Why Can't the Resultant Force Be 0.5N When Two Forces Act on an Object?
The resultant force acting on an object subjected to two forces of 3.0N and 4.0N cannot be 0.5N due to the principles of vector addition. The minimum resultant force occurs when the two forces act in opposite directions, yielding a net force of 1.0N (4.0N - 3.0N). The maximum resultant force is 7.0N (4.0N + 3.0N). Therefore, 0.5N is not a valid resultant force as it falls outside the range defined by the vector addition of the two forces.
  • Understanding of vector addition in physics
  • Basic knowledge of force and resultant force concepts
  • Familiarity with the triangle inequality theorem
  • Ability to visualize forces as vectors acting on an object
  • Study vector addition and resultant forces in physics
  • Learn about the triangle inequality theorem and its applications in physics
  • Explore the concept of force diagrams and how to draw them
  • Investigate the effects of angle on resultant forces in two-dimensional vector scenarios
Students studying physics, educators teaching force concepts, and anyone interested in understanding vector addition and resultant forces.
monkeysay
Hello everyone. :)
I encountered this question during my revision and can't remember how I got it correct.
"A force of 3.0N and a force of 4.0N act on an object at the same time. Which of the forces cannot be the resultant force on the object?"
There are 4 options (0.5N, 3.5N, 4.0N, 5.0N)
I chose 4.0N but the correct answer is 0.5N.
Can someone explain why my answer is wrong and why 0.5N is correct? Thanks in advance.
Hello,
By resultant force you mean net force, right?
In that case, think of forces as vectors. Draw it out, pretend like the forces act on a box. Then think of triangles. If you know 2 sides of a triangle, what length can the other side be? What inequalities apply to the length of the unknown side of the triangle?
do the forces act on the object horizontally or vertically or one of each? if its one of each you could construct a right angled triangle and use pythagoras' a^2 + b^2 = c^2
Hello John, thanks for the reply.
I still don't understand why 0.5N cannot be a possible net force. Can't the resultant arrow be small if you have the opposite angle small as well?
I don't understand how the other force of 3.0N can act to achieve 4.0N only. Where would it act upon?I hope you won't find it too hard to explain, I am pretty bad at physics I admit. Thanks again!
Hello Rory, for the question the forces can act anywhere.
Thus I don't think Pythagoras theorem can be used since the vectors need not form a right angle.
oh right, hmmm in that case I am not totally sure.sorry for the lack of help!
Hint: For the two forces to add up to the maximum value, how would they have to point with respect to each other? What about to get the minimum value? (Once you have max and min, the actual value can be anything in between, depending on the angle between the vectors.)
I wouldn't trust Yahoo Answers. I have seen a lot of satirical and nonsensical answers get voted as the "Best".
Well I take answers there with a pinch of salt. Some of them frequent there to tout their products or give nonsensical and irresponsible comments.
But if you look at the discussion I linked to, I thought the replies I got were pretty decent.
And if you think there are no best answers, as an answerer, you have the choice to select No Best Answer.But this isn't really the place to discuss the validity of Yahoo Answers is it? =p
  • · Replies 19 ·
  • · Replies 20 ·
12K
