Shyan said:
In fact the problem asks for the reflection coefficient for the normal incidence which makes both polarizations the same!
Nothing is assumed about the layer's thickness.
The third layer is an ideal conductor, so no wave is present in it, neither an incoming wave nor an outgoing one!
As a boundary condition, the tangential component of the electric field should be continuous at the interface. Because here the third layer is an ideal conductor, the electric field, and so its tangential component, is zero inside it and so the tangential component of the electric field should be zero at the second layer too. But for normal incidence, we only have tangential components of fields which means the field is zero in the second layer!
Also we should note that there will be infinite number of reflections until the wave is reflected completely. But this point should be considered after solving the previous one!
Ok, then that greatly simplifies the whole process. But I'll expand upon what has already been stated regarding the solution. You basically start by assuming the basic solution to the waves. We can work with only the electric field since the magnetic field can be solved directly from there. So we start with an incident wave,
[tex]\mathbf{E}_{inc}(\rho,z) = E_0 e^{-ik_1z}\hat{x}[/tex]
where the boundary between air and dielectric lies at z=0 and along the x-y plane and the PEC lies at z=-t. Since we are talking about normal incidence, there is no dependence on the transverse position and the wave vector is in the -z direction. I've also implicitly assumed a -i\omega t time dependence.
So in the air layer, you have two waves, the incident and reflected wave which will be described by a reflection coefficient. In the dielectric, you will have a transmitted wave, and a reflected wave off of the PEC boundary. Now the reflected wave is going to be the reflection of the transmitted wave. In the PEC, as been stated previously, there is no wave. Thus,
[tex]\mathbf{E}_1(z) = E_1 \left[ e^{-ik_1z}\hat{x} + \mathcal{R}_{12} e^{ik_1z}\hat{x} \right][/tex]
[tex]\mathbf{E}_2(z) = E_2 \left[ e^{-ik_2z}\hat{x} + R_{23} e^{ik_2z+2ik_2t}\hat{x} \right][/tex]
[tex]\mathbf{E}_3(z) = 0[/tex]
where [itex]\mathcal{R}_{ij}[/itex] is the generalized reflection coefficient from the i-th layer to the j-th layer. Generalized in that they incorporate all the multiscattering effects from the layers above or below. We know that [itex]\mathcal{R}_{23} = R_{23}[/itex], where [itex]R_{ij}[/itex]is the reflection coefficients between the two layers as if they existed by themselves. We know this because there are no layers below the PEC, thus [itex]\mathcal{R}_{23} = R_{23}[/itex]. In addition, we have a factor of 2 in the 2ik_2t term because the wave has to travel a distance of t to get to the PEC boundary, and another phase factor comes in because the reflection coefficient is the ratio of the incident and reflected waves at the boundary (the incident wave also picks up its factor of ik_2t when it travels to the PEC boundary).
So you are correct that there are going to be these infinite number of reflections and transmissions amongst the layers. But you can account for these by the fact that we will have a single reflection/transmission coefficient account for all these multiscattering effects. The electromagnetic waves still must satisfy the boundary conditions along the boundaries. So you know that, for example, at the air-dielectric interface at z=0, that the tangential electric field is continuous. At the PEC boundary, the total tangential electric field is zero. So we know that
[tex]E_2e^{ik_2t} + R_{23}E_2e^{ik_2t} = 0[/tex]
So we see that [itex]R_{23} = -1[/itex].
Let's take a look at the constraint equation for the air-dielectric boundary. At the boundary, we have a downward going wave of amplitude [itex]E_2[/itex]. This downward traveling wave is due to the transmitted wave coming in from the air into the dielectric, and we have a wave that is coming up out of the dielectric and reflected off of the air. But the reflected wave is the upward traveling wave in the dielectric which is already scaled by [itex]E_2R_{23}[/itex]. Thus, at z=0, the downward traveling wave is:
[tex]E_2 = T_{12}E_1 + R_{21}R_{23}E_2e^{-2ik_2t}[/tex]
Here you can solve for [itex]E_2[/itex]. Next, construct the constraint equation for the upward traveling wave. The upward traveling wave in air is due to the GENERALIZED reflection coefficient and this is equal to the reflection of the incident wave in air on the dielectric and the transmission of the upward traveling wave from the dielectric into the air. So,
[tex]E_1\mathcal{R}_{12} = R_{12}E_1 + T_{21}E_2R_{23}e^{-2ik_2t}[/tex]
So now you can solve for the generalized reflection coefficient and that's all that there is too it. Things get slightly trickier when we have oblique angles but the process is the same. More convoluted for the cases of anisotropy.
Hopefully there isn't too many mistakes in the above. I've got a run so I can't spend anymore time proofreading. Unfortunately, I have only seen the treatment of this in graduate textbooks. However, a transmission line is a 1D wave equation. So I'm sure you can draw parallels in how to solve for the reflection coefficient in a series of transmission lines.
EDIT: The above assumes that we only have an anisotropy in the z-direction and are isotropic otherwise.
I'm still wondering if this is really the problem you are being asked as it seems like it's rather advanced from what you have stated. I could imagine that they were asking for the reflectivity which as already been stated is a trivial 100% assuming lossless dielectrics.
