Calc Time for Electron to Travel 100m in Lab Frame
  • Thread starter Thread starter i_hate_math
    Relativity
The discussion centers on calculating the time it takes for an electron moving at 0.98c to travel 100 meters in the lab frame. The correct answer is 0.34 microseconds for both the electron's frame and the lab frame, which raises questions about the calculations. Participants debate the use of Lorentz transformations and length contraction, with some expressing confusion over the interpretation of the question. It is clarified that while the time intervals differ between frames, the calculations should yield consistent results when properly applied. Ultimately, the discussion emphasizes the importance of understanding reference frames in special relativity.
i_hate_math
This is an extract of a very long question. The electron is moving relative to the lab at 0.98c.
In the reference frame of the electrons, calculate the time required for an electron to travel the length of a beam pipe which has a proper length of 100 m measured in the laboratory reference frame.
t'=y(t-vx/c^2) where y=1/(1-v^2/c^2)=6 in this case
The correct answer is 0.34microsecond, strangely it is, the time interval observed by a person in the lab's reference frame is also ∂t=L0/0.98c=0.34microsecond. Can someone explain to me why this is?
How did you get that the correct answer is 0.34 microseconds for the time in the electron's frame? I do not get that.
That isn't my answer. It says 0.34microsec on the solutionsheet, but i got different value. It could be that the solution sheet contain errors. Did u use L=L0*(1-v^2/c^2) and then divide L by 0.98c?
That is one way of doing it. The other is to use the transformation from ##t## to ##t'## directly. They should produce the same answer. Note, by the way, that you're writing your Lorentz factor incorrectly. The correct equation is $$\gamma = \frac{1}{\sqrt{1 - \frac{v^2}{c^2}}}$$ but you left out the square root. Aside from that, what answer did you get?
Likes i_hate_math
I got 1.96 microsecond from the transformation equation, and 0.067microsec using L/0.98c
Also, its -1.96 a negative value that i got.
Could you show the steps so I can follow your calculations?
For reference, your length contraction approach is correct, so you're likely just making a small mistake using the transformation equation.
Likes i_hate_math
t'=y(t-vx/c^2)
and t=100/0.98c
this gives t'=6(100/0.98c-0.98*100/c)=0.067686 microsec
(looks like i made a mistake while doing the calculation and got -1.96)
the other way to do it
L=L0*lorentz facter=502.5189...
t=L/0.98c=0.067686 microsec
Now I'm fairly confident that his is the correct solution.
Likes axmls
Thanks heaps for the help!
Likes axmls
I don't know if this is right, but it gets the quoted solution...
So length, as measured by electron:
##l'=\frac{l}{\gamma}=100 \sqrt{1-0.98^2}= 19.899... m ##
So the time to traverse the length of the rod ## t= \frac{l'}{v}=\frac{19.899...}{0.98c}= 6.7686... 10^{-8} s##
But then you were asked of the time as measured in the lab frame. Since all moving clocks run slow, this time must be time dilated to convert back to the lab frame:
##t_{lab}= \gamma t= \gamma (6.7686... 10^{-8})= 3.401... 10^{-7} s ## which was the answer required.
However, this comes with no guarantee- I too am learning special rel. this year :)
Yeah your calculations would be correct if the question were asking for the time interval in the lab's reference frame.
The question is a bit confusing i must say. Perhaps the guy wrote the solution didn't realize that it is the electron's reference frame that the question concerns.
I feel like that's what the question wanted- For you to show that you can work in either fame and the time should be invariant for any given frame (i.e. that the transforms are consistent). That was how I interpreted the question. I feel like this is where punctuation is important had he put a comma such that it read
i_hate_math said:
In the reference frame of the electrons, calculate the time required for an electron to travel the length of a beam pipe, which has a proper length of 100 m, measured in the laboratory reference frame.
Then you would have to interpret it in the way I have. However, without this the question is sort of left to interpretation. Write down both, and then it's unambiguous that you knew what you were doing ;)
The transit time for the electron (i.e. in the electron's frame) will differ from that of the lab frame. This is due to two equivalent interpretations: 1. the distance the electron must travel is length contracted in its frame, so it has less distance to travel in its frame, or 2. time itself is slowed down in the electron's frame relative to the lab frame. Either way, the electron will experience some passage of time for the duration of the transit, and the lab will measure some time for the duration of the electron's transit. These two times will differ. So no, the time is not invariant between frames.
No, as in the calculations should be invariant. If you work out the time in the lab frame this must be identical to the time that is calculated if you worked in the electron frame and then transformed back to the lab frame. This may not have been clear from my wording- but when accompanied with my working it is very clear that this is what I meant..
  • · Replies 30 ·
  • · Replies 32 ·
