Reversible Adiabatic Process Question
The forum discussion centers on calculating the work done during a reversible adiabatic expansion of an ideal gas. The initial conditions include a temperature of 300K, a volume of 15L, and a pressure of 15 atm, with a target pressure of 10 atm. The user initially miscalculated the work using incorrect assumptions about temperature changes, but later confirmed the correct approach involves using the formula W = nC_vΔT, where Cv = 1.5R and gamma = 5/3. The final work done is established as 5130 J.
  • Understanding of ideal gas laws and equations (P = nRT/V)
  • Knowledge of thermodynamic processes, specifically adiabatic processes
  • Familiarity with the concept of internal energy and its relation to work
  • Ability to perform unit conversions (e.g., L to m³, atm to pascals)
  • Study the derivation and applications of the adiabatic process equations
  • Learn about the implications of the first law of thermodynamics in adiabatic processes
  • Explore the concept of gamma (γ) in thermodynamics and its significance
  • Investigate the relationship between work, internal energy, and temperature changes in ideal gases
Students studying thermodynamics, physics enthusiasts, and professionals in engineering fields focused on gas dynamics and energy systems.
kalbuskj31
An Ideal Gas at 300K has a volume of 15L and a pressure of 15 atm. Calculate the change when the system goes under a reversible adiabatic expansion to a pressure of 10 atm. Gamma = 5/3. Cv = 1.5R. q = 0(definition of adiabatic processes).
dw = P DV (lowercase means squiggly d and uppercase means straight d)
P = nRT/V
The answer in the book says w = 5130 J, which is the opposite of what I got for the internal energy.
First, I calculated n: n = PV/RT = 15 atm * 15 L / .08206 (L*atm / K * mole) * 300K
n = 9.14 moles
Then, I calculated Vf: Vf = [(Pf * Vi ^ (5/3)) / (Pf)] ^ 3/5
Vf = 19.13 L
dW = P DV
dw = NRT (dw = P DV so then work = NRT * Integral [DV/V]) ****This is wrong since T changes temperature between states*****
w = nRT ln(Vf/Vi)
Plugged in everything and the answer didn't turn out.
Your method looks to be fine, so you might want to consider the units. Rather than L, convert to m^3, and instead of atm, convert to pascals.
Thanks for taking a look at the problem Gear300. The problem I found with my logic is that P, V, and T all are changing from state 1 to state 2 so I have to use the Internal Energy formula reversing the temperature. (i.e. Ti - Tf).
w = nRT ln(Vf/Vi)
Not sure what the question is. Are you trying to find the work done? Find the change in temperature and use:
W = \Delta U = nC_v\Delta T
AM
andrew,
That's what I ended up doing to get the answer.
10K
