REDOX titration of bleach help
In summary: The endpoint occurs when there is no more purple-blue particles visible. In summary, the titration endpoint is when the solution becomes colorless, regardless of the amount of excess titrant added.
Rachel9287
I am performing a REDOX titration of a diluted bleach sample in my analytical chemistry class. I am using sodium thiosulfate as the titrant to determine the amount of sodium hypochlorite ion in solution. I am using a starch indicator, which is supposed to turn from blue to colorless at the endpoint. The solution itself turns colorless at a point, but excess blue particles, of what i am assuming are starch, still float around. Does anybody know if the endpoint of the titration is when the solution itself becomes colorless, or if by adding excess titrant the endpoint is when the particles in the colorless solution become colorless?
Chemistry news on Phys.org
Your description would be more thorough if you stated the use of excess KI to allow for the formation of triiodide. You also titrate in the presence of acid? to help the titration reaction? The blue color occurs by the interaction or reaction between triiodide and starch. When enough thiosulfate has been added to reduce the iodine (thereby eliminating the triiodide), the blue color disappears.
The starch used as an indicator makes seeing the triiodide easier.
iodide from excess KI is a reducing agent, it is oxidised by the hypochlorite ion to iodine. Iodine is an oxidsing agent. The iodine liberated will then oxidise the thiosulphate.
Iodine is normally brown when in solution. actually it reacts with iodide from the excess KI to form tri iodide ion, and in this form, the iodine becomes soluble.
the tri iodide gives a blue black colour with starch. when the blue black colour disappears, this means that all the tri iodide has reacte with the thiosulphate.
the particles you see are iodine which has not dissolved. the iodine has a tendency to reappear during such titrations. you should shake the solution well, or maybe you should try adding another drop of thiosulphate, and then shake again.
the end point is when the solution becomes colourless.
The amount of starch in the solution should be small enough that it doesn't form chunks. How much starch did you add?
I made the starch indicator with 2 grams of soluble starch in 500 mL of heated water, I used about 1-2 mL for the titration. The analyte consisted of a 10 mL aliquot of dilute bleach (10 mL pure bleach in 250 mL water), 1 mL 3 M H2SO4, and 2 grams of excess KI. The titration required about 67 mL of .01 M Sodium Thiosulfate to reach the "endpoint" where the solution turns from dark greenish-blue to clear, with small bits of dark purple-blue particles floating around. When about 10 mL more titrant is added, the blue particles become white.
1. What is the purpose of a REDOX titration when testing bleach?
The purpose of a REDOX (reduction-oxidation) titration when testing bleach is to determine the concentration of the active ingredient in the bleach, which is typically sodium hypochlorite (NaClO). This is important for quality control and ensuring the bleach is strong enough for its intended use.
2. How does a REDOX titration work?
In a REDOX titration, a known amount of a reducing agent, such as the bleach, is added to a solution containing a known amount of an oxidizing agent, such as potassium permanganate (KMnO4). The reducing agent will react with the oxidizing agent until all of it is consumed. The endpoint is determined by a color change, indicating that all of the reducing agent has been used up and the reaction is complete.
3. What equipment is needed for a REDOX titration of bleach?
The equipment needed for a REDOX titration of bleach includes a burette, a standard solution of the oxidizing agent (such as KMnO4), a conical flask, a pipette, and a color indicator (such as starch). It is also important to have a clean and calibrated glassware to ensure accurate results.
4. What is the formula for calculating the concentration of the active ingredient in bleach?
The formula for calculating the concentration of the active ingredient in bleach is: CNaClO = (Vox x Nox x Mox) / Vred, where CNaClO is the concentration of sodium hypochlorite, Vox is the volume of the oxidizing agent used, Nox is the normality of the oxidizing agent, Mox is the molarity of the oxidizing agent, and Vred is the volume of the reducing agent (bleach) used.
5. What are some potential sources of error in a REDOX titration of bleach?
Some potential sources of error in a REDOX titration of bleach include inaccurate measurement of volumes, contamination of solutions, and incorrect calibration of equipment. It is also important to ensure that the bleach is fresh and has not been exposed to air, as this can affect its concentration. To minimize errors, it is important to carefully follow the steps of the titration and conduct multiple trials for more accurate results.
13K
  • Biology and Chemistry Homework Help
  • Chemistry
12K
