Relationship between potential and induced emf?
3 replies · 6K views
Yoriko
[PLAIN]http://img220.imageshack.us/img220/2589/44045733.png
Semicircular wire MN of diameter L moves with speed v perpendicularly through a uniform magnetic field of strength B.
1. Find the magnitude of the induced emf generated between M and N.
2. State whether M or N is at a higher potential.
E = BLv
1. Given answer: Induced emf = BLv
However, I was wondering if you can use that equation even if it's not a closed circuit?
In the semicircular wire, there shouldn't be magnetic flux linkage. And even if there was, there is no change in magnetic flux linkage.
2. N is at a higher potential
There is opposing force that resists the motion of the wire (:confused: is this reason correct?), which, by Fleming's left hand rule, results in an induced current (if the circuit were to be closed) flowing from M to N. Thus, N is at higher potential as a result of the induced "current".
However, I know that current flows from higher potential to lower potential. So is it right to say that in the case of an induced current, if it flows from M to N, N is at a higher potential?
Sure, you can, you have to.
Just be careful what "length" is.
If it was a closed circuit of zero resistance, there would be no voltage at all.
V=RI, R=0, so V=0 (for closed loops of zero resistance)
Pay attention to the charge sign.
No there's no opposing force.
Then how is there an induced emf?
[PLAIN]http://img207.imageshack.us/img207/5853/93128344.png
Do you take "Force" to be in direction of the velocity?
i know the thread is old but i have a question
what shall we take as a length to calculate E, the length πr of the arc or the length 2r of the line segment and why?
thanks a lot
