CMOS Resistance: Drawing NAND & Solutions
  • Thread starter Thread starter nobrainer612
    Cmos Resistance
The discussion focuses on calculating the resistance in a CMOS NAND gate configuration. When both inputs A and B are high (value 1), the total resistance is Rn + Rn, as both NMOS transistors are in series. When both inputs are low (value 0), the resistance is calculated as Rp/2, since both PMOS transistors are in parallel. If A is high and B is low, the output is VDD (value 1), and the resistance is simply Rp, as the PMOS is active while the NMOS is off.
  • Understanding of CMOS technology and transistor operation
  • Familiarity with resistance calculations in series and parallel circuits
  • Knowledge of NMOS and PMOS transistor characteristics
  • Basic algebra for simplifying resistance equations
  • Study the operation of CMOS NAND gates in detail
  • Learn about resistance calculations in digital circuits
  • Explore the impact of transistor sizing on resistance in CMOS designs
  • Investigate the behavior of other CMOS logic gates under varying input conditions
Electrical engineers, students studying digital electronics, and professionals designing integrated circuits will benefit from this discussion.
nobrainer612
I drew a NAND in the picture.
I know when A and B are both high ( value 1), resistance will be Rn + Rn because those 2 NMOS will be turned on and resistance will added up since they are in series.
Also when A and B are both low ( value 0), both PMOS will be turned on. My first question is, 1.) is the resistance become Rp*Rp/(Rp + Rp) because they are in parallel?
My second question is, if A is high (value 1) and B is low ( value 0) , output should be VDD ( value 1). But what will be resistance be? I think they are neither in series nor parallel. So will the resistance only become Rp ?
Hope somebody can share their ideas. Thank you
Hi nobrainer612! Those would be my answers, too.
Can you simplify this expression: Rp*Rp/(Rp + Rp) :wink:
sorry but I don't get what you mean.
Can you tell me if those I assumed are correct? because I am interested what the resistance is .
simplify this expression: Rp*Rp/(Rp + Rp) : isn't that equal (Rp^2) / 2*Rp = Rp/2?
So what I assumed:
if A is high (value 1) and B is low ( value 0) -----> resistance = Rp only? :bugeye:
Also when A and B are both low ( value 0) -----> resistance = Rp/2 ? :shy:
nobrainer612 said:
if A is high (value 1) and B is low ( value 0) -----> resistance = Rp only? ✔[/size][/color]
Also when A and B are both low ( value 0) -----> resistance = Rp/2? ✔[/size][/color]
:smile:
10K
