Undergrad Components of Riemann Tensor: 4 Indexes, 16x16 Matrix
The Riemann tensor, denoted as ##R^i_{jkl}##, consists of four indices and can be represented as a 16x16 matrix in spacetime, incorporating one time coordinate and three spatial coordinates. However, due to the complexity of the tensor's structure, it is more accurate to describe it as a 4x4x4x4 tensor. The discussion emphasizes that while a matrix representation is possible, it is essential to maintain consistent index types (either all upper or all lower) to preserve the tensor's properties. The skew symmetries of the Riemann tensor allow for a reduction to a 6x6 symmetric matrix, which can be further decomposed into three 3x3 matrices, known as the Bel decomposition, with specific tensors representing electrogravitic and topogravitic components.
  • Understanding of Riemann curvature tensor and its indices
  • Familiarity with tensor algebra and matrix representations
  • Knowledge of general relativity concepts, particularly the Bianchi identity
  • Experience with mathematical notation in physics, specifically LaTeX
  • Study the properties and applications of the Riemann curvature tensor in general relativity
  • Learn about the Bel decomposition and its significance in gravitational theories
  • Explore the implications of skew symmetries in tensor calculus
  • Investigate the Bianchi identity and its role in reducing degrees of freedom in tensors
Physicists, mathematicians, and students specializing in general relativity, tensor calculus, and differential geometry will benefit from this discussion, particularly those interested in the intricacies of the Riemann tensor and its applications in theoretical physics.
Z3kr0m
Hello, Riemann tensor ##R^i_{jkl}## 4 indexes, and it should be matrix 16x16 in spacetime if we have time coirdinate - 0 and space coordinates -1,2,3. But how should I write the components to matrix? For example ##\begin{pmatrix}R^0_{000} & R^1_{000} & R^2_{000} ... \\ R^0_{100} & R^1_{100} & R^2_{100} ...\\ R^0_{200} & R^1_{200} ... \\ R^0_{300} ... \end{pmatrix}##?
You can't. The two-dimensional matrix representation only works for rank-two tensors (those with only two indices). Even then you have to be alert to whether you are representing the components of the tensor with contravariant or covariant (upper or lower) indices - this information is lost in the matrix representation, so it's best to avoid it altogether.
So I must write out the components one by one?
Yes, but you have to do that whether you're arranging the values you're writing down in a matrix or not.
It's not really a matrix, its a 4x4x4x4 tensor. But if you group the first two componetns together, and the last two, you can write the 256 element tensor as a 16x16 matrix.
I've only seen discussions (in MTW's "Gravitation") of ##R_{ijkl}## and NOT ##R^i{}_{jkl}## however. To take advantage of the skew symmetries ##R_{ijkl} = -R_{jikl} = -R_{ijlk}## https://en.wikipedia.org/wiki/Riemann_curvature_tensor#Symmetries_and_identities, I believe one needs the indices to be all lower, or all upper, not mixed. It is possible I am mistaken.
If one does consider the all-lower index ##R_{ijkl}##, the skew symmetries imply that ##R_{00**} = R_{11**} = R_{22**} = R_{33**} = 0##, i.e. any repeated index in the first pair must be zero. A similar argument leads to the same conclusion for repeated indices in the last pair. This lowers the Riemann to a 12x12 matrix by dropping the 4 zero diagional elelents, , and a further reduction to a 6x6 matrix by only specifying ##R_{ij**}## where i<j, as ##R_{ji**} = -R_{ij**}##.
The natural pair-groupings are (0,1), (0,2), (0,3) and their duals *(0,1) = (2,3), *(0,2) = (1,3), *(0,3)=(1,2) in a coordinate or orthonormal basis.
Using this approach, the 256 element tensor becomes a 6x6 symmetric matrix, where the symmetry comes from the "interchange symmetry", ##R_{ijkl} = R_{klij}##.
This can be further decomposed into three (in GR) 3x3 matrices Wiki calls this the Bel decomposition, https://en.wikipedia.org/wiki/Bel_decomposition, MTW does a similar decomposition but doesn't use this name to describe it.
Two of the 3x3 matrices from this decomposition are symmetric, the so-called electrogravitc and topogravitc tensors. This is a total of 21 degree of freedom, there is one additional constraint due to the Bianchi identity that reduces the degrees of freedom of the Riemann to 20.
Likes PeterDonis
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 19 ·
