Relative velocity=relative momentum?
  • Context: Graduate
  • Thread starter Thread starter h1a8
    Momentum Relative
The discussion centers on the momentum transfer of photons to a solar sail traveling at 0.866c, as analyzed through the lens of special relativity. It concludes that while photons always travel at the speed of light (c) in all reference frames, the momentum imparted to the sail is affected by the relativistic Doppler effect. Specifically, the momentum received by the sail moving at 0.866c is approximately one-fourth of that measured by an observer at rest relative to the radiation source. This demonstrates that relative velocity significantly influences momentum transfer in relativistic contexts.
  • Understanding of special relativity principles
  • Knowledge of momentum and energy transfer in physics
  • Familiarity with the relativistic Doppler effect
  • Basic concepts of photon behavior and light speed
  • Study the implications of the relativistic Doppler effect on momentum transfer
  • Explore the mathematical formulation of momentum in special relativity
  • Investigate the behavior of solar sails in different velocity regimes
  • Learn about the applications of special relativity in astrophysics
Physicists, aerospace engineers, and students of relativity interested in the dynamics of momentum transfer in high-speed scenarios.
h1a8
Assume a solar sail was traveling at a high speed (say .866c) away from the radiation source. The radiation hitting it is of course traveling at c. But according to the special theory of relativity it would appear on the sail that the radiation is hitting the sail at c speed (since the speed of light is constant in all reference frames). Thus would a photon supply the same momentum push when the sail is traveling away from the source at .866c as it would if the sail was merely at rest (or with a much lower speed) relative to the source?
No, momentum changes due to the relativistic Doppler effect. In your example, it would be ~1/4 of the momentum measured by an observer at rest wrt the source.
  • · Replies 32 ·
  • · Replies 18 ·
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 57 ·
  • · Replies 32 ·
