Require clarification on how charging a capacitor works
The discussion clarifies the process of charging a parallel plate capacitor connected to a battery. When connected, electrons flow from the battery's negative terminal to the plate, creating a negative charge, while electrons on the positive plate move towards the positive terminal, establishing a positive charge. The voltage across the capacitor matches that of the battery when fully charged. It is emphasized that electrons do not cross the dielectric directly; instead, they are influenced by electric fields, leading to a separation of charge without direct electron transfer across the dielectric.
  • Understanding of basic electrical concepts such as voltage, current, and charge.
  • Familiarity with capacitor construction, specifically parallel plate capacitors.
  • Knowledge of dielectric materials and their role in capacitors.
  • Awareness of electron drift velocity and its implications in electrical circuits.
  • Study the principles of electric fields and their effects on charge distribution in capacitors.
  • Learn about the different types of dielectrics and their impact on capacitance, including relative permittivity.
  • Investigate the concept of dielectric breakdown and its applications in electronic components.
  • Explore the relationship between drift velocity and current flow in conductive materials.
Electrical engineering students, electronics hobbyists, and anyone interested in understanding capacitor behavior and charging mechanisms in circuits.
needingtoknow
When it comes to charging a capacitor I'm under the impression that when a parallel plate capacitor is hooked up to a battery, that electrons simply flow from the negative terminal to the plate that is connected to the negative terminal, causing that plate to become the "negative plate" and electrons that are on the plate connected to the positive terminal will flow towards the positive terminal making that plate the "positive plate". This process occurs until the voltage of the capacitor matches the voltage of the battery. This is basically what the diagram that I attached is trying to explain.
I have two questions with respect to this explanation:
1. When I was reading up on charging a capacitor, I read that work is required to transfer charge from the positive plate to the negative plate and that transfer of electrons from one plate to another is what charges the battery, clearly not what I explained above in the first paragraph. I am obviously missing something here. I would appreciate your help in clarifying the process of charging a capacitor.
2. There is a space between the first plate and the second plate, which means the circuit is incomplete UNLESS what is happening is that electrons are being transferred from the "negative plate" to the "positive plate". Is that true?
Thank you very much!
Actually I think when my book said that the electrons were being transferred from the positive plate to the negative plate they meant indirectly by traveling all the way around the voltage source rather than simply crossing the capacitor (b/c I now realize that that is unlikely due to the presence of the dielectric)
Yes, if electrons flow across the dielectric, that is called breakdown and is a bad thing.
Not necessarily, it depends what you're trying to do. I don't really have a specific example for when breakdown in a capacitor would be useful, but I personally have reverse biased many-a-diode, operated them at breakdown, and used them as photo detectors. Definitely not a bad thing there.
Dielectric capacitors are also better this way right because they prevent less electrons from passing across from one plate to the other, causing a greater build up of charge?
I don't know what you mean. What is a "dielectric capacitor" as opposed to any other capacitor? ALL capacitors have a dielectric, whether it is air, wax, oil, vacuum, ceramic, or tiny little green men holding the plates apart. There is SOMETHING between the two plates and that is called the dielectric.
I find it hard to believe that dielectric breakdown in a capacitor could ever be a good thing.
That is also misleading, if it gives you the wrong idea that the electrons move at high speed all the way round the circuit. For typical components that you would find in battery powered electronic circuits, each individual electron will only move a fraction of a millimeter when you charge the capacitor. You are not moving electrons all the way from one plate to the other. You are just pushing the electrons on one plate slightly closer together, and pulling the electrons on the other plate slightly further apart, compared with the positive charges which can't move around because they are part of the nuclei of the atoms in the plates.
My mistake, you are right phinds I meant a dielectric insulator such as glass or rubber. That is actually pretty interesting AlephZero, so the electrons only move a fraction of a millimeter? I've always thought the opposite. I will definitely look into that now thank you!
Yeah, lots of folks find that surprising. I forget the exact speed but it is something on the order of inches per hour. REALLY slow. It's called "drift velocity". CURRENT flows really fast so it's confusing.
I suppose one might argue that lightning arresters / overvoltage protectors make use of dielectric breakdown in the form of a capacitor of sorts. Also glow discharge lamps for another example. Of course we don't call these things capacitors because they're intended for another purpose, but they've still got a capacitor-like structure at their heart.
That's fair enough. I was thinking more of traditional caps in an electronics circuit.
Dielectric breakdown in a liquid or gas is usually "self-healing" when the voltage source is removed, unless it starts a self-sustaining chemical reaction, e.g. the fluid catches fire. Breakdown of a solid dielectric often causes some irreversible change, e.g. cracking of the solid material.
Consider parallel plates separated by a vacuum. Because the plates are in such close proximity, if an electron is added to one plate its electric field line "reaches across" the gap and repels exactly one electron off the other plate. So to an outside observer, it may appear that the electron has jumped the gap, but nothing could be further from the truth. Only field lines span the gap, electrons themselves don't jump across.
The presence of a material in the gap changes things somewhat, having the effect of magnifying the capacitance by its material constant ##\epsilon##r.
  • · Replies 18 ·
  • · Replies 44 ·
