Riemann tensor cyclic identity (first Bianchi) and noncoordinate basis
The discussion focuses on the cyclic sum identity of the Riemann curvature tensor, specifically the first Bianchi identity, expressed as {R^\alpha}_{[ \beta \gamma \delta ]}=0. The user references established proofs from textbooks such as Wald, Padmanabhan, and Weinberg, which utilize a coordinate basis where commutation coefficients are zero. The challenge arises when attempting to prove the identity in a noncoordinate basis, where additional terms involving commutation coefficients complicate the proof. The user concludes that the identity should hold in noncoordinate bases, emphasizing the tensorial nature of {R^\alpha}_{[ \beta \gamma \delta ]}.
  • Understanding of Riemann curvature tensor and its properties
  • Familiarity with coordinate and noncoordinate bases in differential geometry
  • Knowledge of commutation coefficients and their role in tensor calculus
  • Proficiency in tensor notation and manipulation
  • Study the proofs of the first Bianchi identity in both coordinate and noncoordinate bases
  • Explore the implications of commutation coefficients in noncoordinate bases
  • Learn about the properties of tensors and their behavior under basis transformations
  • Investigate advanced topics in differential geometry, such as connections and curvature
Mathematicians, physicists, and students specializing in differential geometry, particularly those interested in the properties of curvature tensors and their applications in general relativity.
miracu113
I got trouble to understand the cyclic sum identity (the first Bianchi identity) of the Riemann curvature tensor:
or equivalently,
{R^\alpha}_{\beta \gamma \delta}+{R^\alpha}_{\gamma \delta \beta}+{R^\alpha}_{\delta \beta \gamma}=0.
I can understand the proofs from the most general textbooks, for example:
Wald P.39 (3.2.18), Padmanabhan P.200 (5.41), Weinberg P.141 (6.6.5) and so on.
But I found that all of them do the proof under a coordinate basis, so commutation coefficients are zero, {c_{\mu\nu}}^\alpha=0. In this case, the Riemann tensors are
{R^\alpha}_{\beta \gamma \delta}<br /> =<br /> {\Gamma^\alpha}_{\beta \gamma , \delta}<br /> -{\Gamma^\alpha}_{\beta \gamma , \delta}<br /> +{\Gamma^\alpha}_{\mu \delta}{\Gamma^\alpha}_{\beta \gamma}<br /> -{\Gamma^\alpha}_{\mu \gamma}{\Gamma^\alpha}_{\beta \delta}<br />
and
[\nabla_\gamma, \nabla_\delta]\,v^\alpha<br /> ={R^\alpha}_{\beta \gamma \delta}\,v^\beta
for a vector v=v^\alpha \,e_\alpha. I've checked that we can easily prove the above cyclic sum identity by starting from either of these.
But in a noncoordinate basis case, the Riemann tensors are
{R^\alpha}_{\beta \gamma \delta}<br /> =<br /> {\Gamma^\alpha}_{\beta \gamma , \delta}<br /> -{\Gamma^\alpha}_{\beta \gamma , \delta}<br /> +{\Gamma^\alpha}_{\mu \delta}{\Gamma^\alpha}_{\beta \gamma}<br /> -{\Gamma^\alpha}_{\mu \gamma}{\Gamma^\alpha}_{\beta \delta}<br /> -{\Gamma^\alpha}_{\beta \mu} \,{c_{\delta \gamma}}^\mu<br />
and
([\nabla_\gamma, \nabla_\delta]-{c_{\gamma \delta}}^\mu\nabla_\mu)\,v^\alpha<br /> ={R^\alpha}_{\beta \gamma \delta}\,v^\beta.
I've tried the proof again for a noncoordinate basis and stuck:
3{R^\alpha}_{[ \beta \gamma \delta ]}<br /> =<br /> {c_{\delta \beta}}^\alpha{}_{,\gamma}<br /> +{c_{\beta \gamma}}^\alpha{}_{,\delta}<br /> +{c_{\gamma \delta}}^\alpha{}_{,\beta}<br /> +{c_{\gamma \mu}}^\alpha{c_{\delta \beta}}^\mu<br /> +{c_{\delta \mu}}^\alpha{c_{\beta \gamma}}^\mu<br /> +{c_{\beta \mu}}^\alpha{c_{\gamma \delta}}^\mu<br />
I think the identity will be true in a noncoordinate basis too. But how can I proove or understand it in a noncoordinate basis?
I think all you need is to note that {R^\alpha}_{[ \beta \gamma \delta ]} is a tensor because it's the sum of three tensors, and that if a tensor is zero in one basis it's zero in all.
  • · Replies 24 ·
