Ricci tensor equals zero implies flat splace?
The Ricci tensor equaling zero does not imply a flat Riemannian manifold. There exist both compact and non-compact Ricci flat manifolds that cannot be endowed with flat Riemannian metrics. For compact manifolds, a flat Riemannian metric necessitates a zero Euler characteristic, as the Euler class is a polynomial function of the curvature 2 form. Notably, Calabi-Yau manifolds can exhibit non-zero Euler characteristics, demonstrating the complexity of this relationship.
  • Understanding of Ricci tensor and its implications in differential geometry
  • Familiarity with Riemannian and semi-Riemannian manifolds
  • Knowledge of Euler characteristic and its relation to curvature
  • Basic concepts of Calabi-Yau manifolds and their properties
  • Research the properties of Ricci flat manifolds
  • Study the relationship between curvature and Euler characteristic in compact manifolds
  • Explore the implications of the Ricci decomposition in geometry
  • Investigate the role of gravity in curving vacuum spaces in semi-Riemannian geometry
Mathematicians, physicists, and students of differential geometry seeking to deepen their understanding of the implications of the Ricci tensor in manifold theory.
Abrahamsk8
Hi, my question is the title, if Ricci tensor equals zero implies flat space? Thanks for your help
If by flat space you mean a flat Riemannian manifold, the answer is no. There are examples of both compact and non-compact Ricci flat manifolds that cannot be given flat Riemannian metrics.
One thing to note is that for compact manifolds,a flat Riemannian metric implies that the Euler characteristic is zero - because the Euler class can be expressed as a polynomial in the curvature 2 form. If you look around you will find Calabi -Yau manifolds with non-zero Euler characteristic.
As a physics application, in the semi-Riemannian case, a vacuum has a Ricci tensor equal to zero. A vacuum doesn't have to be flat. A vacuum be curved by gravity. An example would be the space above the Earth's surface where you're sitting right now.
  • · Replies 37 ·
10K
  • · Replies 31 ·
