Residue Theorem applied to a keyhole contour
The discussion focuses on applying the residue theorem to evaluate a closed contour integral using a keyhole contour. The participants identify singularities at the poles, specifically at ##z=\frac{-\sqrt{2}+i\sqrt{2}}{2}## and ##z=\frac{-\sqrt{2}-i\sqrt{2}}{2}##. They emphasize the importance of calculating residues at these simple poles and confirm that the integral can be expressed as ##2\pi i## times the sum of these residues. The final result simplifies to ##2^{\frac{1}{2}}\sin\left(\frac{3\pi}{8}\right)##, demonstrating the relationship between the residues and the sine function.
  • Understanding of complex analysis, specifically the residue theorem.
  • Familiarity with contour integration and keyhole contours.
  • Knowledge of calculating residues for simple poles.
  • Ability to manipulate complex numbers and functions, including the use of the sine function in exponential form.
  • Study the properties of the residue theorem in complex analysis.
  • Learn about keyhole contours and their applications in contour integration.
  • Practice calculating residues for various types of poles, including simple and higher-order poles.
  • Explore the relationship between complex exponentials and trigonometric functions, particularly in the context of integrals.
Students and professionals in mathematics, particularly those specializing in complex analysis, as well as physicists and engineers dealing with integrals in the complex plane.
Teymur
Use the Residue Theorem to show:
$$\int \:\frac{z^{\frac{1}{2}}}{1+\sqrt{2}z+z^2}dz=2^{\frac{2}{3}}\pi isin\left(\frac{8\pi }{3}\right)$$
for a keyhole contour where ##z=re^{i\theta }## and ##-\pi <\theta <\pi##
the standard residue theorem
I'm really struggling with this one. A newbie to using the residue theorem. I'm trying to solve this by factorising the denominator to find values for z0 and I have:
I also know that sin(3π/8)= ##\frac{\sqrt{2+\sqrt{2}}}{2}##
Show us residues you calculated, please.
The path of integration is not clear to me. I can make a guess, but it is better if you spell it out. What is the multiplier 'a'? What is a "keyhole contour"?
Hello,
Thanks for the responses. The integral is a closed contour integral (with a branch cut along the negative x-axis so the function is not multi-valued) but I couldn't find the correct symbol with the integral sign having a circle. The residue theorem states that in place of calculating the integral explicitly, it is equivalent to 2*pi*i*sum of residues.
I haven't that's the problem. The first step, in the process I'm familiar with, is to factorise the denominator so that you can find values of z for which their are isolated singularities. I've tried to do that and I've given my results in the original post. Not sure where to go next..
p.s. I'm aware you can use the Laurent series, but my series expansion knowledge isn't great. Hence I'm trying to compute this using poles.
the "a" was a mistake, sorry. I've removed it
This is an example:
These are simple poles, so what's the procedure for calculating the residue of a simple pole?
Please correct the typos in your work. There's a fairly obvious one, but I suspect there are more.
Ah yes, so sorry!! The integral should give:
$$2^{\frac{3}{2}}\pi \:isin\left(\frac{3\pi }{8}\right)$$
I got the numerators and denominators mixed up! Soz
Yes exactly, simple poles. Firstly, I'm just checking to see if the values I have obtained for z0 at the poles are correct, they seem unwieldly. If they are correct, you multiply f(z) by (z-z0) and evaluate the result at =z0.. I've tried to do that but can't see how it would get you to the intended outcome.
The values of ##z_0## seem right. What are they in polar form?
You can always check them by plugging them back into the quadratic and seeing if the result is 0. They are indeed a bit unwieldy for some parts of the calculation. As @julian suggested, you'll find it convenient to express them in polar form.
Teymur said:
If they are correct, you multiply f(z) by (z-z0) and evaluate the result at =z0. I've tried to do that but can't see how it would get you to the intended outcome.
Post what you get. Remember you have two poles, so it's the sum that will produce the result you want.
Okay cool. Am I right that you get:
$$\cos \left(\frac{\pi }{4}\right)+isin\left(\frac{\pi }{4}\right)=e^{\frac{i\pi }{4}}$$
and
$$\cos \left(\frac{3\pi i}{4}\right)+isin\left(\frac{3\pi i}{4}\right)=e^{\frac{3\pi i}{4}}$$
And if so, is the next step:
$$\left(z-e^{\frac{\pi i}{4}}\right)f\left(z\right)=\left(z-e^{\frac{\pi i}{4}}\right)\frac{z^{\frac{1}{2}}}{\left(z-e^{\frac{\pi i}{4}}\right)\left(z-e^{\frac{3\pi i}{4}}\right)}$$
For ##z=e^{\frac{\pi i}{4}}##
$$\frac{e^{\frac{\pi i}{8}}}{\left(e^{\frac{\pi i}{4}}-e^{\frac{3\pi i}{4}}\right)}$$
The first one isn't correct, but the second one is. (Just check the signs.) Note that because the coefficients in the quadratic are real, the roots will be complex conjugates of each other. So this means the other root is ##e^{-3\pi i/4}##.
The next step will look okay once you fix the roots. I'd note it's a limit as ##z \to z_0##.
You mean that the roots are ##e^{\frac{3\pi i}{4}}## and ##e^{\frac{-3\pi i}{4}}##?
Are you saying:
$$\left(z-e^{\frac{3\pi i}{4}}\right)f\left(z\right)=\left(z-e^{\frac{3\pi i}{4}}\right)\frac{z^{\frac{1}{2}}}{\left(z-e^{\frac{3\pi i}{4}}\right)\left(z-e^{\frac{-3\pi i}{4}}\right)}$$
so that as z goes to z0:
$$\frac{e^{\frac{3\pi i}{8}}}{\left(e^{\frac{3\pi i}{4}}-e^{\frac{-3\pi i}{4}}\right)}$$
Teymur said:
Are you saying:
Do the same thing with the root ##e^{-\frac{3\pi i}{4}}##. Add the two residues, then multiply by ##2 \pi i##.
working backwrads from the solution given in the question and putting aside the prefactor of ##2\pi i## that comes from the theorem, that means that the sum of the residues should give ##2^{\frac{1}{2}}sin\left(\frac{3\pi }{8}\right)##
I can't see how to get there from:
$$\frac{e^{\frac{3\pi \:i}{8}}}{e^{\frac{3\pi \:i}{4}}-e^{-\frac{3\pi \:i}{4}}}+\frac{e^{\frac{-3\pi \:i}{8}}}{e^{\frac{-3\pi \:i}{4}}-e^{\frac{3\pi \:i}{4}}}$$
I'm assuming the following identity has something to do with it, but can't seem to put it all together:
$$sin\left(x\right)=\frac{e^{ix}-e^{-ix}}{2i}$$
The denominator of the 2nd term is the negative of the denominator of the first term. That allows you to write your expression as a single fraction.
And then, yes, you use ##\sin (x) = \frac{e^{i x} - e^{-i x}}{2i}##.
I get the feeling this isn't the best way to simplify but what I get is as follows:
$$\frac{sin\left(\frac{3\pi }{8}\right)}{sin\left(\frac{3\pi }{4}\right)}=\sqrt{\frac{2+\sqrt{2}}{2}}$$
If you then multiply through by ##2^{\frac{1}{2}}## you get:
$$2^{\frac{1}{2}}\frac{\sqrt{2+\sqrt{2}}}{2}=2^{\frac{1}{2}}sin\left(\frac{3\pi \:}{8}\right)$$
as required. If there's a simpler, straightforward way to do this, I'd be grateful to hear.
The sum of residues is indeed equal to:
\begin{align*}
\dfrac{\sin \left( \frac{3 \pi}{8} \right)}{\sin \left( \frac{3 \pi}{4} \right)}
\end{align*}
You then just substitute ##\sin \left( \frac{3 \pi}{4} \right) = \frac{1}{\sqrt{2}}## into it to obtain the desired result.
Appreciate all the support
  • · Replies 17 ·
  • · Replies 34 ·
  • · Replies 22 ·
