Representing a Function as Laurent Series: Example
12 replies · 3K views
Petar Mali
How to represent function
[tex]\frac{1}{e^x-x-1}[/tex]
in form of Laurent series around point [tex]0[/tex]
Laurent series
[tex]f(z)=\sum^{\infty}_{n=-\infty}a_n(z-z_0)^n[/tex]
Here is [tex]z_0=0[/tex]
Computer gives
[tex]\frac{2}{x^2}-\frac{2}{3 x}+\frac{1}{18}+\frac{x}{270}-\frac{x^2}{3240}-\frac{x^3}{13608}-\frac{x^4}{2041200}+\frac{x^5}{874800}+\frac{13 x^6}{146966400}-\frac{307 x^7}{24249456000}-\frac{479 x^8}{203695430400}+O[x]^9[/tex]
in form of [tex]12[/tex] first members in series.
[tex]e^{x}=1+x+\frac{x^2}{2!}+...[/tex]
so I can say
[tex]e^x-x-1=\sum^{\infty}_{n=2}\frac{x^n}{n!}[/tex]
[tex]\frac{1}{e^x-x-1}=\frac{1}{\sum^{\infty}_{n=2}\frac{x^n}{n!}}[/tex]
But I don't know what to do with that.
Take [tex]2/x^2[/tex] common, the expression becomes
[tex]\frac{2}{x^2}\left(1+\frac{x}{3}+\frac{x^2}{12}+...\right)^{-1} = \frac{2}{x^2}(1+y)^{-1}[/tex]
where
[tex]y = \frac{x}{3}+\frac{x^2}{12}+...[/tex]
Now expand [itex](1+y)^{-1}[/itex] and then substitute back.
where
Ok. I will get
[tex]\frac{2}{x^2}\sum^{\infty}_{n=0}(-1)^n(\frac{x}{3}+\frac{x^2}{12}+...)^n[/tex]
But I don't have this form
[tex] \frac{2}{x^2}-\frac{2}{3 x}+\frac{1}{18}+\frac{x}{270}-\frac{x^2}{3240}-\frac{x^3}{13608}-\frac{x^4}{2041200}+\frac{x^5}{874800}+\frac{13 x^6}{146966400}-\frac{307 x^7}{24249456000}-\frac{479 x^8}{203695430400}+O[x]^9[/tex]
and I want to do that analyticaly from
[tex] \frac{1}{e^x-x-1}[/tex]
So open up the brackets and expand it further. You will get that.
Open up the brackets?
Open up
[tex] (\frac{x}{3}+\frac{x^2}{12}+...)^n[/tex]
for the first few terms. then do the summation.
Listen to me. I have just this[tex]\frac{1}{e^x-x-1}[/tex]
I understand. What I am asking you to do is simple. Lots of irritating calculations, but simple.
Let me work out the first two terms for you (upto [itex]{\cal O}(1)[/itex]). Do you agree that you got the following?
[tex]\frac{2}{x^2}(1+y)^{-1} = \frac{2}{x^2}(1-y+y^2-y^3+...)[/tex]
Now plug in the expression for y
first term is
[tex] y = (\frac{x}{3}+\frac{x^2}{12}+...)[/tex]
second is
[tex]y^2 = \frac{x^2}{9} + ...[/tex]
Note that you don't require to calculate any higher terms since those will just contribute to [itex]x^3[/itex] and higher. Now plug it in
[tex]\frac{2}{x^2}(1-y+y^2-y^3+...) = \frac{2}{x^2}\left(1 - \frac{x}{3} - \frac{x^2}{12} + \frac{x^2}{9}\right)[/tex]
[tex]\Rightarrow = \frac{1}{e^x-x-1} = \frac{2}{x^2} - \frac{2}{3x}+\frac{1}{18} +...[/tex]
And to go up one higher order you will have to go till y^3, and to next order in the expansion of y. Got it?
I understand what you trying to tell me. But
[tex] <br /> \frac{2}{x^2}-\frac{2}{3 x}+\frac{1}{18}+\frac{x}{270}-\frac{x^2}{3240}-\frac{x^3}{13608}-\frac{x^4}{2041200}+\frac{x^5}{874800}+\frac{13 x^6}{146966400}-\frac{307 x^7}{24249456000}-\frac{479 x^8}{203695430400}+O[x]^9<br /> [/tex]
this relation is given by the computer and I can't use it.
I must take
[tex] \frac{1}{e^x-x-1} [/tex]
and get from that Laurent series!
I am not asking you to use it! I am asking you to calculate by series expanding by hand! And then VERIFY your answer by matching it with what the computer has given you. The method I have written is an analytic series expansion that I have done by hand. I haven't used any computer to do any part of my calculations.
This calculation is exactly that of getting the Laurent Series.
Ok just tell me
[tex]\frac{1}{e^x-x-1}=...[/tex]
what you have done before you put [tex]\frac{2}{x^2}[/tex]?
Write
[tex] e^x = 1+x+\frac{x^2}{2!}+...[/tex]
You figured out
[tex]e^x-x-1 = \frac{x^2}{2!}+\frac{x^3}{3!}+\cdots = \frac{x^2}{2}\left(1+\frac{2x}{3!}+\frac{2x^2}{4!}+\cdots\right)[/tex]
so
[tex]\frac{1}{e^x-x-1} = \frac{1}{\frac{x^2}{2}\left(1+\frac{2x}{3!}+\frac{2x^2}{4!}+\cdots\right)} = \frac{2}{x^2}\,\frac{1}{1+\left(\frac{2x}{3!}+\frac{2x^2}{4!}+\cdots\right)}[/tex]
Now compare this to what praharmitra wrote in post 8.
