Residue Theorem applied to a keyhole contour
In summary, the conversation is about solving an integral using the residue theorem. The first step is to factorize the denominator and find values for z0 that correspond to isolated singularities. The next step is to calculate the residue at each simple pole, which is done by multiplying the function by (z-z0) and evaluating it at z0. The final step is to use the residue theorem, which states that the integral is equivalent to 2*pi*i times the sum of the residues. The conversation also covers finding the values of z0 in polar form, and correcting errors in the calculations.
Teymur
Use the Residue Theorem to show:
$$\int \:\frac{z^{\frac{1}{2}}}{1+\sqrt{2}z+z^2}dz=2^{\frac{2}{3}}\pi isin\left(\frac{8\pi }{3}\right)$$
for a keyhole contour where ##z=re^{i\theta }## and ##-\pi <\theta <\pi##
the standard residue theorem
I'm really struggling with this one. A newbie to using the residue theorem. I'm trying to solve this by factorising the denominator to find values for z0 and I have:
##z=\frac{-\sqrt{2}+i\sqrt{2}}{2}## and ##z=\frac{-\sqrt{2}-i\sqrt{2}}{2}##
I also know that sin(3π/8)= ##\frac{\sqrt{2+\sqrt{2}}}{2}##
Show us residues you calculated, please.
Likes topsquark
The path of integration is not clear to me. I can make a guess, but it is better if you spell it out. What is the multiplier 'a'? What is a "keyhole contour"?
Hello,
Thanks for the responses. The integral is a closed contour integral (with a branch cut along the negative x-axis so the function is not multi-valued) but I couldn't find the correct symbol with the integral sign having a circle. The residue theorem states that in place of calculating the integral explicitly, it is equivalent to 2*pi*i*sum of residues.
I haven't that's the problem. The first step, in the process I'm familiar with, is to factorise the denominator so that you can find values of z for which their are isolated singularities. I've tried to do that and I've given my results in the original post. Not sure where to go next..
p.s. I'm aware you can use the Laurent series, but my series expansion knowledge isn't great. Hence I'm trying to compute this using poles.
the "a" was a mistake, sorry. I've removed it
This is an example:
Likes DrClaude
These are simple poles, so what's the procedure for calculating the residue of a simple pole?
Please correct the typos in your work. There's a fairly obvious one, but I suspect there are more.
Ah yes, so sorry!! The integral should give:
$$2^{\frac{3}{2}}\pi \:isin\left(\frac{3\pi }{8}\right)$$
I got the numerators and denominators mixed up! Soz
Yes exactly, simple poles. Firstly, I'm just checking to see if the values I have obtained for z0 at the poles are correct, they seem unwieldly. If they are correct, you multiply f(z) by (z-z0) and evaluate the result at =z0.. I've tried to do that but can't see how it would get you to the intended outcome.
The values of ##z_0## seem right. What are they in polar form?
Likes vela
You can always check them by plugging them back into the quadratic and seeing if the result is 0. They are indeed a bit unwieldy for some parts of the calculation. As @julian suggested, you'll find it convenient to express them in polar form.
Teymur said:
If they are correct, you multiply f(z) by (z-z0) and evaluate the result at =z0. I've tried to do that but can't see how it would get you to the intended outcome.
Post what you get. Remember you have two poles, so it's the sum that will produce the result you want.
Likes julian and Teymur
Okay cool. Am I right that you get:
$$\cos \left(\frac{\pi }{4}\right)+isin\left(\frac{\pi }{4}\right)=e^{\frac{i\pi }{4}}$$
and
$$\cos \left(\frac{3\pi i}{4}\right)+isin\left(\frac{3\pi i}{4}\right)=e^{\frac{3\pi i}{4}}$$
And if so, is the next step:
$$\left(z-e^{\frac{\pi i}{4}}\right)f\left(z\right)=\left(z-e^{\frac{\pi i}{4}}\right)\frac{z^{\frac{1}{2}}}{\left(z-e^{\frac{\pi i}{4}}\right)\left(z-e^{\frac{3\pi i}{4}}\right)}$$
For ##z=e^{\frac{\pi i}{4}}##
$$\frac{e^{\frac{\pi i}{8}}}{\left(e^{\frac{\pi i}{4}}-e^{\frac{3\pi i}{4}}\right)}$$
The first one isn't correct, but the second one is. (Just check the signs.) Note that because the coefficients in the quadratic are real, the roots will be complex conjugates of each other. So this means the other root is ##e^{-3\pi i/4}##.
The next step will look okay once you fix the roots. I'd note it's a limit as ##z \to z_0##.
Likes julian
You mean that the roots are ##e^{\frac{3\pi i}{4}}## and ##e^{\frac{-3\pi i}{4}}##?
Likes julian
Are you saying:
$$\left(z-e^{\frac{3\pi i}{4}}\right)f\left(z\right)=\left(z-e^{\frac{3\pi i}{4}}\right)\frac{z^{\frac{1}{2}}}{\left(z-e^{\frac{3\pi i}{4}}\right)\left(z-e^{\frac{-3\pi i}{4}}\right)}$$
so that as z goes to z0:
$$\frac{e^{\frac{3\pi i}{8}}}{\left(e^{\frac{3\pi i}{4}}-e^{\frac{-3\pi i}{4}}\right)}$$
Teymur said:
Are you saying:
Do the same thing with the root ##e^{-\frac{3\pi i}{4}}##. Add the two residues, then multiply by ##2 \pi i##.
Likes Teymur
working backwrads from the solution given in the question and putting aside the prefactor of ##2\pi i## that comes from the theorem, that means that the sum of the residues should give ##2^{\frac{1}{2}}sin\left(\frac{3\pi }{8}\right)##
I can't see how to get there from:
$$\frac{e^{\frac{3\pi \:i}{8}}}{e^{\frac{3\pi \:i}{4}}-e^{-\frac{3\pi \:i}{4}}}+\frac{e^{\frac{-3\pi \:i}{8}}}{e^{\frac{-3\pi \:i}{4}}-e^{\frac{3\pi \:i}{4}}}$$
I'm assuming the following identity has something to do with it, but can't seem to put it all together:
$$sin\left(x\right)=\frac{e^{ix}-e^{-ix}}{2i}$$
Likes FactChecker
The denominator of the 2nd term is the negative of the denominator of the first term. That allows you to write your expression as a single fraction.
And then, yes, you use ##\sin (x) = \frac{e^{i x} - e^{-i x}}{2i}##.
Likes FactChecker
I get the feeling this isn't the best way to simplify but what I get is as follows:
$$\frac{sin\left(\frac{3\pi }{8}\right)}{sin\left(\frac{3\pi }{4}\right)}=\sqrt{\frac{2+\sqrt{2}}{2}}$$
If you then multiply through by ##2^{\frac{1}{2}}## you get:
$$2^{\frac{1}{2}}\frac{\sqrt{2+\sqrt{2}}}{2}=2^{\frac{1}{2}}sin\left(\frac{3\pi \:}{8}\right)$$
as required. If there's a simpler, straightforward way to do this, I'd be grateful to hear.
The sum of residues is indeed equal to:
\begin{align*}
\dfrac{\sin \left( \frac{3 \pi}{8} \right)}{\sin \left( \frac{3 \pi}{4} \right)}
\end{align*}
You then just substitute ##\sin \left( \frac{3 \pi}{4} \right) = \frac{1}{\sqrt{2}}## into it to obtain the desired result.
Likes FactChecker, Teymur and SammyS
Appreciate all the support
Likes julian
