Relativity, time, and quantum mechanics
  • Level: Undergrad
  • Thread starter anuttarasammyak
47 replies · 9K views · last reply
Cosmic-ray muons correspond to wave packets in free space, and their lifetime extension can be explained by the Lorentz factor. Muons in a circular accelerator are wave packets governed by a Hamiltonian that includes the electromagnetic potential, and strictly speaking they should not have a definite velocity; however, in practice, a Lorentz factor based on velocity is often applied successfully.
anuttarasammyak said:
Different momentum components have slightly different velocities
On what basis are you making this claim? The "different momentum components" are not observables; they are just a convenient basis in the Hilbert space. So I don't see how they correspond to velocities; there are no velocity operators corresponding to them.
So even in free space QM tells us nothing about velocity ?
If we take the math strictly at face value, which means ruthlessly resisting the temptation to indulge even very plausible interpretational claims: ##p## is an observable so ##p/m## is also an observable that we might reasonably call velocity. And if we're considering non-relativistic QM (not applicable to the questions that started this thread) ##x## is an observable with expectation value ##<x>## so we might reasonably call ##\frac{d<x>(t)}{dt}## the expectation value of the velocity.
In practice it's easier to treat a free particle classically unless and until there is some interaction with some non-zero potential in which quantum effects are relevant.
Nugatory said:
x is an observable with expectation value <x> so we might reasonably call d<x>(t)dt the expectation value of the velocity.
Thank you. Re:#30 Can we call ##\frac{<p>}{m}##, relativistically ##<\frac{pc^2}{E}>, ## as well as ##\frac{d}{dt}<x>(t)## the expectation value of the velocity which can be used for getting Lorentz factor ?
I would greatly appreciate it if you experts could provide a rough sketch of how quantum field theory explains this phenomenon. As a layperson, I find it difficult to grasp the physical meaning behind terms such as annihilation and creation operators, probability amplitudes, and so on, rather than just the mathematical formalism.
I have read that in relativistic quantum theory the decay rate is computed from the weak-interaction matrix element using the bound-state wavefunction:
$$\Gamma_{bound}=<\psi_{1s}|\hat{\Gamma}|\psi_{1s}>$$
The momentum distribution of the bound muon plays an important role.
The decay width is a Lorentz-invariant quantity derived within quantum field theory.
I understand only part of this, but I have the impression that an explanation based on the Lorentz factor is not necessary in this context. Looking back at #28, it seems that p plays a role in Γ in QFT, while v plays a role in τ in classical relativity; they appear to offer complementary perspectives though the latter is not correct now I know.
Of course not. You’re trying to apply non-relativistic quantum mechanics to a problem in which relativistic effects matter.
Am I correct in understanding that both ⟨v⟩ = ⟨p⟩/m and ⟨v⟩ = d⟨x⟩/dt are valid in the non-relativistic regime for a free particle?
If yes, I thought ##<v>=c<\frac{pc}{\sqrt{p^2c^2+m^2c^4}}>## is an improved rlativistic version of ##<v>=\frac{p}{m}##.
This is a follow-up to my post #27 (which so far has not received any specific comments), in which I drew from the 1982 Silverman reference on muonic atoms to promote the idea that bound quantum particles can be usefully characterized by both velocity and time dilation. First, I quote some thread-responses that push back against that notion:
Nugatory said:
...the electron has no path or position so the notion “the proper time of an electron” is meaningless.
The “rest frame of the electron” never enters into the calculation (unsurprisingly, because it’s not defined).
No position means no path along which we can integrate to find the proper time. Instead we use QFT and calculate an amplitude for a decay event at various points in spacetime - "experiences time dilation" is not how I would describe that model.
You have a calculated a quantity that has the dimensions of distance over time, and you can interpret it as a speed (it's an interpretation because it is not observable even in principle and because there's no position that is changing with time) if that interpretation is helpful.
But it's a stretch to get from there to the proposition that a bound particle "experiences time dilation" (what could that phrase possibly mean?
PeterDonis said:
But the state of an electron (or muon, for that matter) in a bound hydrogen atom is not classical even in approximation. So you can't just assume that the expectation value of ##\mathbf{V}##, which is what appears in the quantum virial theorem, has a valid physical interpretation as the "speed" of the electron (or muon).
In response to these comments, I present a 2000 paper by Czarnecki et al. that models the decay of the bound-state of ##\mu^+## and ##e^-##: Muonium Decay. (Compared to a muonic atom, muonium is a "cleaner" system to analyze since it's composed entirely of point leptons that interact via the Coulomb potential only. Indeed, observations of muonium are used to both set the parameters and test the limits of the Standard Model.) Czarnecki et al. summarize the intent of their work:
Text excerpt from a physics paper: "Given its potential importance, we have reexamined the muonium bound state effect on the muon lifetime" with the phrase "bound state effect on the muon lifetime" underlined in red, followed by "the leading correction turns out to be remarkably small, α²m_e²/2m_μ² ≃ 6 × 10⁻¹⁰ and easy to calculate."
(Here I underline content that's germane to the debate in this thread.) The authors employ both the Bethe-Salpeter equation and non-relativistic QED in their analysis, concentrating on the ground-state configuration:
Excerpt from a physics paper on muonium decay with phrases underlined in red, including "equal but opposite momenta and r.m.s. velocities", "muon's r.m.s. bound state velocity", "muon's non-zero velocity", "ground state velocity" and "dilation".
and later write:
Excerpt from a physics paper on muon decay: text on Lorentz invariance and time dilation factor gamma, Eqs. (10) to (12) for the decay rate and lifetime ratio, and a note on bound state velocity effects.
The authors go on to compare their results to those for muonic atoms:
Excerpt of physics paper text stating that Überall found the leading bound state effect was time dilation reducing the muonic atom decay rate, with equation gamma inverse = sqrt(1 - Z^2 alpha^2), approximately 1 - (1/2) Z^2 alpha^2, for Z^2 alpha^2 much less than 1 (16).
This and the Silverman reference provide ample evidence that at least some working physicists embrace the concept that velocity and time-dilation do indeed apply to quantum particles bound in stationary states, and so in my view, the debate is settled. Nonetheless, I welcome citations to literature that supports the contrary position of @Nugatory and @PeterDonis.
Nugatory said:
The global collapse interpretation you are trying to use here is non-relativistic so cannot be applicable here. Instead we have to use the methods of quantum field theory, in which there is no global collapse.
Quantum field theory treats the decoherence between the system and the measuring apparatus, but does it not fail to account for the collapse—that is, the experience of obtaining a single definite outcome from among the possible alternatives?
Moreover, it seems difficult to return from this single experienced outcome to the decohered state, that is, to recover reversibility.
Nugatory said:
How should the Lorentz factor be applied to motion that is not classical?
We don’t. Proper time is the length of a path through spacetime between two events; the electron has no path or position so the notion “the proper time of an electron” is meaningless. Instead we work with the time measured by our lab clock between observation events.
[/QUOTE]
In this thread, I have come to understand that one cannot meaningfully define the proper time of the electron in the 1s state of the hydrogen atom.
As something close to the rest frame of the electron, one may consider the inertial frame in which the hydrogen atom is at rest, i.e., ⟨p⟩ = 0. However, the electron is not at rest in that frame; rather, it undergoes “quantum motion,” for which ⟨p²⟩ provides a certain measure.
Furthermore, even for a free particle, if we take a Gaussian wave packet, then even in the inertial frame where ⟨p⟩ = 0, we still have ⟨p²⟩ ≠ 0 and the wave packet spreads in time. This raises the question of whether such a frame can truly be regarded as the rest frame of the electron. One might instead think of the state as a superposition of momentum components, each with its own rest frame and hence its own proper time.
If the very notion of a rest frame for a physical object becomes ambiguous, then its proper time also becomes ambiguous. Does this mean that the relativistic statement, “The proper time of an object is the time measured by a clock carried by that object,” belongs to the domain of classical mechanics and does not straightforwardly apply to quantum objects as small as an electron?
Suppose that, in a given inertial frame, we measure the position of an electron at two different times. Let the spacetime interval between the two measurement events be s. If s=ct, then there exists an inertial frame in which the two events occur at the same spatial point; we may define the time measured in that frame as the proper time.
In this way, rather than treating proper time as something intrinsic to the electron itself, may we instead regard it as something intrinsic to the pair of events—that is, define proper time in an event-based sense rather than a particle-based one? If so, it would seem that we could meaningfully discuss proper time even within quantum mechanics.
What pair of events? There aren't any well-defined events in the case under discussion, any more than there is a well-defined worldline for the electron.
The pair of events I would refer is
I should have stated clearly that measured space coordinate values of the electron are used to calculate s. I do not think that we need a world line of the electron in this discussion.
Irrelevant if you are trying to analyze the bound state of an electron in a hydrogen atom. The first position measurement will ionize the atom, because, as you can easily work out by running the uncertainty principle numbers, pinning down the electron's position to within the size of the hydrogen atom will introduce more than enough momentum uncertainty to exceed the ionization energy. So the second measurement will not be measuring the electron's position within the atom again; it will be measuring the position of a free electron.
If the goal is to learn about the 1s state of the electron, then you are of course correct that performing two position measurements separated in time would destroy the 1s bound state and thus fail to achieve that purpose. Even if one were to determine a proper time using the method I mentioned, it would be a value unrelated to the 1s state itself.
My point in the previous comment was that, if we take the spacetime interval s between these two events and divide it by c, we obtain a IFR which has proper time τ as its time. In this sense, it seems that τ can be defined even in quantum mechanics, regardless of whether the electron “experiences” τ (that is, regardless of whether it carries a clock that ticks accordingly).
Furthermore, if we consider the path integral between these two events, each path has phase factor
##e^{i\frac{S[\phi]}{\hbar}}## where ##S[\phi]## is action along the path ##\phi##. One might then be tempted to regard the phase as being related to the proper time and to say that each path has its own proper time ##\frac{S[\phi]}{\hbar}##.
  • Sad
Which, as you've admitted, fail to achieve the purpose. So I don't understand why you are even talking about it.
No, because ##\tau## is a worldline parameter, and you don't have a worldline.
As has already been said in this thread, you can't mix relativity and QM this way. Please stop trying. You're getting to the point where you're going to receive a warning if you keep it up.
The path integral of what? What are we even talking about? You haven't even written down a Lagrangian. And again, if you're going to try to do this relativistically, you'll be doing QFT--which doesn't work the way you are trying to make things work.
This is getting you even closer to a warning. Please stop posting along these lines and take some time to learn how QFT actually works.
This thread has reached and passed the point of diminishing returns and will remain closed.
