Remote Control Magnet Force: Possible?
  • Topic: Electronics
  • Thread starter ChBhHu
    Magnet
7 replies · 3K views · last reply
ChBhHu
is it possible to create a remote that can control the force acting on a magnet? for example is, to stop one magnet from attracting or repulsing other metals. or making a magnet adjust the force it apply to other object.
Or do you mean how to switch a permanent magnet on and off? This is a magnetic base for dial indicators:
Magnetic base for a dial indicator: a black textured cube with a grey side panel and a black switch lever, with a steel post and clamp arm rising from its top.
The lever switches the permanent magnet base on and off. And this is a magnetic chuck used in machine tools:
Rectangular magnetic chuck with a steel top plate, brass strips along the edges, a black handle lever on the left end, and a Magnetic Chuck nameplate with CE and EMC marks.
It also has a lever to switch the magnets on and off.
In both cases, the lever rotates an internal permanent magnet so that the base/table surface is either magnetized or not magnetized.
thank you, then what is the proper way in raising or lowering the amount of force that a magnet exert?
ChBhHu said:
is it possible to increase the range of force that a magnet has? for example is typical magnet used inside a speaker. if it is can what is the best way to do it?
To increase the range of force, you have to increase the magnetism. That should be doable with an electromagnet.
  • Wow
If it was both easy and needed, it was done long ago.
The method used will depend on what are you trying to achieve.
You need to explain; why do you need a stronger or a variable magnet?
  • Wow
