Reliability of Upper/lower yield point in tensile test.
The discussion centers on the reliability of the upper and lower yield points in tensile testing, specifically for mild steel. The lower yield point is deemed more reliable as it reflects the material's true properties, while the upper yield point is influenced by experimental apparatus settings. The phenomenon is attributed to the molecular structure of mild steel, which initially exhibits a higher yield point that quickly stabilizes to a lower value as strain increases. This makes the lower yield point a more conservative choice for engineering applications.
  • Understanding of tensile testing principles
  • Familiarity with stress-strain diagrams
  • Knowledge of material properties, specifically mild steel
  • Awareness of experimental apparatus and its influence on results
  • Research the molecular structure of mild steel and its impact on yield points
  • Study the differences between upper and lower yield points in various materials
  • Explore best practices for conducting tensile tests to minimize experimental error
  • Learn about engineering applications that utilize lower yield points for safety and reliability
Materials scientists, mechanical engineers, and quality control professionals involved in tensile testing and material property analysis.
Ravi Singh choudhary
Some metal give two yield point in stress strain diagram. One is called Upper yield point and Lower yield point. Why lower yield point is considered as more reliable. I can think of Upper yield point is much more dependent upon experimental apparatus settings. So why lower yield point is much more reliable as considered as actual material property of metal.
The 2 yields are not due to experimental error, rather, it is due to the molecular structure of the material (mild steel in particular) which exhibits an initial upper yield value over a small range of time under load, which quickly lowers and flattens to the lower value with increasing strain. More reliable to use the lower value over the wider range of strain, but also, more conservative for engineering.
