Reflection and Transmission of acoustic waves at a boundary
The problem involves the reflection and transmission of longitudinal acoustic waves at the boundary between aluminium and copper. Participants are tasked with calculating acoustic impedances, amplitudes of reflected and transmitted waves, and the percentage of incident power that is transmitted and reflected.
  • Participants discuss the calculation of acoustic impedances and the relative amplitudes of reflected and transmitted waves. There is a focus on understanding what it means to express these amplitudes relative to the incident wave amplitude, with some questioning the implications of this ratio.
The discussion is ongoing, with participants clarifying the concept of expressing amplitudes as fractions of the incident amplitude. There is a productive exchange regarding the interpretation of the problem, particularly around the significance of ratios in this context.
Participants note the lack of information regarding the amplitude of the incident wave, which raises questions about how to approach the calculations without this data.
Nerrad
An interface is formed between a block of aluminium (density = ##2.70 \times 10^3 kg/m^3##, speed of sound =##6.40 \times 10^3m/s##) and a block of copper (density = ##8.96 \times 10^3 kg/m^3##, speed of sound =##4.76 \times 10^3m/s##). Longitudinal waves traveling through the aluminium are normally incident on the boundary, and are partially reflected. Calculate:
(a) The acoustic (characteristic) impedances of aluminium and copper;
(b) The amplitudes of the reflected and transmitted waves, relative to the incident wave;
(c) The percentage of the incident power that is transmitted and reflected.
(a) The acoustic characteristic impedance of a material is given by:
$$Z = \rho v \text{ (1)}$$
where ##\rho## is equal to the density of the material and ##v## is the acoustic velocity
(b) Reflection coefficient is given by :
$$\frac {A_r} {A_i} = \frac {Z_1-Z_2} {Z_1+Z_2} \text{ (2)}$$
Transmission coefficient is given by:
$$\frac {A_t} {A_i} = \frac {2Z_1} {Z_1+Z_2} \text{ (3)}$$
(a) By using equation 1, I've obtained impedances of ##1.73 \times 10^7## and ##4.33 \times 10^7## respectively.
(b) I have to work out the amplitudes relative to the incident wave, but I'm not given the amplitude of incident wave, so how do I go about tackling this question? Thanks
Read this carefully. You are asked to find the reflected and transmitted amplitudes relative to the incident wave amplitude. What does that mean?
Does it have something to do with ratio? To me it's quite vague
Yes, it has to do with ratio. Call the incident amplitude 1 and find the reflected and transmitted amplitudes as a fraction of 1.
Oh so what you mean is that it doesn't matter what I set the incident amplitude as, because at the end I'm going to get a percentage/ratio of it? Kinda like how for probability it all adds up to 1?
Exactly.
  • · Replies 17 ·
