Reverse the elements in a given array
3 replies · 2K views
Fatima Hasan
Write a sequence of statements to REVERSE the elements of array X1.
Here's my work :
Could somebody check my answer please ?
scottdave said:
Is this assembly?
yes
Your code doesn't work, but you're not far off.
It looks like you are setting up a loop to run 5 times, and you have a label at the start of your loop, but you are missing a loop statement at the bottom of the loop body, and whose target is the label. After you fix that, I believe your code will do what it's supposed to do.
When you get your code to run, you really should use your debugger to see if the program is working correctly. Set a breakpoint on the first line after the loop statement, and inspect the contents of the array. After the loop finishes the array contents should be 1ah, 90h, 80h, ..., 10h.
