Regular Values (Introduction to Smooth Manifolds)
8 replies · 3K views · last reply
BrainHurts
Consider the map [itex]\Phi[/itex] : ℝ4 [itex]\rightarrow[/itex] ℝ2
defined by [itex]\Phi[/itex] (x,y,s,t)=(x2+y, yx2+y2+s2+t2+y)
show that (0,1) is a regular value of [itex]\Phi[/itex] and that the level set [itex]\Phi^{-1}[/itex] is diffeomorphic to S2 (unit sphere)
So I have the Jacobian
D[itex]\Phi[/itex] = [2x 2y 0 0; 2x 2y+1 2s 2t]
the reduced row echelon form of D[itex]\Phi[/itex] is a rank 2 matrix which implies that F is a smooth submersion.
So I guess I'm a little confused on the definition: Let M and N be smooth manifolds
If F:M→N is smooth and let p [itex]\in[/itex] M, then p is a regular point if D[itex]\Phi[/itex] at p is onto.
D[itex]\Phi[/itex] is a rank 2 matrix which implies that D[itex]\Phi[/itex] is onto right?
Another question that I have is that the pre-image of (0,1) under [itex]\Phi[/itex] is a subset of ℝ4 any hints on the diffeomorphism part?
I don't get the same Jacobian
But ##D\Phi## is not a matrix at all. You should evaluate it in different points. You should ask for which ##(x,y,s,t)## that ##D\Phi_{(x,y,s,t)}## is surjective. This is not true for all ##(x,y,s,t)##. For example ##(0,0,0,0)##.
Shoot!
[itex]\Phi[/itex](x,y,s,t) = (x2+y, x2+y2+s2+t2+y)
D[itex]\Phi[/itex] = [2x 1 0 0; 2x 2y+1 2s 2t]
How is D[itex]\Phi[/itex] not a matrix? I'm confused on that?
I'm going to switch notation up a bit
If we have a smooth map F: M → N and let p [itex]\in[/itex] M, then p is a regular point if
TpF is onto. In this case TpF is the total derivative which we used D[itex]\Phi[/itex].
TpF : TpM → TF(p)N
However I do see your point about D[itex]\Phi[/itex](0,0,0,0), we would have a rank 1 matrix in that case.
BrainHurts said:
Shoot!
I still don't agree.
It's not a matrix in the sense that it depends on specific values of ##(x,y,s,t)##. If you're given specific values, then it is a matrix.
TpF : TpM → TF(p)N
Can you classify all points such that ##D\Phi_{(x,y,s,t)}## is surjective?
BrainHurts said:
sorry my equation was wrong
OK, I agree with the Jacobian now. But please don't edit any posts after you already received a reply. Just reply with the correct equation.
So, can you now figure out for which ##(x,y,s,t)## that your Jacobian has rank 2?
First sorry about that reply thing, I realized that once I made the edit, thought about re-editing so that I made my mistake, but then that's just too many re-edits, in any case I won't make that mistake again!
so the point (0,1), the pre-image of (0,1) under [itex]\Phi[/itex] is a subset of ℝ4
so we will look at the specific case:
(x2+y,x2+y2+s2+t2+y) = (0,1)
this means that
x2+y = 0
and that x2+y2+s2+t2+y = 1
this reduces the second component to
y2+s2+t2 = 1 (which is nice sine S2 : y2+s2+t2)
[itex]\Phi^{-1}[/itex](0,1) = {(x,y,s,t)|(x2+y=0 and y2+s2+t2 = 1}
so for all (a,b,c,d) [itex]\in[/itex] [itex]\Phi^{-1}[/itex](0,1)
we have D[itex]\Phi[/itex](a,-a2,c,d) is a rank 2 matrix
I think that's good now right?
this means that
x2+y = 0
If it's clear to you why ##D\Phi(a,-a^2,c,d)## has rank 2, then it's good.
for all p [itex]\in[/itex] [itex]\Phi^{-1}[/itex](0,1), p is a regular point, and it follows that (0,1) is a regular value. Thanks so much! That really helped a lot. I think I have the second part.
