Calculating Horizontal Distance Between Two Hot Air Balloons | Vectors Problem"
  • Thread starter Thread starter hannah2329
    Vectors
To calculate the horizontal distance between two hot air balloons at heights of 48.8 meters and 52.2 meters, one balloon observer notes the other is at a 13.3-degree angle above the horizontal. The challenge lies in visualizing the problem and correctly positioning the angle within a right triangle formed by the heights and the horizontal distance. A diagram can aid in understanding how to set up the triangle for calculation. Once the triangle is established, trigonometric functions can be applied to find the horizontal distance. Clear visualization and proper use of trigonometry are essential for solving this problem.
hannah2329
two hot air balloons are 48.8 and 52.2 meters above the ground. a person in the left balloon observes that the right balloon is 13.3 deg above the horizontal. what is the horizontal distance between the two balloons?
im stuck on how to draw the picture and where to put the 13.3 degrees. if you could attach something of what it is supposed to look like that would be helpful. i can figure out how to make a triangle
[PLAIN]http://img530.imageshack.us/img530/4264/balloon.jpg
Thank you! I understand.
10K
