Calculating Resistance of Coaxial Cable with Isolator
The problem involves calculating the resistance of a coaxial cable with a copper core and shield, separated by an isolator with specific resistance. The original poster is attempting to understand the relationship between the resistance, the dimensions of the cable, and the properties of the materials involved.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the formulation of resistance in terms of geometry and material properties, with some questioning the integration approach and the definitions of area and length in the context of coaxial geometry.
The discussion is ongoing, with participants exploring different interpretations of the resistance calculation. Some guidance has been offered regarding the integration of resistance elements, but there is no explicit consensus on the correct approach or understanding of the area involved.
There are indications of confusion regarding the definitions of area and length in the context of coaxial cables, as well as the distinction between specific resistance and resistivity. The original poster also expresses uncertainty about the integration limits and the physical meaning of the variables involved.
bolzano95
Coaxial cable has radius a of copper core and radius b of copper shield. Between there is an isolator with specific resistance ζ. What is the resistance of this cable with length L between the core and the shield?
First, I tried to solve this like this:
R= ζ \cdot \frac{l}{S}
In our case the length is dr, and therefore I suppose that the area of this ring is 2πrdr:
dR= ζ \cdot \frac{dr}{2πrdr}
The solution sheet says: dR= ζ \cdot \frac{dr}{2πrL}
I know that something is wrong with my equation, because dr goes away and then I cannot integrate from a to b. But why is in the solution L instead of dr? As I understand problem instruction L= b-a. And therefore L=dr which doesn't make sense to me.
The current flows in the radial direction. A volume element is ##dV=rdrd\theta dz.## The resistance of this is ##dR=\frac{\zeta dr}{rd\theta dz}## I would integrate over ##r## first to get the resistance of a radial sliver, ##dR_{sliver}##. I can do that because the stacked elements ##dV## in the radial direction are in series and their resistances add. Then note that all such slivers are in parallel which is how they should be added.
should be ".. insulator with specific resistivity ... "
True. Insulator with specific resistivity ζ. Thanks.
I got an answer from fellow student that the area of the element is 2πrL and the thickness of the element is dr. But I wouldn't say so. I would suppose that the area of the element is 2πrdr. What am I missing?
Please read and understand post #2 to see what you are missing.
  • · Replies 16 ·
  • · Replies 26 ·
