Redshift FAQ article development
142 replies · 22K views · last reply
Pallen: I just read your posts around #19 - #30 for the first time.
Those really clarify nicely some cornerstone concepts
"...Doppler appropriately defined for GR is the one universal way to compute and understand redshift...In the cases of static observers, we call the Doppler for these special observers gravitational red shift; in the case of comoving observers we call it cosmological red shift... a parallel transported 4-velocity will never exceed c in any local frame..."
Nicely done...!
Well don't get too carried away! [LOL] because now I am back to fretting about comoving observers: that in widely separated cosmological expansion observations, redshift due to the Doppler shift and that due to expansion is arbitrary...coordinate based... We end up with superluminal expansion...etc.. why if we can avoid it?? ...
ah well, I'll save that for another day.
Nicely done...!
lol what really bugs me is in replies to the question " Is expansion really faster than the speed of light and how does this not violate GR"
the common answer on the forum is " yes at the edge of the observable universe its 3c " then they briefly explain how it doesn't violate GR with its "due to expansion and expansion does not need to follow GR"
the problem with that answer is its misleading and doesn't correctly answer the question.
Jonathan Scott said:
The relative gravitational time dilation in a static situation is already there in the metric, and is completely independent of the path by which signals travel (provided that the path is also static), so this seems a much simpler way to describe it.
A metric component g00 has no coordinate independent meaning, in general. To say it has the meaning commonly attributed to it in e.g. SC geometry, you need to:
- Note that static observer's have tangent vectors such that all other components of the metric do not contribute to their proper time. Then this still gives only the relation between coordinate time and proper time for a particular family of observers.
- To convert the above to something observable (coordinate independent) you must examine how one static observer observes clocks or light from another static observer. This is a computation of Doppler. Only Doppler and differential aging are observables, not time dilation.
- Then you note that Doppler is static between a pair of static observers.
- Then you can say that observed redshift and dime dilation between two static observers can be determined from a potential difference.
The view that gravitational time dilation is direct observable in GR, with a definition in terms of the metric (in the general case) has led to numerous fundamental misunderstandings displayed on these forums. Thus I think it is crucial to counter the very attitude you present - that gravitational redshift= gravitational time dilation is a general feature of GR; that a component of the metric in some coordinate basis describes something physically significant; that there is any general way to separating gravitational redshift from Doppler.
Basically, you are ok with common treatments that I view as half way between misleading and just plain wrong.
Also, any description which equates a gravitational potential difference to a "relative velocity" is potentially seriously misleading, as it suggests that there is a fixed velocity difference along a general path which travels from one to another, which is not true.
My descriptions have emphasized that relative velocity is not unique in GR, but that for Doppler, what counts is relative velocity determined by parallel transport along the light path. Please read the wording I contributed to the FAQ - it very carefully makes these points in as succinctly as possible. Because there is one specific path that matters for Doppler (the path actually taken by light), there is a static relative velocity between static observers, for the purpose of Doppler].
There is a fixed potential difference, which means that the change in kinetic energy is a fixed proportion of the initial energy, but the velocity difference is dependent on the initial velocity. When this is applied to the special case of light propagation, then there is a unique meaning, but there's no change of local speed involved, so calling this a relative velocity seems unhelpful.
This is all backwards. GR does not natively have any concept of potential difference. Nor does it have any native concept of KE of light changing, apart from Doppler in curved spacetime. The existence of a potential as a useful, non-fundamental, computational trick that derives from the special case of a timelike killing vector picking out a family of observers for which Doppler takes a remarkably simple form. Then you can use this to facilitate determination of Doppler in static spacetime by first considering Doppler between static observers (based on potential difference), then computing strictly local SR Doppler between each world line and a corresponding static world line.
Note also, that the idea there is a unique (for Doppler purposes only) relative velocity between static world lines in a static GR solution makes nice contact with the idea that in SR, Doppler between front and back of a rocket can be attributed to velocity of emitter at emission event relative to velocity of absorber at target event. Thus, just as SR has no need to introduce pseudo-gravity to explain any redshifts in flat spacetime, GR does contains only one fundamental notion for observed spectral shifts.
It is obviously true that if you look at the same phenomenon in a different way you should get the same physical result, as I've recently mentioned for the spinning space station. However, the most general way is not necessarily the most useful. I think it is more helpful to understand simple special cases in detail and then to be aware that there are ways of uniting them into a general but more complex scheme.
I remain convinced that pretending that, for GR, Doppler, gravitational redshift, and cosmological redshift are three separate phenomena is simply wrong. And to the extent that so much literature gives this impression, we should, on PF work against this bad practice.
I agree that common answers in terms of expanding space make a very simple idea easily explainable in SR into something mysterious (I have not emphasized in this thread that using Milne foliation you can get arbitrary recession speeds even in flat spacetime). There is nothing going on here beyond the difference between growth of proper distance between world lines using a chosen foliation (for which neither SR nor GR poses any upper bound), versus relative velocity, which uniquely < c for SR, and not unique in GR (but always < c).
However, to answer Naty1, there is a very good reason such coordinates are used in cosmology and why it is useful to talk about recession velocity as normally defined. That is that in these coordinates, the isotropy and homogeneity observed by all comoving observers is made manifest.
I'm absolutely with you. Especially the common statement that cosmological redshift is not a doppler shift is really evil.
However, I'd also like if you'd use coordinate-dependent statements as well, as Jonathan Scott promotes it.
For example,
this one's true: g_tt in static coordinates describes a significant symmetry. Of course, this symmetry may not be exact, as in an expanding spacetime where you use "static" coordinates on a small patch, but still, is has some merit.
I'm under the impression that much of the discussion is about words rather than physics.
For example, I understand why you want to call the "Synge-type" redshift a Doppler shift. But couldn't we call it "GR redshift" or something like that instead and use the name "Doppler shift" as close as possible to its pre-relativistic meaning? This would imply that you use "gravitational redshift/time dilation" as its counterpart, too.
My reasoning: those words have some relatively well defined meaning to the layman or semi-expert reader, and as such could help to intuitively explain the rather "fuzzy" and complicated world of GR, where for example GR redshift is well defined, but way beyond the mathematical abilities of 99% of the readership. Just start talking about path dependency of the procedure, and you'll lose all those that don't have the necessary geometrical background.
But if you define an observer, doppler and gravitational redshift are complementary description of reality: doppler is two-way redshift, while gravitational redshift is one way only. The former is accompanied by a changing distance, the latter is what's left for obervers at rest wrt each other.
Of course, the very meaning of "chaqnging distance" or "at rest" becomes fuzzy at large timescales, large distances in a changing spacetime, but they're useful in most circumstances except large scale cosmology. And their meaning is relatively clear to most readers.
So why not say "GR redshift" is the canonical description in GR, the other descriptions are "human made" distinctions.
Where, in the coordinates the readers are most familiar with, redshift can be split into doppler and gravitational. But such coordinates are not suitable for too large an area in a dynamic spacetime.
Where, in the case of a cosmological symmetry, one can alternatively use cosmological redshift, which doesn't describe a different physical phenomenon - every cosmological redshift can also be explained as a combination of doppler and gravitational redshift in their domain of applicability, after all. But, given said symmetry, cosmological redshift's domain of applicability is truly universal, that's why we're using this additional concept, too.
Which is kind of my point: You wouldn't describe e.g. solar system mechanics in FRW coordinates. Also, the canonical "Synge-type" redshift isn't of much use - at least not as misleading an mystic as the FRW description, but just plainly useless.
You'll use a quasistatic background, even if the universe isn't static, and you'll use the potential and the notion of (relative or absolute, doesn't matter) velocity that comes with this assumed, not really exact background. You'll do highscool physics and e.g. calculate the effect of universal expansion on solar system dynamics without any difficulties: It's simply the gravity of the additional matter/energy within the system.
That's an example how practical and useful a quasistatic background with its quasiNewtonian physics is. Doppler shift and gravitational redshift/time dilation also belong to this extremely useful heuristic, why don't you encourage their usage?
I only have a moment now, but a few comments:
- Doppler in GR (what you call Synge redshift) in the solar system is impractical computationally, agreed, but precisely accurate all the same (as to physical concepts and math).
- I do not oppose use of any what you describe here; it is what I do (as I'm sure what anyone does) to make a computation. However, I do feel it is important to understand that there is a single core phenomenon, with special cases that simplify and are given special names. The wording I proposed for this does suggest the utility of the special case treatment. Perhaps emphasis can be shifted. Here is what I contributed to this section:
"Gravitational Redshift describes Doppler between static emitter and receiver in a gravitational field. Static observers in a gravitational field are accelerating, not inertial, in general relativity. As a result (even though they are static) they have a relative velocity in the sense described under Doppler. Because they are static, so is this relative velocity along a light path. In fact, the relative velocity for Doppler turns out to depend only on the difference in gravitational potential between their positions. Typically, we dispense with discussion of the relative velocity along a light path for static observers, and directly describe the resulting redshift as a function of potential difference. When the potential increases from emitter to receiver, you have redshift; when it decreases you have blue shift. "
I don't mind a shift in emphasis, but I do feel it is important to get across that starting from SR Doppler and asking "what is Doppler in GR", an accurate answer leads, as a derived consequence, the asymmetric redshift between sufficiently static observers, as well as to the cosmological redshift.
Also, what I see as really in common between these and possible additional special cases is:
- symmetries pick out some family of observers between which GR Doppler takes a simple form.
Whenever this is true, you can then treat Doppler for general observers by applying the simple formula for special observers, combined with local pure SR Doppler for emitter motion relative to coinciding special observer; similarly for target motion relative to its coincident special observer.
I could agree with calling the single GR phenomenon "GR redhsift" rather than "GR Doppler" as long as we get across that it is the GR generalization of SR Doppler, and includes SR Doppler as well as well as gravitational redshift as special cases.
However, as for how to classify cosmological redshift, the following paper:
http://arxiv.org/abs/1111.6704
proposes a specific definition of kinematic (which you need not agree with, but at least they pose a precise one), such that much of cosmological redshift is considered due to spacetime curvature rather then kinematic (despite being symmetric).
Personally, I prefer the concept of a preferred (by symmetries) family of observers picking out a simple form GR redshift, that can be used to analyze general observers. We give the name 'gravitational redshift' to static observer's (asymmetric)shift, and 'cosmological redshift' to comoving observer's shift (which is symmetric).
I've seen this debate numerois times in the past in regards to redshift being ill defined. That was one of the reasons I was pleased to having PAllens assistance. The viewpoint above is one that I agree with.
I've been thinking of how to go about modifying the article.
The article I feel can be narrowed down to two questions. The others being covered by other FAQs in the subforum.
1) Is redshift the same as Doppler shift?
2) How do we determine a stellar objects location (and inherently motion.)
I want to clarify why I think it is most accurate to view the single phenomenon in GR as "Doppler in curved space time". Ich earlier proposed a dichotomy between gravitational redshift for situations where distance does not grow and shift is asymmetric; versus Doppler where distance grows (or shrinks) with symmetric red (blue) shift.
I think this distinction is misleading because it implies that gravitational redshift must be distinguished from Doppler even for SR. At the fundamental level, this is absurd. The case of an accelerating rocket is strictly explained by Doppler, and shows that the attachment of symmetry to Doppler is restricted to inertial motion. Once you have non-inertial motion in SR, you find asymmetric Doppler between world lines, with distance not changing (depending on who measures it how). Furthermore, to first order (but not higher order) asymmetric shift between static observers in GR has exactly the same explanation as a pure Doppler effect when viewed in inertial frame (as the SR rocket case).
Thus, I think the correct approach is to start from observations like the above to explain there is one phenomenon in GR responsible for all spectral shifts, and that it is Doppler generalized to curved spacetime. The special cases arise from approximate or exact symmetries picking out a family of observers (static; comoving) for which Doppler takes a simple form.
I don't think I will budge from these core postions:
- Is gravitational redshift different from Doppler? NO.
- Is cosmological redshift different from Doppler? NO.
- Must photons be viewed as losing energy for cosmological redshift any more than they
must be viewed as losing energy for Doppler or gravitational redhsift? NO ( I do agree that
there are valid ways of looking at both the gravity and cosmological situations that involve
photons losing energy - but such a view is not required).
- Despite the fact that there is no reason to view 'individual' photons as losing energy, there is a fundamental conservation issue in FLRW cosmology. But I view the core issue as the inability to even define total energy for such spacetime; and that there is not necessarily any reason to expect energy conservation because of time asymmetry.
Right, as in "you're in a balloon", if you know that old joke. :smile:
That's ok. However, I'd say the core phenomenon concerning redshift is the parallel transport of the wave vector along the null curve. That you get the same result by transporting the four velocity of the emitter is fine, and it may add some insights that would otherwise be lost. For example, it's interesting that gravitational redshift can be seen as an application of redshift due to relative velocity. I played with the idea, too, but my experience is that you confuse your audience rather than enlight them. I also think that the definition of gravitational redshift as being due to relative velocity between static observers is a bit on the progressive side of mainstream - I won't challenge its validity, but I doubt it's the most helpful interpretation. We should not set this as a standard interpretation, IMHO.
As said, my feeling is that this is a bit too general. Starting from SR, you have doppler shift due to relative velocity = position change. Going to GR, you may either generalize Doppler to include shift between static observers as well, or you may keep that distinction and differentiate between doppler and gravitational shift. Both are valid, but I think the latter approach is much more suitable to pick the readers up from where they already are.
I'm just talking about the wording. Call it GR redshift, feel free to explain how it can be seen as a generalisation of a Doppler shift, but use the word "Doppler" for the following:
I agree and add: looking at emitters with some relative velocity wrt said static observers, you get the most appropriate definition of Doppler shift, which you simply multiply with the gravitational shift to get the total result. As you can see, I'm rather with Peacock in that interpretation than with Ostvang. You can split the effects in every type of cosmology, at least as far as "static" has - at least as an approximation - some well-defined meaning that can be interpreted as "not moving".
I just want to save this Doppler definition for the GR case, too. It's way too useful to be discarded.
Which galaxies are not moving in an FLRW cosmology?
FYI: I see no problem with an FAQ suggesting that there are more than one valid way of viewing things. Twin FAQs are famous for that. Thus, while I strongly resist a claim Doppler is definitely not the same gravitational redshift I could easily go along with:
- looked at one way, the distinction is.
- looked at another way, they are the same.
There are none. But in order to construct a "SR-like" coordinate system, you'd provide some observers that are at rest wrt each other (as measured by vanishing two-way redshift between adjacent observers) instead of some that we know to have relative velocity. And you'd use those to take the place of Einstein's clocks in his inertial frames, not the moving galaxies, of course.
In other words: You can always use Normal Coordinates, and by doing so you'll always gain some intuitive insight.
Because Normal Coordinates translate this fuzzy GR world into the concepts that most of us are familiar with.
Great. I don't make such claims, and my goal is to prevent unsubstantiated claims like: cosmological redshift is not a doppler shift. So we agree, there's a useful notion of "doppler" against "gravitational" redshift also in GR, and there's the coordinate-independent fact that redshift is generally explained by parallel transport (of the source or the signal, whatever).
Of course if a free faller does this near a planet, they conclude there is pure relative motion Doppler between 'static' bodies. Meanwhile the static bodies do not fit the 'relatively motionless' criteria you give (no vanishing redshift). So, setting up 'as close to Minkowski' coordinates over a region of interest in GR leads to:
- Cosmological redshift is clearly Doppler
- gravitational redshift is also clearly Doppler.
Almost. I agree that there is derived, practical, approach of 'gravitational redshift'. But attaching more significance to it implies that one must distinguish Doppler between non-inertial world lines in SR from that between inertial world lines. Conceptually, this last is silly. However, for SR as much as GR, there are common situations where the 'gravitational redshift heuristic' simplifies problem solving enormously.
Also, the parallel transport is the 'second order' phenomenon sensitive to curvature. The 'first order' difference between inertial Doppler and non-inertial Doppler (to coin a phrase) has nothing to do with parallel transport, because that is a no-op in SR. In any case, we don't necessarily have to agree (completely or at all); we only have to agree that there are a couple of valid ways of looking at these issues.
Dear PAllen!
Do you agree that space is expanding (or stretching of space )?
nonspace said:
Dear PAllen!
It is, mathematically, a coordinate dependent effect (in that you can construct an apparent expanding space for flat, Minkowski spacetime - see the Milne universe). However, in the real world, the division between space and time leading to expanding space is preferred by physical symmetries of the universe and experience of observers: we observe isotropy and homogeneity at large scales; so do other galaxies. Any separation of spacetime into space and time that manifests these symmetries will show expanding space.
So, to sound like Clinton, it depends on what the meaning of is is; but mostly the answer is yes.
This is an accurate statement. I tried showing that in the article with your assistance on the GR viewpoints. After the long weekend I plan to pull the excess expansion details out. Develop the Article to the two view points.
The section on cosmic distance ladder I will use for a second article covering how distances and motion ae measured.
The trick will be writing the two articles without repeating as both articles involve redshift in a fsshion.
PALLEN:...
It's even more important than that! It's absolutely necessary for perspective...One reason is that many if not most readers will have not exhaustively studied all the detailed math of cosmology and likely not of GR either...If Tamara Davis can provide alternative perspectives, and such alternatives are real,and valuable, and they ARE, so should we...
In the great 2007 thread Wallace, Chronos ,Oldman, Marcus, others take different views ...you can read the posts from the 40’s thru 50’s and see the pros and cons.
https://www.physicsforums.com/showthr...nt+flow&page=4
One view:
I do think it is better to think of (photons) as being redshifted by being observed in a different frame ...Now as t ticks along, the scale factor a(t) increases. Therefore two observers who are both at rest wrt to the CMB, but who have different times t will therefore be in different frames (have different metrics). This is what leads to photons being redshifted when observed and emitted at different times.
[Contrast that observational persective with one from above:
ICH:
... in order to construct a "SR-like" coordinate system, you'd provide some observers that are at rest wrt each other (as measured by vanishing two-way redshift between adjacent observers) instead of some that we know to have relative velocity.
As 'obvious' as that seems now, it took me [because I am not too bright] a long time to realize that on my own terms...]
a concurrence...from the old thread:
I tend to agree, photons are not redshifted by traveling through the universe, they are redshifted only because they are observed in a different frame from which they were emitted.
a dissent!...
Marcus: # 48...
I am not comfortable with that because among other things I see cosmologists doing inventories of the energy density which are implicitly estimated IN A CMB FRAME...
[If photons are not physically redshifted as they travel though an expanding space, how did the universe cool from about 3,000 to about 3 degrees K today??]
These ‘conflicting’ viewpoints stem in part from this as explained by Chalnoth elsewhere:
… You get some total redshift for faraway objects due to cosmological expansion. How much of that redshift is due to the Doppler shift# and how much is due to the expansion between us and the far away object is completely arbitrary.”
Another 'physical view: In the CMB a grav redshift is the so called Sachs-Wolfe effect...
and another: Chronos:
Redshift is a frame dependent measurement. If you were approaching a distant galaxy at the same speed as it is receeding, you would see no redshift.
But reconciling these different perspectives, showing how they relate,explaining the physical results, is not so easy!
PAllen:
- Must photons be viewed as losing energy for cosmological redshift any more than they must be viewed as losing energy for Doppler or gravitational redhsift? NO ( I do agree that there are valid ways of looking at both the gravity and cosmological situations that involve photons losing energy - but such a view is not required).
Still seems REQUIRED to me...How does one avoid explaining that the universe has cooled...via a redshift or Doppler... of about 1,000 corresponding to an early temperature of 3,000 degrees to about 3 degrees currently?
In other words, wow things get from an opaque, charged plasma of about 3,000 K, a surface of last scattering which blocked photons, to the current 'clear and uncharged' environment?? Something physical seems to have changed!
I have not quite figured that out to my own satisfaction! Thanks
Naty1 said:
PAllen:
Well, let me answer in part with a question: Suppose a collapsed star stopped short of forming a BH with horizon, and had a 3000K black body radiating surface (as experienced on the surface). To all observers well away, there is 2.7K black body radiation. For this it is routine (and Jonathan Scott agrees with this perspective) to say the no photons lost energy. Simply that 3000K on the collapsed surface corresponds to 2.7K far away; thus the photon was emitted at local temp of 3000K=2.7K far away perspective, and didn't change at all along the way to being received. Yet this is not considered a violation of conservation of energy or a mystery at all - just a difference in time and energy scale between different locations. For cosmology, instead of different time and energy scale varying by location in a static geometry, you have different time and energy scales at different cosmological times. Thus, there really is no reason you need consider CMB photons to have lost energy over time - instead you can equally well (a la gravity well case) consider the energy scale changed over time, and that the two scenarios are equivalent.
Does this mean there is no conservation of energy problem in FLRW cosmologies? Unfortunately, it doesn't address this issue. There is a fundamental difference between 'sufficiently static geometry' in 'sufficiently flat very large region', where we can define quasi-local energy in a consistent way (and for which 3000k photon near the collapsed surface adds the same total energy as a 2.7 K photon far away), coming up with a conserved quantity. For FLRW cosmologies, all known ways, within GR, of totalling energy for the universe fail (they require either asymptotic flatness or something close to it). Thus, my point of view (shared by Tamara Davis post 2009), is the total energy of the universe is undefined, so the failure of conservation cannot even be posed. But none of this is related to whether photons must be considered to change energy from emission to absorption in cosmology.
PAllen:
...3000K on the collapsed surface corresponds to 2.7K far away; thus the photon was emitted at local temp of 3000K=2.7K far away perspective, and didn't change at all along the way to being received.
That's another nice example...so ok, I guess the dichotomy I am struggling with is my 'flat space' mind with the vagaries of 'curved space-time'...
Towards the end of the article linked above, Tamara Davis expands this perspective a bit..., so I guess these ideas are as 'good as it gets'...thank you once again!
...because in small enough regions
the universe makes a pretty good approximation
of flat spacetime. But in flat spacetime
there is no gravity and no stretching of waves,
and any redshift must just be a Doppler effect
So we can think of the light as making many
tiny little Doppler shifts along its trajectory.
And just as in the case of the police car—where
it would not even occur to us to think that photons
are gaining or losing energy—here, too, the
relative motion of the emitter and observer
means that they see photons from different perspectives
and not that the photons have lost energy
along the way.
In the end, therefore, there is no mystery to
the energy loss of photons: the energies are being
measured by galaxies that are receding from
each other, and the drop in energy is just a matter
of perspective and relative motion.
PAllen...
I did not mention it in my prior post but I do understand [I think] about FLRW cosmologies not addressing energy conservation...On the other hand, I don't really understand this part of your prior post and I am remiss in skipping over it:
...There is a fundamental difference between 'sufficiently static geometry' in 'sufficiently flat very large region', where we can define quasi-local energy in a consistent way (and for which 3000k photon near the collapsed surface adds the same total energy as a 2.7 K photon far away), coming up with a conserved quantity.
I'm confused by this description because I don't see how you are disentangling motion and curvature...I assume near the 'collapsed surface' there is curvature [a change in gravitational potential??] and hence gravitational redshift as a photon is emitted ...If there is no curvature and a 'static' geometry, [do you mean 'no expansion'??] then should I not expect to see the photon at distance as emitted, unchanged, at 3,000 K??
Hi PAllen,
I think you misread what I wrote. I was talking about vanishing two-way redshift, which clearly vanishes for static observers. Sending light down the potential, you get gravitational blueshift, which is exactly canceled by the redshift on the way back if there is no radial motion between the observers.
Why is that? This is a coordinate based concept, we're not talking about right or wrong here, we're talking about "useful" or "useless". If it's useful, use it. If not, let it be.
Well, using fictitious concepts like a "gravitational field" may in fact be "silly" at times. That's no reason to generally forbid its use, as they may be very helpful in other situations.
Remember what you're arguing against: There are those who insist that one must not see cosmological redshift as a doppler shift. Why would you insist that one must not see redshift (under the appropriate circumstances) as a "gravitational" redshift. Why would you forbid it, when it's clearly of use somtimes? (If that's your intention at all, I may have misunderstood you.)
Comparison via parallel transport is trivial in SR and yields standard relative velocity, at least for the frame where the compared events are simultaneous. If the events are null-separated, you might also want to interpret the result as a gravitational redshift, if it suits your purposes. No special significance to it, it may just be useful and even reflect something important in nature.
I think there may be a misunderstanding concerning my use of "first" and "second order" effects: in a homogeneous universe, if you make a series expansion of redshift as a function of normal distance (in the quasistatic frame), the Hubble flow will show up as a first order effect, while the gravitational potential is parabolic with distance. I did not intend to say that, generally, gravitational redshift is a second order effect. Sorry for the confusion.
BTW, this thread's going too fast for my limited (and phase-shifted) time online.
To sum up, my point is: there are times to call a redshift cosmological, doppler, or gravitational. Don't call it "doppler" under all circumstances, you're going to sow confusion. It's good to say that GR itself doesn't care about these concepts, it's ok to say that the redshift concept you propose is kind of "canonical" in GR, and it's ok to explain that it might be seen as related to a doppler shift. But there's no use henceforth calling every redshift "doppler".
Make of it what you will, I'll have a look at this thread from time to time and be happy to answer to your (and anybody's) comments, if it doesn't disturb the many strands in this discussion.
