Reversible vs irreversible work for adiabatic process
The discussion revolves around the net work done on a gas during an adiabatic process, specifically comparing reversible expansion and irreversible compression. Participants explore the implications of these processes on energy changes and the conditions required to return to the initial state.
  • One participant describes a gas transitioning adiabatically between two states and attempts to calculate the net work done during reversible expansion and irreversible compression, noting a discrepancy in energy changes.
  • Another participant questions whether the problem is original or sourced from a textbook, prompting further exploration of the scenario.
  • A participant identifies a flaw in the initial logic, stating that irreversible compression at constant pressure will not allow the gas to return to its original state, as it will equilibrate at a volume greater than the initial volume.
  • Further clarification is sought regarding the relationship between volume and temperature during irreversible compression, with a focus on whether friction contributes to an unexpected increase in temperature.
  • Responses confirm that the increase in temperature during irreversible compression is indeed due to viscous dissipation.
  • A participant encourages the original poster, acknowledging the complexity of the problem and referencing additional resources for understanding reversible versus irreversible processes.
Participants express differing views on the implications of irreversible compression and whether the initial state can be reached under those conditions. There is no consensus on the resolution of the discrepancies in energy calculations.
The discussion highlights assumptions regarding the behavior of gases during adiabatic processes, particularly the effects of reversibility and irreversibility on work and energy changes. Limitations in the initial logic and the dependence on specific conditions are noted but remain unresolved.
Andrew U
I have a gas transitioning adiabatically between A (P1, V1) and B (P2, V2) where P1>P2 and V2>V1. The question is to determine the net work done on the gas if the gas is first expanded reversibly from A to B (w = dE = Cv(T2-T1)), and then compressed irreversibly from B to A (w = -Pext(V1-V2)) at a constant external pressure defined by A. In this scenario, simply looking at the areas under the graphs the net work should be positive.I am trying to reconcile this with dE for the gas. For the roundtrip transition (A to B to A), dE = 0. And if we take each step as adiabatic, then dE = w for each step, but as I have described above you would end up with two different values for dE for each step, thus dE not equal to zero. My logic is flawed somewhere, can someone help?
Is this a problem you invented yourself, or is it out of a book?
Chet
The flaw in the logic is this: If you try to recompress irreversibly at constant P1, you will re-equilibrate at a volume greater than V1 before ever reaching V1. So, you won't be able to reach the initial state in this adiabatic irreversible recompression. You can calculate what final volume and final temperature the system reaches by irreversibly recompressing at P1. The only way you can back to the initial state adiabatically is if you do it reversibly.
Hi Chet, thanks! I invented this one (and obviously missed an important point). So if I end up at a larger volume, then my temperature must also be higher, correct? Is this because of friction during the irreversible compression?
Clarification: When I ask about the increase in temperature, I am referring to an additional increase that is larger than one would normally expect for an adiabatic compression, thus leading to a larger final volume.
Yes.
Yes. Viscous dissipation.
Don't despair. You invented a very interesting problem. I've seen other versions of this before.
For more details in irreversible vs reversible processes, see my Physics Forums Insights article: https://www.physicsforums.com/insights/reversible-vs-irreversible-gas-compressionexpansion-work/
  • · Replies 60 ·
11K
  • · Replies 22 ·
  • · Replies 27 ·
10K
