Finding Initial Velocity Components of a Projectile Using Kinematic Equations
The discussion focuses on calculating the initial velocity components of a projectile using kinematic equations. The projectile is displaced 40 m horizontally and 53 m vertically after 2 seconds. The horizontal component of the initial velocity was determined, but the vertical component remains unclear. The key formula to use is derived from the kinematic equation, specifically relating initial velocity, displacement, and time, which allows for the calculation of the vertical component using the known values at t = 2 seconds.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion concepts
  • Familiarity with uniform acceleration
  • Basic algebra for solving equations
  • Study the derivation and application of the kinematic equation: vi = (y - 0.5at^2)/t
  • Learn how to analyze projectile motion using time of flight and maximum height
  • Explore the effects of gravity on vertical motion in projectile problems
  • Practice solving similar projectile motion problems with varying initial conditions
Students studying physics, particularly those focusing on kinematics and projectile motion, as well as educators looking for examples to illustrate these concepts.
Bashyboy
b]1. Homework Statement [/b]
1. Two seconds after being projected from ground level (y=0 m), a projectile is displaced
x=40 m horizontally and y=53 m vertically above its launch point. What are the (a) horizontal
and (b) vertical components of the initial velocity v of the projectile? (c) At the instant the
projectile achieves its maximum height above ground level, how far is it displaced horizontally
from the launch point?
I am working on part a). I was able to determine the horizontal component; however, I am unable to ascertain the vertical component of velocity. I tried applying kinematic equations, but with no avail. I tried to employ a symmetry argument, by finding the velocity acquired as the projectile falls to Earth from a vertical distance of 53 m, but then I realized that I don't know the velocity at this point, nor can I suppose that the speed is zero, because it isn't.
What should I do?
There is a formula relating initial velocity, uniform acceleration, displacement and time. You know three of these, thus should be able to find out the remaining unknown.
Are you speaking of this formula: vi = (y -.5at^2)/t. If so, how can I apply it when I need to set t = 0, in order to determine the initial velocity?
At what value of ##t## do you know ##y##? Why would you let ##t = 0## instead?
I figured that I would set t = 0, because that is the instant whose velocity I am trying to find.
At ## t = 0 ##, ## y = 0 ##, so your equation is ## 0 = v_i \cdot 0 - g \cdot 0^2 / 2 ##, which is useless. But you are given data at ## t ## different than 0, so use that.
  • · Replies 26 ·
