Refraction, wavelength and frequency
The discussion revolves around the relationship between wavelength, frequency, and refraction of light. Participants explore how these properties interact when light transitions between different media, addressing both theoretical and conceptual aspects of wave behavior in varying refractive indices.
  • Some participants assert that when wavelength increases, frequency decreases, but this is not universally applicable in all contexts, particularly in media.
  • One participant explains that in refraction, the frequency remains constant while wavelength and speed change, suggesting that the frequency does not change due to the linear response of the medium's atoms or molecules.
  • Another participant emphasizes that the rate at which peaks enter a medium does not change, leading to a bunching effect in regions of higher refractive index, which implies that frequency remains constant.
  • Some participants express confusion about whether the wavelength changes as well, questioning the implications of the frequency remaining constant.
  • It is noted that frequency changes in specific scenarios such as Doppler shift or gravitational redshift, which are unrelated to the medium through which light travels.
  • One participant discusses the mathematical relationship between frequency, wavelength, and speed, indicating that if frequency remains constant while wavelength changes, speed must adjust accordingly.
  • Another participant introduces the concept of dispersion, explaining that in media, the relationship between frequency and wavelength can become non-linear due to the dependence of the index of refraction on frequency.
Participants do not reach a consensus, as multiple competing views remain regarding the relationship between frequency and wavelength in different contexts, particularly in media versus vacuum.
Limitations include the dependence on definitions of frequency and wavelength in different media, as well as the unresolved implications of dispersion on the relationship between these properties.
Gajan1234
I've learned that when wavelength increase the frequency decreases.
But in Refraction, there is a mention about frequency remains same but the wavelength and speed changes. Why does the frequency doesn't change? I thought when when wavelength is short the peaks are closer to each other so there will be more cycles per second.
Science news on Phys.org
Hi Gajan:
The rule above is not for a single photon but relates to comparing properties of different photons moving at the same speed.
One form of the relevant equation is:
wavelength × frequency = speed.​
When a photon slows down moving through some medium, the frequency is unchanged, so the wavelength is then proportional to the speed.
Hope this helps.
Regards,
Buzz
The two statements above are unrelated.
There, you are talking about the spectrum of the electromagnetic wave. In vacuum, rgardless of its frequency or wavelength, EM wave propagates with the speed of ##c=3\times 10^8## m/s. The frequency and wavelength are related through ##c=\lambda f##. So, obviously in order to keep ##c## fixed, ##\lambda## and ##f## must change in a reciprocal way.
In the linear regime, which is applicable in most cases, the transmitted/refracted light has the same frequency as the incoming one because the substance making up the medium response linearly. This means, if the incoming light has a frequency ##f##, the atoms or molecules inside the medium also oscillates with a frequency of ##f##, radiating a secondary wave with frequency ##f##. The wavelength, however, must change because each emitter (the atoms/molecules) must radiate such that all emitted waves superimpose constructively. Mathematical analysis shows that this so-called phase matching between the emitters requires that the wavelength be different from that of the incoming wave.
Light is a wave. In a beam there is a continual train of peaks and valleys. When light transitions to a region of higher index of refraction, the rate at which peaks come into the region doesn't change. Instead they bunch up more. Think about it. If the frequency of peaks was lower coming out of the region than coming in, either peaks would have to continually build up in the juncture or the output wave would have to become decorrelated with the input wave.
I am quite confused, does this means that the wavelength will bot change as well.
Buzz Bloom said:
Hi Gajan:
Hope this helps.
Regards,
Buzz
Are we not viewing light as wave in this case?
The wavelength changes. The frequency does not change.
so where do we apply the rule that the frequency changes when wavelength is changed
Frequency changes in the case of Doppler shift or gravitational redshift. This is due to the relativity of time and had nothing to do with traveling through media.
If speed is constant, frequency changes when wavelength is changed.
The wavelength is inversely proportional to the frequency, [tex]ƒ = \frac{cycles}{time} \ \ \ \ λ = \frac{time}{cycles}[/tex] So this relationship basically means that [tex]λ = \frac{1}{ƒ} \ \ \ \ \ \ \ λ = \frac{c}{ƒ}[/tex] [tex]c = λƒ \ \ \ \ \ \ v = λƒ[/tex] This means that the velocity is equal to the product of the wavelength and it's frequency. If the frequency remains constant and the wavelength changes, it means that the speed would increase or decrease in order to compensate for the cycles over time.​
This is true as long as you compare waves moving either in vacuum or in the same medium. However, in media, the speed of light is different than the speed of light in vacuum. In general, ##f=c_0 n/\lambda##, where f is frequency, ##c_0## is the speed of light in vacuum and ##\lambda## is the wavelength. The index of refraction, n, is typically a function of frequency itself, so that the relation between frequency and wavelength becomes non-linear. This is called dispersion.
In refraction, you consider a situation where light changes from one medium to another. In this situation, frequency stays constant, but the wavelength changes due to the different indices of refraction of the media into question.
  • · Replies 16 ·
