. Constant speed and fixed motion are not required. As long as the cars each perform the exact same movements as they pass, a montage of your photographs ordered by their respective time delays is a precise record of the motion of one and all of them.
The only trick is in believing that they will all do the exact same thing, and with light pulses that is a very good assumption. So even though this is composited from many pulses it is nevertheless a precise record of what each and every pulse did in real time.
Believe me, I know it CAN be done if this is the goal. I measure the speed of electron bunch trains, so this is something I know how to do.
But I am replying to the OP in this context based on what has already been done in this report, not what they can or what is possible to be done. Somehow the OP seems to think that simply having the various snapshots of the different pulses can easily be translated to measuring the speed of these pulses.
Zz.
  • · Replies 67 ·
  • · Replies 45 ·
  • · Replies 35 ·
  • · Replies 40 ·
  • · Replies 17 ·
  • · Replies 16 ·
