Undergrad Resolve the Recursion of Dickson polynomials
pawlo392
I am trying to prove the expression for Dickson polynomials:
$$D_n(x, a)=\sum_{i=0}^{\lfloor \frac{n}{2}\rfloor}d_{n,i}x^{n-2i}, \quad \text{where} \quad d_{n,i}=\frac{n}{n-i}{n-i\choose i}(-a)^i$$
I am supposed to use the recurrence relation:
$$D_n(x,a)=xD_{n-1}(x,a)-aD_{n-2}(x,a)$$
I have tried to use induction to prove this, but I am having trouble. Here's what I have so far:
Base case: For ##n=1##, we have:
$$D_1(x,a)=x$$
which matches the expression for ##D_n(x,a)## when ##n=1##. So the base case holds.
Inductive step: Assume that the expression for ##D_n(x,a)## holds for some ##n \geq 1##. We want to show that it also holds for ##n+1##.
From the recurrence relation, we have:
$$D_{n+1}(x,a) = xD_n(x,a) - aD_{n-1}(x,a)$$
Substituting the expression for ##D_n(x,a)## and ##D_{n-1}(x,a)##, we get:
\begin{align*}
D_{n+1}(x,a) &= xD_n(x,a) - aD_{n-1}(x,a) \\
&= x\sum_{i=0}^{\lfloor \frac{n}{2}\rfloor}d_{n,i}x^{n-2i} - a\sum_{i=0}^{\lfloor \frac{n-1}{2}\rfloor}d_{n-1,i}x^{n-1-2i} \\
&= \sum_{i=0}^{\lfloor \frac{n}{2}\rfloor}d_{n,i}x^{n-2i+1} - \sum_{i=0}^{\lfloor \frac{n-1}{2}\rfloor}d_{n-1,i}ax^{n-1-2i} \\
&= \sum_{i=0}^{\lfloor \frac{n}{2}\rfloor}d_{n,i}x^{n-2i+1} - \sum_{i=1}^{\lfloor \frac{n}{2}\rfloor}d_{n,i-1}ax^{n-2i+1} \\
\end{align*}
Now, I am stuck here and not sure how to proceed. Can someone please provide some guidance or hints on how to continue with the proof? Thanks in advance.
If you do use induction, then your base case is to show that the result holds for n = 0 and n = 1, and your inductive hypothesis is that if the result holds for n and n-1 then it holds also for n + 1. That will invole some manipulation of binomial coefficient identities.
However, there may be an easier way. The recurrence <br /> D_n(x,a) = xD_{n-1}(x,a) - aD_{n-2}(x,a) subject to D_0(x,a) = 2, \qquad D_1(x,a) = x is a constant coefficient linear recurrence for D_n(x,a) in terms of n. It is straightforward to solve this recurrence and show directly that the resulting expression for D_n(x,a) is of the required form.
I've encountered a few different definitions of "indefinite integral," denoted ##\int f(x) \, dx##. any particular antiderivative ##F:\mathbb{R} \to \mathbb{R}, F'(x) = f(x)## the set of all antiderivatives ##\{F:\mathbb{R} \to \mathbb{R}, F'(x) = f(x)\}## a "canonical" antiderivative any expression of the form ##\int_a^x f(x) \, dx##, where ##a## is in the domain of ##f## and ##f## is continuous Sometimes, it becomes a little unclear which definition an author really has in mind, though...
  • · Replies 16 ·
