Requesting help with the uncertainty principle equation
In summary, the most general form of the Schrödinger uncertainty relation reduces to the commutator term only if the anti-commutator term is never zero.
dyn
773
61
Hi
For 2 Hermitian operators A and B using the Cauchy-Schwarz inequality and assuming the expectation values of A and B are zero I get
(ΔA)2(ΔB)2 ≥ (1/4)|<(AB+BA)>|2 + (1/4)|<(AB-BA)>|2
Now both terms on the RHS are positive so why is this inequality usually just written with only the commutator term , dropping the anti-commutator term ? Surely it could be written with only the 1st term instead ? And why is it not normally written with both terms ?
Thanks
dyn said:
I get
Could you show us how ?
Often <AB+BA> = 0 but the inequality stays true if you drop a term that cannot be negative.
You derived the most general form, the Schrödinger uncertainty relation.
Likes dextercioby and bhobba
But the commutator can sometimes be zero and both terms cannot be negative so why is the anti-commutator term usually dropped from the uncertainty relation ?
The commutator is rarely zero in cases where the uncertainty relation is used.
If it is zero and the anticommutator is also zero you don't need the uncertainty relation. ##\geq 0## is trivial.
Is it not the case that the anti-commutator is also rarely zero ? In which case why is that term general dropped ?
You could have the UP for a particular state, but in that case you have an equality. I.e. ##(\Delta A)^2 (\Delta B)^2 =## something definite.
Where the UP comes in is usually for any state of a system. And, you may be able to find a state where ##\langle AB + BA \rangle = 0##. In that case, in general, the inequality will involve the commutator.
Note that its an inequality. Most of the time the uncertainty will be greater. But, if you need a general inequality for a system, then it reduces to the commutator term only.
(You might like to try to find a system where the expected value of the anti-commutator is never zero, in which case there is actually a stronger UP.)
Finally, the position-momentum UP, for example, is valid for all systems and all states. In which case, you can't do better than the HUP. I.e. there are systems and states for which equality applies.
Why does a general inequality reduce to the commutator term only ? What happens to the anti-commutator term ?
Because it's an inequality. You can always drop a term. E.g.
If ##a \ge b + c## Where ##c \ge 0##, then ##a \ge b##.
But both terms are non-negative so why always drop the anti-commutator ? Is it just convention ?
No. Look at the full inequality in the above link.
For example, with only the anti-commutator term the HUP would become:
##\sigma_x \sigma_p \ge 0##
Which doesn't say anything.
For canonical conjugates, the (expectation value of the) commutator is [itex]i \hbar[/itex] for all states. It doesn't make sense to drop this term and keep only the anti-commutator term because you can't find a state where the resulting inequality becomes an equality.
For the Heisenberg uncertainty principle (where only the commutator term is kept), there are states where the inequality becomes an equality (the coherent states of the harmonic oscillator, for example).
Still, it might be interesting to restrict oneself to states where the anti-commutator doesn't vanish and ask what kind of states minimize the Schrödinger uncertainty principle . The so-called squeezed states have this property (Trifonov 2001). Trifonov also talks about such states for noncanonical observables but I have never heard of them.
In the end, the significance of all these states is whether they can be prepared in the lab and have interesting properties.
Likes dyn and PeroK
The UP I quoted in #1 contains a commutator term and an anti-commutator term. Both terms are non-negative so I do not understand why the UP is generally shown with only the commutator term.
Also with the usual form involving only the commutator term if [ A , B ] = 0 then this says (ΔA)2(ΔB)2 ≥ 0 but it cannot be zero because if [A, B] = 0 then AB+BA does not equal zero
You've dropped the ##\langle A \rangle \langle B \rangle## term from the expression involving the anti-commutator. If ##A## and ##B## commute, you can find a shared eigenbasis and the whole anti-commutator term is 0:
##\frac12 \langle AB + BA \rangle - \langle A \rangle \langle B \rangle = 0##
Likes dyn and dextercioby
If A and B don't commute as with x and px then why is the anti-commuter term generally dropped ?
It isn't always dropped, see the paper I cited above. But it's a question of usefulness.
The way the HUP is often used is "if the spread in position is such and such, the spread in momentum needs to be at least such and such". This enables quick estimates and you don't even need to know the exact state. An example would be "I know that the particle is located in the lab, so the spread in momentum needs to be at least of the order hbar / length of the lab".
You can't reason like this with the Schrödinger uncertainty relation because the anti-commutator depends on the state. For the same reason, uncertainty relations for noncanonical observables aren't used much in practise.
Likes dyn
1. What is the uncertainty principle equation?
The uncertainty principle equation, also known as the Heisenberg uncertainty principle, is a fundamental principle in quantum mechanics that states that it is impossible to know both the exact position and momentum of a particle at the same time. It is represented by the equation ΔxΔp ≥ h/4π, where Δx is the uncertainty in position, Δp is the uncertainty in momentum, and h is Planck's constant.
2. Why is the uncertainty principle important?
The uncertainty principle is important because it sets a limit on the precision with which certain physical properties of particles can be measured. It also highlights the inherently probabilistic nature of quantum mechanics and challenges the classical notion of determinism.
3. How do I use the uncertainty principle equation?
The uncertainty principle equation can be used to calculate the minimum uncertainty in position or momentum of a particle. To use it, simply plug in the values for Δx and Δp and solve for the other variable. It can also be used to compare the uncertainties of different particles or systems.
4. What are the units of the uncertainty principle equation?
The units of the uncertainty principle equation depend on the units used for position and momentum. Generally, position is measured in meters and momentum is measured in kilograms meters per second (kg·m/s). Therefore, the units of the uncertainty principle equation would be (m)(kg·m/s) ≥ h/4π, which simplifies to kg·m²/s ≥ h/4π.
5. Are there any exceptions to the uncertainty principle?
While the uncertainty principle holds true for most physical systems, there are certain situations where it does not apply. For example, in macroscopic objects, the uncertainties in position and momentum are so small that they can be ignored. Additionally, there are certain quantum states, such as coherent states, that minimize the uncertainty in both position and momentum. However, these are exceptions and do not invalidate the principle itself.
  • Quantum Physics
  • Quantum Physics
9K
