Is the Flask Closed or Open to Atmosphere During Reflux Heating?
  • Thread starter Thread starter Rajini
The discussion centers on the heating of solvents in a reflux apparatus and whether the flask should be closed or open to the atmosphere. It is established that a completely sealed flask is not advisable due to the risk of pressure buildup, which can lead to explosions. For oxygen-sensitive reactants, it is recommended to pass an inert gas, such as argon (Ar), continuously during heating at temperatures around 250 degrees Celsius for 30 to 60 minutes. Additionally, using an oxygen scrubber with vanadium(II) chloride solution may be beneficial for enhanced safety.
  • Understanding of reflux apparatus and its components
  • Knowledge of inert gas usage in chemical reactions
  • Familiarity with oxygen-sensitive reactants
  • Basic principles of pressure dynamics in closed systems
  • Research the use of argon gas in chemical heating processes
  • Learn about the design and function of oxygen scrubbers
  • Investigate the properties and safety measures for vanadium(II) chloride
  • Explore best practices for handling pressure in closed chemical systems
Chemists, laboratory technicians, and researchers working with sensitive reactants in reflux heating applications will benefit from this discussion.
Rajini
Hello All,
I have a doubt in reflux apparatus. Usually when we heat some solvents in a glass flask it may evaporate..and this vapour is cooled by reflux condensor and again go into boiling solvent. So on heating the amount of solvent won't decrease or decompose. What I want to know is whether the flask is closed or left open to atmosphere while heating?
Regards, Rajini.
Chemistry news on Phys.org
Ordinarily, NOT ALWAYS.
It is very seldom a good idea to heat a completely sealed apparatus, as pressure can build up and cause it to explode. If your reactants are water sensitive, a drying tube can be placed on top of the condenser to eliminate moisture, and if they are oxygen sensitive the apparatus would need to have a stream of inert gas supplied, or be run inside a glove box.
Hello Bystander,ManiacaLaugh,
Thanks for your reply. My reactants are oxygen sensitive. Also I cannot heat inside a glovebox/bag! So plan to pass continuously an inert gas (Ar) while heating (30 to 60 min of heating around 250 celsius is enough for my case).
Regards, Rajini.
Depending on how sensitive your reactants are, you may want to use an oxygen scrubber with vanadium(II) chloride solution.
12K
  • · Replies 26 ·
21K
  • · Replies 30 ·
