Reverse gear on manual transmission cars
33 replies · 42K views
Well in the quote you can see I used "code" tags, which are probably designed to ignore processing codes.
See if this worx:
Code:
[*code]text                   spaces
         more space[/*code]
No it doesn't. So I added *'s to deactivate the code code
Okay... that is far too complicated for me. Next time something like this rolls around, I'll just whomp up a pic and then post an ImageShack link.
[noparse]
Code:
[/noparse] is for code (like program source), to not process the text you should use [noparse][noparse][/noparse][/noparse].
However, [noparse][noparse][/noparse] means that tags and urls will be ignored. It doesn't mean white space will be displayed as entered, as these are different levels of processing - white space is combined on the HTML level, while [noparse][noparse][/noparse] stops processing of the post on the vBulletin level.
Thanks for that total lack of an explanation that I can understand. :biggrin:
I think that I'll stick with ImageShack.
