Refractive Index change with Wavelength & Carrier Concentration
The discussion revolves around calculating the refractive index of semiconductor materials over a specific wavelength range (1×10-5 m - 1×10-9 m) while considering different carrier concentrations (n/p doped). Participants explore the relationship between refractive index, wavelength, and carrier concentration using the Plasma-Drude model and discuss the implications of various parameters in the equations involved.
  • One participant seeks to understand why the calculated refractive index remains relatively constant despite changes in wavelength, suggesting a potential oversight regarding the wavelength dependence of the dielectric constant (εm).
  • Another participant points out that the left-hand side of the equation is complex, while the right-hand side appears to be real unless absorption is considered.
  • Discussion includes the need to account for electric susceptibility (χe) in the refractive index calculation, with some participants suggesting that εm must be a function of frequency.
  • Concerns are raised about the validity of the formula over a wide range of wavelengths, particularly from infrared to x-rays, and whether it can accurately predict refractive indices across such a spectrum.
  • Participants discuss the limitations of the Drude model and the potential need for using the Sellmeier equation for more accurate results within specific wavelength ranges.
  • There is a suggestion to calculate the overall refractive index including doping by modifying the original equation to incorporate values obtained from a referenced materials database.
  • Some participants express uncertainty about the definitions of parameters in the susceptibility equation and how to establish values for χe over smaller wavelength ranges.
Participants express a range of views regarding the applicability of the equations and models discussed, with no clear consensus on the best approach to calculate the refractive index or the validity of the formulas across the specified wavelength range.
Participants note that the equations and models may have limitations in their range of validity, particularly when applied to a broad spectrum of wavelengths. There is also uncertainty regarding the definitions and implications of various parameters in the susceptibility equation.
This discussion may be useful for researchers and students interested in semiconductor optics, refractive index calculations, and the effects of doping on optical properties in materials.
rbert15
I need to calculate the refractive index of a semiconductor material over a wavelength range (1×10-5m - 1×10-9m) and with different values of electron and hole carrier concentrations (i.e. n/p doped).
I found this equation that relates those parameters:
n+ik = √ [ (εm - [(e22)*((n0/m*e)+(p0/m*h))]) / ε0 ]
The values ε0 and e are known constants. For each semiconductor material I'm interested in, the values of electron and hole concentrations (n0 and p0) and the effective electron and hole masses (m*e and m*h) have been found, as well as the value of the dielectric constant/relative permittivity (εm), all via literature (http://www.ioffe.ru/SVA/NSM/)
The problem is that whilst the equation is giving me results, the value of the refractive index (n+k) is not varying as much as it should when the wavelength is changed. For example for InAs it should change from about 4 to 1, whereas it is staying almost constant at 3.5 regardless of wavelength.
The frequency (ω) in the equation is calculated by simply ω=c/λ and this value (and the subsequent term) is so small compared to εm and ε0 that it doesn't have much influence. Does εm have a wavelength/frequency dependence I'm not accounting for? I can't see any other variables that would have λ dependence to increase λ effect on n calculation.
Science news on Phys.org
A very good idea is to recheck the reference where you got that equation from. Second, the LHS is complex while the RHS seems to always be real unless one also takes the absorption in relative permittivity into account.
The equation is from the Plasma-Drude model as shown here http://docs.lumerical.com/en/index.html?ref_sim_obj_charge_to_index_conversion.html but I cannot source the reference "Henry, C. H.; Logan, R. A.; Bertness, K. A. Journal of Applied Physics, vol. 52, (1981), p. 4457-4461" to view the original work.
I have checked the units match across the equation.
The RHS should be complex. There must be more to the εr value than just (number*ε0) then - but I don't know what/how to include this.
Ah yes, that is free carrier contribution to the refractive index. According to Drude model, the pure plasma (no bound electrons) system yields the following expression for refractive index
$$ n(\omega) = \sqrt{1-\frac{e^2N}{\epsilon_0 m \omega^2}} $$
Note that the second term is somehow similar to the corresponding one in the above equation. When all contributions present such as those related to bound electrons, the corresponding susceptibility must also be included which is ## \epsilon_m ##. In other words ## \epsilon_m ## must also be a function of frequency.
So, in first equation how is εm term modified to include λ dependence?
The link you gave there says that ## \epsilon_m ## corresponds to permittivity of unperturbed system, I'm not a pro in semiconductor but I guess it is closely related to the host material before being dopped.
I would check the reference for the range of validity of the formula. You want to use is over a 4 orders of magnitude range of wavelengths, from infrared to x-rays.
I would be surprised if it gives accurate results for both x-rays and infrared, in a single formula.
The values of n over the λ range as calculated using that formula should be valid as that is the method used by Lumerical (where I found the formula) to obtain the "n vs λ" values in their materials database. This is how I know whether my calculations are correct, as I can compare values of n for example with undoped InAs (with intrinsic carrier concentrations) before then moving on to include doping.
Through some further reading I find that "at low frequency the expression for εr reduces to static field case" - this is why the results at the λ=10-5 are close in agreement but way off at the λ=10-9 end of the wavelength range.
I was using just εr=*number for static field case* whereas I should be using εr=1+χe to account for electric susceptibility - which has a wavelength dependence.
χe=(N*e2)/(ε0ω02m) but don't know what are the definitions of N or ω02 or m. I thought N is number of atoms per cm3, λ0 is the wavelength, and m is electron mass, but that doesn't give the overall value required.
I think if I can include χe that will solve the issue.
Note that Drude model is based on classical calculation.
As long as your reference really does mention the range of validity, only then can you be confident with your calculation.
This is the point where Sellmeier's equation comes into play. Don't bother trying to find a closed form of the susceptibility as a function of wavelength for that large range. And also note that Sellmeier's equation for most material are typically defined with high degree of accuracy only within about 0.2 microns up to about 3 microns.
Do they give values of index of refraction for wavelengths in the nano meter range?
The material database gives a list of wavelength (or frequency) vs refractive index (real and imag parts) only for the range 2x10-5 to 5x10-8 - so it doesn't go into nanometre range (which is interesting to note since a lot of simulations take place over the nm range).
I think perhaps I'm looking for a simple answer when there isn't one. I thought that for example for InAs εr=12.3 for static field case then since εr=1+χe then χe would have some simple λ dependence and be a value varying around 1-11.
Is it possible to establish a value for χe over smaller wavelength ranges, say MIR (5-20μm) or nm? I still don't know what all the parameters mean in the χe definition.
As I have said, you should look for the Sellmeier equation for the material of interest. Example of this equation for InAs can be found in this site
http://refractiveindex.info/?shelf=main&book=InAs&page=Aspnes
Just inform yourself about the wavelength range and accuracy of data assumed in this website.
That's a really useful webpage - thanks for the link. I see I can select "0.2-0.8um" range and it shows values of n and ε and states the n doping; or I can select "3-31um" which shows n but doesn't state the n doping (would assume it to be the same, intrinsic). There's an equation for n which includes λ but this doesn't include influence of the doping.
So, I'm still stuck on how to calculate refractive index n based on wavelength and n doping value.
If I were you I would try to calculate the overall refractive index including doping using the equation you found up there
n+ik = √ [ (εm - [(e2/ω2)*((n0/m*e)+(p0/m*h))]) / ε0 ]
with ## \epsilon_m = (n_0 + ik_0)^2 ##, ##n_0## and ##k_0## being the values obtained from that webpage. Again this is purely my speculation, I have got no reference for its justification.
I think that sounds like a good idea - to calculate εm using n0 - and then input this into the first equation.
31K
