Reframing Light Bending Using Density Instead of Radius
  • Context: Undergrad
  • Thread starter Thread starter Owe Kristiansen
    Gravity Newton
The discussion centers on an alternative formulation of gravitational light bending, proposing to express the bending angle in terms of density rather than radius. Participants explore the implications of this approach within the context of general relativity and its assumptions, particularly regarding the geometry of spacetime and the characteristics of astrophysical objects.
  • One participant proposes a new formulation for gravitational light bending using density, suggesting it may provide a more material-based interpretation of curvature.
  • Another participant challenges this approach, arguing that it assumes Euclidean geometry and that many astrophysical objects do not have uniform density or spherical shapes.
  • Some participants note that the deflection angle depends on the impact parameter of the light rather than the radius of the gravitating mass.
  • A participant mentions that the full general relativity result can be expressed as a simple energy ratio, which aligns with historical measurements of light bending during solar eclipses.
  • There are references to previous discussions on the relationship between Newtonian and general relativity predictions regarding light bending, with some participants expressing skepticism about the relevance of such comparisons.
  • Participants discuss the limitations of Newtonian gravity in predicting light bending, emphasizing that it cannot provide accurate quantitative predictions in this context.
  • Some participants express interest in the weak field approximation of general relativity, suggesting it may be sufficient for certain scenarios, such as light bending near the Sun.
Participants express differing views on the validity and practicality of using density in the formulation of light bending. There is no consensus on whether this approach is beneficial or if it introduces unnecessary complications. The discussion remains unresolved regarding the implications of the proposed formulation and its comparison to established theories.
Participants highlight limitations related to the assumptions of uniform density and spherical symmetry in astrophysical objects, as well as the challenges in applying Newtonian concepts to relativistic contexts.
Owe Kristiansen
TL;DR
Title: Reframing Light Bending Using Density Instead of Radius
I’ve been exploring an alternative way to express gravitational light bending:
θ = (4G / c²) * (4π / 3)^(1/3) * M^(2/3) * ρ^(1/3)
Instead of using radius r, I substituted it using the density ρ of a spherical mass.
I’ve been exploring an alternative way to express gravitational light bending, starting from the classical general relativity approximation:
θ = (4 * G * M) / (r * c²)
Instead of using radius r, I substituted it using the density ρ of a spherical mass. It should be correct at the radius of a sphere with uniform density.
For a sphere:
ρ = M / V = M / ((4/3) * π * r³)
Solving for r gives:
r = (3M / (4πρ))^(1/3)
Substituting this into the original bending formula gives:
This reframing expresses light bending as a function of mass and density, rather than radius. It seems to offer a more material-based interpretation of curvature — compactness and mass together determine how much light bends.
The beauty of this is that more mass or more density increase the bending.
I’m curious whether this formulation has been explored before, or if it might offer any new insights into gravitational lensing or curvature fields. Would love to hear your thoughts.
  • Sad
Unfortunately you're assuming Euclidean geometry, and the whole basis of general relativity is non-Euclidean geometry. Very few astrophysical objects have uniform density and a great many of them aren't spherical.
Also, the total mass of a compact object (or at least the mass times G) is easy to measure from orbits of nearby objects. The density and surface area may be unknown (and, indeed, the density of a black hole isn't a well defined concept). So I don't see that this is a more convenient form of the equations even in the kind of weak field approximation where it's valid.
Thanks for reply, and yes, it may have limited practical usage, but may be useable in corner cases.
The reason I dig into it is I gain understanding by studying ratios.
The deflection angle depends on the impact parameter of the light, not the radius of the gravitating mass.
Thanks,
In the specific case I was looking at — light just grazing the Sun — the impact parameter is equal to the Sun’s radius. So using r = R isn’t a mistake, it’s modeling the real-world situation that was actually measured during the 1919 eclipse.
What I found interesting is that the full general relativity result:
phi = 4GM / (rc²)
can be written as a simple energy ratio:
phi = (2 × gravitational potential energy) / (relativistic kinetic energy)
phi = (2GMm / r) / (½ mc²)
This gives the correct 1.75 arcseconds when r is the Sun’s radius.
There was a thread about this a couple of years ago. Someone was trying to justify (intuitively) why the GR approximation gave twice the hypothetical Newtonian calculation. You might be able to find the thread.
It was largely a waste of time, IMO.
Here it is:
One try?
When you integrate or derivate formulas factors appear, so my hypotesis is I think the factor 2 is a result of that. 2 / 1/2 = 4, which is the conatant that appears in the standard phi formula, 4GM / rc²
The constant 4 in (4GM / rc²) becomes 2 when you introduce 1/2 mc^2 in the denominator according to math rules.
  • Skeptical
But we are doing physics, and newtonian physics does not work in this context.
Ok, I will dig into that.So, what is the formulas replacing newton with something better?
General Relativity.
As PeroK says, you need to study general relativity. If you look for early tests of GR you'll find Eddington's measurement of the deflection of light grazing the Sun, which tested Einstein's predictions. The derivation of the deflection angle will be there.
Note that potential energy is of very limited use in GR. It can't be defined in anything but the simplest of circumstances.
PeroK said:
General Relativity.
So, the formula for the bending of light in general relativity is:
phi = 4GM / (rc²)
So that is the one I am using. Execpt some syntactic sugar where other letters are used, meaning the same. r vs b
So, then I can use math to adjust this formula.
phi = (4GM) / (rc²)
multiply by 1 -> (1/2m)/(1/2m):
phi = ((1/2m) 4GM) / ((1/2m)rc^2)
Rearranging and moving r up as denominator:
phi=(((1/2*4GMm/r) ) / (1/2mc^2)
And we have arrived on
phi= 2 * (GMm/r) / (1/2mc^2)
This is the exact same formula as we started on, so its still general relativity.
phi = 4GM / (rc²)
That's only an approximation (for small ##GM/rc^2##). Note that in some cases, Newtonian gravity is a close approximation to GR - orbits of the planets round the Sun, for example. In this case, it isn't even close. You want to make a big deal that the difference is almost exactly a factor of 2. That may just be a numerical coincidence.
What we can say is that Newtonian gravity cannot predict, even approximately, the quantitative bending of light round the Sun. The comparison between GR and Newtonian gravity in this case, therefore, has little or no value.
Ok, I am looking at the general and special relativity formulas now.
Don't look at the formulas, look at the whole story!
The formulas I have used are for weak field approximations. The thread is also tagged with gravity and newton. So, while special and general relativity is another liga, the weak field approximation predicts well enough for the bending of light near our own sun.
Newtonian gravity and the weak field approximation are different things. Newtonian gravity has the additional constraint that nothing is moving quickly, which rules out dealing with light.
That's why you have to add fiddle factors to your formulas to get the right answer - they aren't valid for the regime you want to study.
Ok, ok. You’re right that Newtonian gravity and the weak-field approximation in general relativity aren’t the same—and I appreciate the clarification.
I fully acknowledge that Newtonian gravity doesn’t handle light correctly—since it assumes particles with mass and low velocities.
TL;DR Summary: Title: Reframing Light Bending Using Density Instead of Radius
For a sphere:
Your formulation suggests that gravitational lensing depends on both the total mass (M^(2/3)) and local density (ρ^(1/3)) with different scaling laws. This implies that a 1000× increase in mass has a different effect than a 1000× increase in density. How do you reconcile this with the equivalence principle, which suggests that only the total enclosed mass within the light ray's closest approach should matter? Shouldn't two objects with identical M but different density distributions produce identical lensing at the same impact parameter?
You seem to be missing that he's only discussing grazing orbits, so his impact parameter varies with density if the total mass is held constant. That's why his result is only out by constant factors that follow from him using the wrong approxmation.
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 51 ·
  • · Replies 75 ·
  • · Replies 22 ·
