Regarding volume of an ellipsoid bounded by 2 planar cutting planes
The discussion focuses on calculating the volume of an ellipsoid bounded by two horizontal planes, specifically at z=0 and z=h. The volume of the ellipsoid is defined as \( \frac{4}{3} \pi abc \), while the area of the cutting plane is \( \pi ab \). The solution involves using elliptical-cylindrical coordinates, where the transformation is defined as \( x = ar \cos(\theta) \), \( y = br \sin(\theta) \), and \( z = cz' \). The integral for the volume is set up as \( \int_{h/c}^0 \int_{0}^{2\pi} \int abcr \,dr\,d\theta\,dz' \), requiring careful consideration of the limits of integration.
  • Understanding of ellipsoids and their equations, specifically \( \frac{x^2}{a^2} + \frac{y^2}{b^2} + \frac{z^2}{c^2} = 1 \)
  • Knowledge of integration techniques, particularly triple integrals
  • Familiarity with coordinate transformations, especially elliptical-cylindrical coordinates
  • Experience with Jacobian transformations in multivariable calculus
  • Study the derivation and application of elliptical-cylindrical coordinates in volume calculations
  • Learn about the Jacobian determinant and its role in changing variables during integration
  • Explore the properties and applications of triple integrals in various coordinate systems
  • Investigate the geometric interpretation of ellipsoids and their cross-sections
Mathematicians, physics students, and engineers involved in volume calculations of three-dimensional shapes, particularly those working with ellipsoids and integration techniques.
Corse
Hi I require to compute the volume of a ellipsoid that is bounded by two planes. The first horizontal (xy) plane is cutting directly along the mid-section of the ellipsoid. The second horizontal plane is at a z = h below the first horizontal plane. The volume of the ellipsoid between these two planes is the interest.
I understand that the volume of the ellipsoid is 4/3 ∏abc and the area of the cutting plane is ∏ab. However for this problem, I believe the use of integrals may be necessary.
From the problem statement, I realized that this can be reduced to a half-ellipsoid and the single horizontal cutting plane at z = h below the first cutting plane. In doing so it will just be a subtraction between 2/3 ∏abc and the volume not bounded by the 2 planes.
If a is the length of the major axis of the 2nd cutting plane in the x direction,
a = A x √(1-(h/C)²);
where A is the major axis of ellipsoid in X direction
C = Major axis of ellipsoid in Z direction
h = vertical distance in the z direction of 2nd plane (below 1st plane)
I'm not sure how should I continue from here though.
Help!
Thanks all for your input.
Regards
Corse
So your ellipsoid is given by
\frac{x^2}{a^2}+ \frac{y^2}{b^2}+ \frac{z^2}{c^2}= 1
and it is cut by z= 0 and z= h< 0?
At z= 0, the plane cuts the ellipsoid in the ellipse
\frac{x^2}{a^2}+ \frac{y^2}{b^2}= 1
and at z= h, the plane cuts the ellipsoid in the ellipse
\frac{x^2}{a^2}+ \frac{y^2}{b^2}= 1- \frac{h^2}{c^2}
I think I would be inclined to put this into "elliptical-cylindrical coordinates" taking
x= ar cos(\theta), y= br sin(\theta), and z= cz&#039;;
In those coordinates the equation of the ellipsoid becomes r^2+ z&#039;^2= 1, the upper elliptical boundary becomes r^2= 1 (r= 1 since r cannot be negative), and the lower elliptical boundary becomes r^2= 1- h^2.
Of course, you will also have to change the differential using the Jacobian:
\left|\begin{array}{ccc}\frac{\partial x}{\partial r} &amp; \frac{\partial x}{\partial \theta} &amp; \frac{\partial x}{\partial z&#039;} \\ \frac{\partial y}{\partial r} &amp; \frac{\partial y}{\partial \theta} &amp; \frac{\partial y}{\partial z&#039;} \\ \frac{\partial z}{\partial r} &amp; \frac{\partial z}{\partial \theta} &amp; \frac{\partial z}{\partial z&#039;}\end{array}\right|= \left|\begin{array}{ccc} a cos(\theta) &amp; -ar sin(\theta) &amp; 0 \\ b sin(\theta) &amp; br cos(\theta) &amp; 0 \\ 0 &amp; 0 &amp; c\end{array}\right|= abcr
so that dxdydz= abc r drd\theta dz&#039;
Then the integral from r= 0 to r= 1- h will be from z'= h up z'= 0 while the integral from r= 1- h to 1 will be from z&#039;= -\sqrt{1- r^2} up to z&#039;= 0.
Hi HallsofIvy
Thank you for your quick response! That was helpful to get me going. I understand the jacobian transformation from the cartesian to the elliptical-cylindrical space.
I have a couple of questions:
1) Elliptical-cylindrical coordinates was used where x=arcos(θ), y=brsin(θ), and z=cz′;
May I know why were the coefficients of a,b and c in the elliptical coordinates?
2) You mentioned that the integral from r= 0 to r= 1- h will be from z'= h up z'= 0 .
So for my case, I would be interested in r=0 to r = 1-h; I'm assuming this fact would be crucial in evaluating the triple integral to obtain the volume. Which integration limits would this correspond to?
Could you advise regarding the limits of integration if they are correct?
Volume = \int_{h/c}^0 \int_{0}^{2∏} \int abcr \,dr\,dΘ\,dz&#039;
Would it be necessary to obtain the traces of rΘ, rz' and Θz' to get the limits of integration?
Corse said:
Hi HallsofIvy
\frac{x}{a}= r cos(\theta), \frac{y}{a}= r sin(\theta) and \frac{z}{c}= z&#039; so that
\frac{x^2}{a^2}+ \frac{y^2}{b^2}+ \frac{z^2}{c^2}= r^2 cos^2(\theta)+ r^2 sin^(\theta)+ z&#039;^2= r^2+ z&#039;^2= 1
The equation of a sphere in cylindrical coordinates.
I said that r goes from 0 to 1- h. So the integral will be
\int_{z&#039;= h}^0\int_{r= 0}^{1- h}\int_{\theta= 0}^{2\pi} abcr d\theta dr dz&#039;
Hi HallsofIvy
1) May I know how did you get limits for r to be r = 0 to 1-h? Especially for the part r = 1-h
2) For z', should the bottom limits be -h instead of h?
3) Also, does converting the problem to cylindrical coordinates make it more convenient to solve? Could it be done in a similar fashion in cartesian coordinates?
Thank you for helping me out!
Regards
Corse
  • · Replies 41 ·
15K
