Relative Velocity of Bolt in Elevator
5 replies · 3K views
Toranc3
An elevator is moving upward at a constant speed of 2.50 m/s. A bolt in the elevator ceiling 3.00m above the elevator floor works loose and falls.
A. How long will it take the bolt to fall to the elevator floor?
I am not sure if I should do this relative to elevator or earth.
Vb/g=Vb/e+Ve/g
Yb/g=Yb/e+Ye/g
3.The attempt at a solution
Vb/g=Vb/e+Ve/g
Vb/g= velocity of bolt relative to ground
Vb/e= velocity of bolt relative to earth
Ve/g= velocity of elevator relative to ground
Yb/g=Yb/e+Ye/g
Yb/g=position of bolt relative to ground
Yb/e= position of bolt relative to earth
Ye/g=position of elevator relative to ground
Vb/g=Vb/e+Ve/g
Vb/g=0+2.5m/s
Yb/g=Yb/e+Ye/g
Yb/g=3m+ 2.5m/s*t
Is this right so far? Where do I go from here? Thanks!
You can make this question much easier by recognising that since the elevator is moving at constant speed it constitutes an inertial frame.
Can you clarify what you mean? :/
Take the elevator as the reference frame. What are the initial height, initial velocity, final height and acceleration of the bolt in that frame?
3m, 0m/s, 0m, -9.81m/s^(2)?
I think I see what you mean. What if the elevator was not traveling at a constant speed but rather a constant acceleration. How would that change?
He means that the laws of physics are the same in every inertial reference frame. You can think of an inertial frame as a frame that is not accelerating (that is, one that is moving at constant speed relative to another inertial frame). It's a little more complicated than that, but you can ignore those complications for present purposes.
