Reynolds Transport Theorem derivation question
The discussion centers on the derivation of the Reynolds Transport Theorem, specifically the transition from the partial derivative of a vector field to the material derivative. The user questions why sources replace the partial derivative \(\frac {\partial f} {\partial t}\) with the material derivative \(\frac {Df} {Dt}\). It is clarified that the material derivative is applicable when dealing with a material fluid, which is a function of initial position and time, while a control volume requires the use of the partial derivative. This distinction is crucial for correctly applying the theorem to both scalar and vector fields.
  • Understanding of Reynolds Transport Theorem
  • Familiarity with vector calculus
  • Knowledge of material and partial derivatives
  • Basic concepts of fluid dynamics
  • Study the derivation of the Reynolds Transport Theorem in detail
  • Learn about the differences between material and partial derivatives in fluid dynamics
  • Explore applications of the Reynolds Transport Theorem to both scalar and vector fields
  • Investigate examples of control volumes in fluid mechanics
Students and professionals in fluid dynamics, physicists, and engineers who are looking to deepen their understanding of the Reynolds Transport Theorem and its applications in both scalar and vector fields.
Rearden
Hi,
I'm struggling to understand one step in the derivation of the Reynold's Transport Theorem. I get as far as:
\begin{equation}
\frac{d}{dt} \int_{V(t)} f(\mathbf x, t) \, dV = \frac {d} {dt} \int_{V_0} f(\mathbf X,t) J(\mathbf X,t) \, dV = \int_{V_0} J \frac {\partial f} {\partial t} + f \frac {\partial J} {\partial t} \, dV
\end{equation}
From here, I want to write the RHS as:
\begin{equation}
\int_{V_0} \frac {\partial f} {\partial t} J + f \, ({\nabla \cdot} {\mathbf v}) J \,\, dV = \int_{V(t)} \frac {\partial f} {\partial t} + f \, ({\nabla \cdot} {\mathbf v}) \,\, dV
\end{equation}
However, all of my sources inexplicably replace the \begin{equation} \frac {\partial f} {\partial t} \end{equation} with a \begin{equation} \frac {Df} {Dt} \end{equation} Could anyone explain their reasoning or my error?
Thanks!
\begin{equation} \frac {Df} {Dt} \end{equation} is just the material derivative (the derivative with respect to time while keeping the initial position constant).
But isn't the material derivative given by the total derivative wrt time, \begin{equation} \frac {df} {dt} = \frac {\partial f} {\partial t} + (\mathbf v \cdot \nabla) f \end{equation} whereas the integrand over the control volume just contains a partial derivative?
Yes, it is if f is a scalar field. But in the Reynolds transport theorem, f is a vector field. For a vector field V, the material derivative is defined as follows:
\begin{equation} \frac {Df} {Dt} = \frac {\partial V} {\partial t} + (\mathbf V \cdot \nabla) V \end{equation}
Afraid I still don't follow. Why is the material derivative involved at all? In the ordinary course of physics we never swap a partial derivative for a total derivative, and as I understand it, the material derivative gives:
\begin{equation}
\frac {df(\mathbf x (\mathbf X,t),t)} {dt}
\end{equation}
which is not the integrand. I'm fairly certain the transport theorem is equally valid for scalars and vectors, so that shouldn't have made a difference either.
You are taking the material derivative because the volume is a material fluid (a function of initial position and time where there is no flux of mass) as opposed to a control volume which is just a function of position with a fixed volume. Basically, you can still use the transport theorem on a control fluid, you just need to take the partial derivative instead of the material derivative. The same thing goes for a scalar field; the theorem is still applicable, you just need to consider that when deriving it.
Thanks for pointing out that distinction, it clears things up.
Glad to be of assistance.
  • · Replies 22 ·
