Representing long decimals in hex in Java
  • Topic: Java
  • Thread starter Thread starter Paul Uszak
    Java
34 replies · 6K views
Paul Uszak
Does anyone know how to represent the following (example) base 10 number as hexadecimal in the Java language?
2.67367134065437661762356872350435000732582367230003208735000765782365523111637787869816671091367351854359435034651476543984089764356140092091709145675149665165167871324671303963400256123013656501396325676347820
I'm not sure I understand the question. It seems like a straightforward algorithm to convert a decimal floating point number to a base 16 floating point number, or is that not what you mean? And it's the algorithm that matters, not what language it is implemented in. Certainly the standard math pack won't do it, if that's what you're asking ...an extended precision algorithm will be required but that's just programming.
No - it's exactly as you say. I just don't know how to do it. Any specific pointers /code fragments..? (I mention Java as that's my programming skill set.)
Try Planet Source Code. I haven't used it in years but when I used to go there I could almost always find something that helped.
If you don't mind handling the decimal point yourself you can use the BigInteger class [1] which has a constructor that accept a long string of numbers (without decimal point) and a toString method that takes a radix (use 16 for hexadecimal).
If you like to parse your number with a decimal point but don't need the decimal point on output you can also use the BigDecimal class [2] which can read in decimal numbers with a decimal point and convert the whole number to an unscaled BigInteger which you then can print in hexadecimal. If you really need the decimal point on output too you should be able to extract the integer part and fractional part of that BigDecimal as BigIntegers which you can then print separated by a decimal point.
[1] https://docs.oracle.com/javase/7/docs/api/java/math/BigInteger.html
[2[ https://docs.oracle.com/javase/7/docs/api/java/math/BigDecimal.html
That does not work Filip Larsen - 1.110 ≠ 1.116 (and also ≠ 0.B16).
You need the apfloat (arbitrary precision floating point) library rather than BigInteger.
Apparently you read some else into the OP's question than I do.
phinds said:
It seems like a straightforward algorithm to convert a decimal floating point number to a base 16 floating point number, or is that not what you mean? [...]
As a follow-up to this exchange, my comment to use BigInteger/BigDecimal was to point out that there are standard classes for doing it (as long as the OP can manage to handle the decimal point himself). If this is not what the OP wants, then perhaps he should clarify what problem he is trying to solve with the hexadecimal number.
I have to question whether you have really thought this through. Just take the simple decimal number 1.5 If you ignore the decimal point, planning to "take care" of it after the conversion, you have 15 which converts to hex F. Now take the ACTUAL conversion and you go from decimal 1.5 to hex 1.8 How do you "handle the decimal point" to get from F to 1.8 ? Suggesting that this is trivial does not strike me as a helpful approach. Am I missing something?
Well, I have not been very clear on my assumptions. If you are trying to write up a floating point number in hex then you are right - what I suggest will not work. And the OP does indeed mention "floating point", although it is not clear to me why he wants to express it in hexadecimal.
Lacking any clear understanding about what the OP wants, I am merely suggesting that if he treat the integer and fractional part as two separate (hex) number strings that just happens to be separated by a decimal point (if he really needs it) then he can use BigInteger. The combined string will not be representing the number as floating point number in the way floating numbers are defined, but since there is no standard way in Java to specify a hex floating point number constant with an arbitrarily number of precision he will have to use a library of some sorts anyway in order to use this number for anything related to arithmetic.
Granted, without any reason for having the number specified in hex I should probably just have suggested to include the number directly as a BigDecimal with something like
Java:
BigDecimal myConstant = new BigDecimal("2.67367134065437661762356872350435000732582367230003208735000765782365523111637787869816671091367351854359435034651476543984089764356140092091709145675149665165167871324671303963400256123013656501396325676347820");
after which myConstant is available for calculations or convertion using the BigDecimal class.
The OP states that he wants to represent rational numbers (of which he gives an example) in hex in Java.
Filip Larsen said:
... I should probably just have suggested to include the number directly as a BigDecimal with something like
Java:
That won't work - BigDecimal does not do number base (radix) conversions: apfloat does which is why I suggested it.
I see no mention of rational numbers by the OP in this thread?
The code snippet I gave has no need for a radix. It is meant to illustrate that lacking any particular reason for writing the number in hex you may as well include number directly as a decimal number using BigDecimal (or the Apfloat library, if that fits your bill).
The OP gave an example of a number he wanted to represent: the example is a rational number. As the OP has not returned and his question has been answered I have no more to say on this.
MrAnchovy said:
The OP...
Side (Silly) Question:-
Sorry, but this is the second site that's called me the "OP". What does OP mean please? Is it rude :wideeyed: ?
Original Poster - not rude at all :biggrin:
You realize that a number with a finite amount of digits in base 10 may have an infinite amount of digits in base 16?
Anyway, here is an example in Java.
Code:
import java.math.BigInteger;
import java.math.BigDecimal;
public class Hex {
  public static void main(String[] args) {
    String input = "2.67367134065437661762356872350435000732582367230003208735000765782365523111637787869816671091367351854359435034651476543984089764356140092091709145675149665165167871324671303963400256123013656501396325676347820";
    int maxDigits = 200;
    BigDecimal bd = new BigDecimal(input);
    BigInteger bi = bd.toBigInteger();
    String hexString = bi.toString(16);
    bd = bd.subtract(new BigDecimal(bi));
    if(!bd.equals(BigInteger.ZERO)) hexString += ".";
    while(!bd.equals(BigDecimal.ZERO) && maxDigits-- > 0) {
      bd = bd.multiply(new BigDecimal(16));
      hexString += bi.toString(16);
    System.out.println(hexString);
Thanks for the code. It's really useful.
I gave a simple example because I didn't want the thread to drift off in a tangential direction before consensus was reached on an answer.
I'm trying to convert a billion (10^9) digit file of the decimal expansion of pi into a binary file of 0-255 value bytes. This will give me a file of what I believe to be truly random bits for comparison purposes for some other work I'm undertaking. I can adapt the code for my needs. Just hope that I have enough RAM...
With a billion digits my code is going to need a lot of RAM and it will take forever to run.
But if all you want is random bytes you can just use Random.nextBytes
Will say a week and 8 GB be sufficient do you think?
Can't use Random.nextBytes; it's not really. I need undisputedly random.
PI is not any more random than the output of the Random class. But there is also SecureRandom which produces better random numbers.
Err, is this a serious comment? The mathematical consensus is that the sequence of digits of pi, e, golden ratio, root 2 are infinite in all bases and entirely random. There's a mountain of published research substantiating this.
I want to use pi as a bench mark for some tests I'd like to do, just don't have it as bytes.
Did you look at generating it rather than converting it?
If all you want to do is convert a completely random sequence of decimal digits into a completely random sequence of bytes, you don't actually have to do a proper base conversion. You can use a simpler, faster algorithm that ends up producing a smaller number of bytes than theoretically possible but is quite fast and needs only little memory.
Here is an example in Java. Whenever a decimal digit is between 0 and 7 it is converted to binary directly. If it's 8 or 9 it is converted into a 0 or a 1. The result should be every bit as random as the input digits. Producing on average 2.6 bits for each decimal digit instead of the theoretically possible 3.3 bits per digit.
As input you can use a FileReader object and as output a FileOutputStream.
btw. there is a program you can use to test the randomness of the output at http://www.fourmilab.ch/random/
Code:
public static void randDecToBin(Reader in, OutputStream out) {
  try {
    int b = 0, bits = 0;
    while(true) {
      int c = in.read();
      if(c < 0) break;
      int d = c - '0';
      if(d < 0 || d > 9) continue;
      if(d >= 0 && d <= 7) {
        b = (b << 3) | d;
        bits += 3;
      } else {
        if(d == 8) b = b << 1;
        else b = (b << 1) | 1;
        bits++;
      if(bits >= 8) {
        out.write(b & 0xFF);
        b >>>= 8;
        bits -= 8;
  } catch(Exception e) {
    e.printStackTrace();
No, that will produce twice as many 0s and 1s as any other (octal) digit. Your method is basically sound (and will be just as random as a true representation of pi in any number base), you just need to ignore 8s and 9s.
Why would it produce twice as many bits? It works fine and the output tests as extremely random.
Oh sorry, I misread your explanation and found your code a bit hard to read so I gave up - the method you describe does indeed produce an average of 2.6 random bits for each decimal digit.
I did briefly. I don't have the skill or kit to generate pi to that number of digits. I already have it in the form of ASCII text. I'd be more confident of having the correct sequence if I just do a simple bit manipulation exercise. One of the features of randomness and cryptography is large numbers, so a roughly Gigabyte file would be really useful.
DrZoidberg said:
...the output tests as extremely random.
If I may, what was your input for the test, and how did you test the output? ENT?
What, exactly, makes you think you need "undisputedly random"? What, exactly, makes you think a finite sequence of the hexadecimal representation of pi is "undisputedly random"?
Some applications do indeed need a cryptographically secure pseudo random number generator. Note well: Bits generated by the binary representation of pi are not cryptographically secure.
There is a formula that let's you do exactly that, the Bailey-Borwein–Plouffe formula. With this, one can, for example, calculate the quadrillionth (1015) hexadecimal digit of pi without having to calculate all of the 1015-1 hexadecimal digits that precede it.
Yes, I used ENT for the test. My input was a text file containing the first 1 billion decimal digits of pi.
