Request about experiments on the linear-motion Faraday paradox
81 replies · 28K views · last reply
artis said:
I believe the linear moving sheet also becomes polarized just like the disc becomes
the problem is, that might be a violation of the principle of relativity
olgerm said:
This was about linear motion scenario not about disc breaking scenario.
Well, we ought to investigate the transition cases.
Depends what will be between the pieces, what is capacity of pieces, what shape the pieces are and etc.
yeah, you can set your own parameters.
The issue is how to not violate the principle of relativity.
greswd said:
yeah, you can set your own parameters.The issue is how to not violate the principle of relativity.
How could it violate principle of relativity? Set your own parameters and explain how it does violate principle of relativity.
artis said:
Look at this simple "railgun" which is basically a linear homopolar motor/Faraday disc, if one applies current to the rails the third shunting rod moves along the rails, but if one puts a voltmeter across the rails, puts a magnet under or above the rails and moves the third rod by hand the voltmeter should read DC voltage output because imagine the rails , voltmeter and moving rod form a rectangular loop that is electrically closed , as you move the rod you change the cross-sectional area of the loop in other words you change the amount of B field lines through the loop which results in generated current in the loop.
This is not what OP meant by linear version of the Faraday paradox in his original post, because conductor and magnet are not moving together in your setup.
greswd said:
This has made me curious about the linear version of the Faraday paradox.
A conductor placed atop a magnet, both at rest in one scenario. In another, both moving together in uniform linear motion.
So what's the mathematics of the "transition"?
Both the disc and linear Faraday "sheet" or whatever you call it both agree with relativity in fact I think they can only be explained with the help of Special relativity and Lorentz forces on electrons etc, that is the reason this was called the Faraday paradox in the beginning until the early 20th century.
I suggest @greswd really think about the "drum" type homopolar generator as that is essentially a rolled up version of a flat conducting sheet being moved across a B field at 90 degree angle. Same rules apply as with a disc rotating in a B field.
I do not understand your question. You where interested about transitional cases so I suppose you know yourself what you meant by transition.
The rotational Faraday homopolar generator works, the linear one doesn't.
What sort of mathematics describes the EMF during the transition between both cases? From linear motion to a slight curve to full rotational motion.
Then what occurs during the transition? Thanks
olgerm said:
Only the angular speed is important, whether the body is moving lineary at same time is not important.
olgerm said:
So what's the mathematics? Cos the last time, you said:
greswd said:
So what's the mathematics? Cos the last time, you said:"This was about linear motion scenario not about disc breaking scenario."
You said that you mean by transition to go from linear motion to a slight curve to full rotational motion, not disc breaking scenario.
My answer was about transition in that sense.
Do you want more explanation about disc breaking?
@greswd , Who said the linear generator doesn't work?
One more time, there is no difference between the linear metal sheet or when the sheet is rolled up in a drum and the flat pancake disc they are all the same from the viewpoint of laws of physics, they all work on the idea of electrons feeling the Lorentz force as the metal cuts a homogeneous magnetic field at 90 degrees.
The only difference is that some of those geometries are much harder to make while the disc is easier so most people go wit the disc.
Why do you care about the transition and what do you even mean by that ? There is no transition as far as I know, the only thing that changes is the geometry , physics doesn't change. I think you ask about these transitions because there is a wrong perception that somehow the "linear generator doesn't work" but I already said it does.
Try it out, take a thin copper or aluminum metal sheet, salvage or get a lot of magnets , align them all so that the same poles face upwards, make stationary brushes and then move the sheet back and forth over the magnets while the sides of the sheet touch some stationary brushes or sliding contacts, voltage will be very very small but with a sensitive voltmeter you might pick up some mV.
ok, why is only the angular velocity important when the Lorentz force is dependent on the linear velocity?
olgerm said:
because to produce electricity you need a closed circuit in which electromotive force(U) is not 0. U can be expressed as ##U=\oint(dl*(\vec{E}+\vec{v}\times \vec{B}))=\oint(dl*\vec{E})+\oint(dl*(\vec{v}\times \vec{B}))=\oint(dl*(\vec{v}\times \vec{B}))-\frac{\partial \oint (dS*\vec{B})}{\partial t}##.
If you take smaller circuits and connect these together then EMF of the new circuit is sum of the smaller circuits. EMF infinitesimaly small circuit is ##rot(\vec{v}\times \vec{B})-\frac{\partial \vec{B}}{\partial t}## and I showed that all these have 0 EMF. All closed circuits can be composed of infinitesimaly small circuits. Therefore all closed circuits must have 0 EMF.
Also, how does this quote relate to the quote above?
You see, the Lorentz force formula uses the relative velocity seen in your rest frame. Not exactly following the principle of relativity.
because if you change frame of reference all ##\vec{E}##, ##\vec{B}## and ##\vec{v}## change in manner that frameinvariant quantities remain the same.
Depends what you mean by linear generator. I say that linear generator in meaning that it is a generator, which all parts are moving together lineary, does not work.
Sorry, I don't understand what you're saying
Of course it doesn't but then the Faraday disc also doesn't work when you rotate the brushes together with the disc, the same rules apply
Rotational and linear case may not give the same result.
I am not 100% sure. But I think Faraday disc would generate electricity if you rotated its brushes together with its disc.
No it would not, think about it, because the brushes and the connecting wire between them would rotate with the same angular velocity and direction that the disc rotates which means that the the current in the brushes would be in the same direction as that in the disc , so the result is two currents running oppositely to one another which sums to zero current in the loop.
You are probably right. I can't get intuition of the situation. Would it not depend of shape of the wire from brush to center of disk and shape of B-field?
Well I have read in theory that if the brushes and return wire could get magnetically shielded then in theory the current in the loop should be the sum of the current generated in the disc portion but in real life this is not possible at least haven't heard anyone done that.
The best practical way to "shield" the return path from getting any canceling current generated is to keep it still and that is the reason for the sliding contacts
But I think you got it , it's a Lorentz force generator so it's very peculiar to the B field and parts of a single loop moving while others staying still unlike in a conventional generator you simply change the field strength through a loop and get induced current.
@olgerm Sorry, need your help.
If there are no brushes, the disc still gets polarized, with the rim or the center having a higher electron density. @olgerm
@artis @jartsa
maybe @olgerm is right and it does depend on the angular velocity. and this would be investigating a rarely mentioned chapter of physics.
You are right, it can't produce DC current. EMF summarised over one full rotation in loop that consist of wire disc and brush must be proportional to change in B-field flux compared to last time, that the wire was in that position beacuse of maxwells III equation. And magnetic flux through the loop must be same every time it gets to that position, because B-field is constant(not changing in time).
There is a distinct physical effect in the rotational case which cannot be ignored.
