How to Derive the Angle Transformation of a Stationary Rod in Relativity?
  • Thread starter Thread starter latentcorpse
    Relativity Rod
The discussion focuses on deriving the angle transformation of a stationary rod in the context of special relativity. It establishes that the relationship between the angles observed in two different frames, S and S', is given by the equation tan(φ') = (1/γ) tan(φ), where γ is the Lorentz factor. The transformation involves applying the Lorentz transformation to the coordinates of the rod's endpoints, leading to the conclusion that the lengths in the x and y directions are affected differently due to relativistic effects. The key insight is that the angle in the moving frame is derived from the differences in coordinates of the rod's endpoints.
  • Understanding of special relativity principles, including Lorentz transformations
  • Familiarity with trigonometric functions and their applications in geometry
  • Knowledge of the Lorentz factor (γ) and its calculation
  • Basic understanding of coordinate systems in physics
  • Study the derivation of the Lorentz transformation equations in detail
  • Explore the implications of relativistic length contraction on various physical systems
  • Learn about the concept of simultaneity in different reference frames
  • Investigate the application of trigonometric identities in relativistic physics problems
Students of physics, particularly those studying special relativity, educators teaching relativity concepts, and researchers exploring relativistic effects in various physical scenarios.
latentcorpse
An observer in S' sees a stationary rod lying in the x'-y' plane and making an angle \phi' with the x' axis. Show that
\tan{\phi'}=\frac{1}{\gamma} \tan{\phi}
where \phi is the angle the rod makes with the x-axis according to an observer in S.
so far I have \tan{\phi'} = \frac{y'}{x'}=\frac{y}{\gamma(x-vt)}=\frac{1}{\gamma} \frac{y}{x-vt}
if i could just get rid of that vt, i'd be there but i can't seem to get it to go away...
I assume the rod is moving in the x direction. In the S frame, let the length in the x direction be Lx and it's length in the y direction be Ly. In the S' frame, the length in the y direction will be the same i.e. L'y = Ly, and the length in the x direction will be shorter by a factor of √(1 - v²), i.e. L'x = √(1 - v²) Lx. So we get
tan θ = Ly / Lx
tan θ' = L'y / L'x = Ly/Lx√(1 - v²)
Your mistake was that you took tan θ to be y/x. If the coordinates of the tips of the rod are (x1, y1) and (x2, y2), then tan θ will be ∆y/∆x where ∆x = x2 - x1 and ∆y = y2 - y1. You should apply the Lorentz transform to both (x1, y1) and (x2, y2) to obtain ∆x' and ∆y'. tan θ' will then be ∆y'/∆x'.
  • · Replies 20 ·
