Req of this series/parallel circuit?
  • Thread starter Thread starter letsgo
    Circuit
5 replies · 4K views · last reply
letsgo
What is the Req of this circuit?
The answer should be 150 ohms, but I can't get that.
Req = R1 + R2
1/Req = 1/R1 + 1/R2
If I treat R1 and R3 as series, I get R13= 200 ohms.
Then if I treat R13 and R2 and parallel I get R123 = 66.7 ohms.
Then if I treat R123 and R4 as series, I get Req = 266.7 ohms.
Also, since the current is 0 (open switch), then the potential difference between points P and Q would also be 0, right?
A hint..
There appears to be a wire (grey) connected from one end of R3 to the other end. What does that mean for the voltage across R3 or R3 in general?
CWatters said:
A hint..
No clue. It's the same as the source's voltage?
Also, did you manage to get Req?
The grey wire has a very low resistance, let's assume it's zero Ohms. You therefore have R3 in parallel with a zero Ohm resistor..
For that bit of the circuit..
I/R = 1/R3 + 1/zero
but 1/zero = ∞
so R3 in parallel with zero Ohms = zero Ohms.
The circuit reduces to..
I'll let you have another go at calculating Req.
I/R = 1/R3 + 1/zero
but 1/zero = ∞
Smart, thanks.
