Relativity question, photon and proton
4 replies · 2K views · last reply
Prodigium
Relativity question, photon and proton...
Proton of gamma factor 10^12 and a photon set off from one side of our galaxy to the other take the distance to be 9.3x10^20m.
What is the time interval that the photon precedes the proton?
\gamma = sqrt(c/2epsilon). (epsilon being c-v)
Worked out epsilon to be 1.5x10^(-18)Not sure where to go from there anyhelp/hints would be most appreciated.
You should try to form ratios that are dimensionless. In this case, you could write
[tex]v = c - \Delta v = c\left(1 - \frac{\delta v}{c}\right) = c(1-\varepsilon)[/tex]where [itex]\varepsilon = \Delta v/c[/itex]. Why? Because it avoids any complication due to units, for one thing. Regardless of which set of units you use, [itex]\varepsilon[/itex] defined this way will always turn out to have the same value. Moreover, an expression is often more naturally expressed in terms of these unitless ratios.
You can show that
[tex]\gamma = \frac{1}{\sqrt{1-(v/c)^2}} = \frac{1}{\sqrt{1-(1-\varepsilon)^2}} \cong \frac{1}{\sqrt{2\varepsilon}}[/tex]
Now write down expressions for the time each takes to travel the given distance.
[itex]\Delta t = \frac{(1- \epsilon )x-x}{c (1- \epsilon) }[/itex]
after putting [itex]t_1 = \frac{x}{c}[/itex] and [itex]t_2 = \frac{x}{c(1- \epsilon )}[/itex], then to find [itex]\Delta t = t_1 - t_2[/itex]
but I can't seem to get it , did I do this correctly?
Because ε is so small, you can approximate t2 well with a series expansion to first order.
so [itex]t_2= \frac{x}{c} \cdot (1- \epsilon )^{-1} = \frac{x}{c} \cdot (1)[/itex]
or, because that completely gets rid of [itex]\epsilon[/itex] :-
[itex]t_2= \frac{x}{c} \cdot (1- \epsilon )^{-1} = \frac{x}{c} \cdot (1+ \epsilon )[/itex]
That after finding [itex]\Delta t[/itex] gave me and answer of [itex]-1.55 \cdot 10^{-12} s[/itex]
only problem is you have to find the time as being in the reference frame of the proton later and need [itex]t_2[/itex].
