Riemann Zeta Function Zeros: Spacing and Convergence
  • Context: Graduate
  • Thread starter Thread starter Diophantus
The discussion revolves around the properties of the Riemann zeta function zeros, particularly focusing on their spacing and convergence of related series. Participants explore theoretical implications, mathematical reasoning, and the connection to the Von Mangoldt explicit formula.
  • One participant proposes a connection between the Riemann hypothesis and the convergence of a series involving the non-trivial zeros of the zeta function, questioning the validity of the assumption regarding the spacing of the zeros.
  • Another participant expresses skepticism about the convergence of the series \sum_{\gamma > 0}\frac{1}{\gamma^2}, suggesting it may diverge based on the asymptotic behavior of Riemann zeros in the critical strip.
  • A different viewpoint suggests that the average density of Riemann zeros does not necessarily imply divergence of the series, emphasizing the importance of how fast the density tends to infinity.
  • Participants discuss the implications of differentiating the Von Mangoldt formula and its relation to sums over frequencies associated with the imaginary parts of the zeros.
  • There is clarification regarding the notation of \gamma, with some participants debating whether it refers to the imaginary parts of the zeros or the zeros themselves.
Participants express differing views on the convergence of the series involving Riemann zeros, with no consensus reached on the validity of the claims regarding their spacing and convergence properties.
Limitations include unresolved assumptions about the behavior of the series and the distribution of Riemann zeros, as well as the dependence on definitions and conventions used in the discussion.
Readers interested in number theory, particularly those studying the Riemann zeta function, its zeros, and related mathematical concepts may find this discussion relevant.
Diophantus
I've just been reading through my number theory lecture notes and I noticed this line of reasoning:
***Assuming the Rieman hypothesis***
\sum_{\gamma > 0}\sin(\gamma \log x) \frac{-(1/2)^2}{\gamma((1/2)^2 + \gamma^2)} = O(1)
by comparisson with \sum_{n \ge 1}\frac{1}{n^2}.
Let me explain the context a little. Importantly the gamma are the non-trivial zeros of the zeta function in the upper half plane. (The goal is to obtain an expression which demonstrates a connection between the Von-Mangolt explicit formula and Fourier series if anyone's interested but that is really not important for my question.)
Now as far as I can see the statement is true by considering absolute convergence etc. but surely this requires also that the spacing of the zeros on the line Re(z) = 1/2 is sufficenty sparse so that the comparison is valid.
There is no mention anywhere else in the course of this being a fact. Is it true?
How much do we know about properties of the distribution? I suppose the above question concerns the existence of a lower bound on the spacing.
It sounds wrong, but I've only looked at small zeroes.
If in V.Mangoldt formula you put x=exp(u) and differentiate respect to 'u' setting \rho _{n} = 1/2+it_{n} you can find an expression for:
\sum_{n} exp(it_{n}) similar to a kind of sum over 'frecuencies' where the 't'-s are just the imaginary part of NOn-trivial roots.
Ok to simplify the situation a little, it has been claimed to me that
is convergent, where, as usual, the gamma are just the imaginary parts of the Riemann zerosin the critical strip.
I think this is false based on the following heuristic arguament:
The number of Riemann zeros in critical strip between 0 and iT is known to be asyptotic to Tlog(T)/2pi. It follows then that the average density becomes unbounded as we go further up the strip, and hence the series must diverge.
If I am correct, how might I go about proving this?
By finding an asymptotic upper bound on the n-th zero, and thus a lower bound on the series. If the lower bound on the series is infinity...
Are you sure that gamma is the imaginary part, and not the actual value of the zero? You said otherwise in your OP.
The average density tending to infinity does not imply the series will diverge. How fast it tends to infinity is important. Here, you only have log(T) times as many zeros up to T as you do integers (ignoring constants and lower order terms), which really isn't that much, and not enough to make this diverge.
Try bounding the tail of the series by looking at
\sum_{T+t \geq\gamma > T}\frac{1}{\gamma^2}
and smacking it around with partial summation and your asymptotic for the number of zeros (really the bound O(Tlog(T)) for the number of zeros will do). Let "t" go to infinity and you should be able to get something that shows the tail tends to 0 as T->infinity, so the original series converges.
For Hurkyl's question about gamma, it doesn't really matter here if it's the imaginary part or the whole zero for the convergence of this series. The real part will be between 0 and 1, while the imaginary part is tending to infinity, so the real part doesn't do much. However, the usual convention is little gamma standing for the imaginary part, so that's likely what they were talking about.
  • · Replies 17 ·
