Calculating Photon Frequency From Relativistic Decay: Homework Solution
The discussion centers on calculating the frequency of a photon emitted from a high-energy particle undergoing relativistic decay. The participant initially applies conservation of energy and momentum principles, using equations such as E' = γ(E - vp) and E' = hc/λ to derive the frequency. The conversation reveals confusion regarding the conservation of momentum in single-particle decay, with clarification that the mass of the original particle is irrelevant to the frequency calculation. Ultimately, the energy transformation aligns with the relativistic Doppler effect, confirming that the observed frequency is greater than the emitted frequency.
  • Understanding of relativistic energy and momentum conservation
  • Familiarity with the Doppler effect in physics
  • Knowledge of Lorentz transformations and the gamma factor (γ)
  • Basic principles of photon energy and frequency relationships (E = hf)
  • Study the derivation of the relativistic Doppler effect formula
  • Explore conservation laws in particle physics, focusing on decay processes
  • Investigate Lorentz transformations and their applications in high-energy physics
  • Review photon energy calculations and their implications in quantum mechanics
Students and educators in physics, particularly those focusing on particle physics, relativistic mechanics, and quantum theory. This discussion is beneficial for anyone seeking to deepen their understanding of photon behavior in relativistic contexts.
Physgeek64
Hi- I've been doing some questions and came across the following
A high energy particle, traveling towards an observer with velocity v decays to produce a photon with
energy E in the rest frame of the particle.
Find the frequency at which this photon would be detected by the observer
so initially i tried:
conservation of energy in particles frame: mc^2=E
then transformed this into the lab frame
E'=gamma(E-vp)
E'=Esqrt((1-v/c)/1+v/c))
and then used E'=hc/lambda to get f=E/hcsqrt((1-v/c)/1+v/c))
but then here is my problem- surely the decay of a single particle into a single photon violates the conservation of momentum as in the particles frame it initially has momentum 0, but after the decay it has momentum E/c? I may be wrong, but I'm just slightly confused. Thanks :)
Are you sure the particle doesn't decay into two photons? By conservation of momentum a single particle cannot decay into a single particle with a different mass.
This is my problem... but that is the exact question
It could decay into another unspecified particle and a photon. It doesn't say only a photon!
But surely the frequency of the photon would depend entirely on the mass of the other particle, so it would be odd not to mention it?
It gives you the energy of the photon. The mass of the original particle and the details of the decay are irrelevant.
ahh okay- so with the exception of my 'conservation of energy' line, my above answer should hold?
E'=gamma(E-vp)
E'=Esqrt((1-v/c)/1+v/c))and then used E'=hc/lambda to get f=E/hcsqrt((1-v/c)/1+v/c))
Are you sure that's right? What would Mr Doppler have to say?
Also, there's no need to introduce ##\lambda## as ##E' = hf_{obs}##
I did initially think that, but the expression I've obtained is already that of the doppler shift? Or is that just a coincidence?
Oh yeah- silly me
Oh yeah- silly me
It's no coincidence. The energy transformation for a photon leads to the relativistic Doppler formula. Is the energy/frequency of the observed photon (in your answer) greater than or less than the emitted photon? What should it be?
It should be greater, so the other way round. I've probably made an algebraic mistake somewhere. But thank you! that's really helpful :)
  • · Replies 19 ·
