Right-Hand Rule: Finding Induced Direction in a One Loop Wire on the Page
The discussion centers on the application of the Right-Hand Rule to determine the direction of induced current in a one-loop wire subjected to an increasing magnetic field. When the magnetic field points into the page and increases over time, the induced current flows counterclockwise, opposing the change in magnetic flux. The participants clarify the use of the Right-Hand Rule, emphasizing that the thumb represents the direction of the induced field, while the curling fingers indicate the direction of the induced current. Additionally, the torque on a rectangular wire loop with a clockwise current in a magnetic field is discussed, highlighting the relationship between current direction and magnetic field orientation.
  • Understanding of electromagnetic induction principles
  • Familiarity with the Right-Hand Rule for magnetic fields
  • Knowledge of magnetic flux concepts
  • Basic grasp of torque in magnetic fields
  • Study the concept of magnetic dipole moment
  • Learn about Faraday's Law of Electromagnetic Induction
  • Explore the relationship between torque and magnetic fields in current loops
  • Investigate applications of the Right-Hand Rule in various electromagnetic scenarios
Students of physics, educators teaching electromagnetism, and anyone seeking to understand the principles of induced current and magnetic fields.
Noreturn
1. The problem statement, all variables, and given/known data
A one loop wire is lying on the page with a magnetic field pointing into the page. The magnetic field strength is increasing with time, the induced current direction in the loop is:
Assume magnetic field is pointing into the page and is increasing with time. If a wire loop is laying on the page perpendicular to the magnetic field the induced current will flow clockwise. T/F
Right-Hand Rule
So I know how to use the right-hand rule when I am using the 3 fingers w/ the 3 forces where:
middle: magnetic field
index: velocity
thumb: force field
I get confused when it starts saying it's lying on the page parallel to the right side then gives only one force..I know the other right-hand rule where we can have thumb be the direction of current the curling of fingers is the flow of the force. Then induced would be the opposite direction correct?
Thanks for any help, know it's kinda hard to explain over text.
Since the induced current will be in a direction as to oppose the change of flux, if you point your thumb in the direction of the induced field, your fingers will curl in the direction of the induced current.
In this problem, the field is pointing into the page and the flux through the loop is increasing. The induced field will want to oppose this increase this in flux and so which way do you think you should point your thumb? Which way do your fingers curl when you do this?
So on the second one, we can say it's false because if we point thumb into the page the natural flow is clockwise so induced would be counterclockwise. The first one I know the answer is to the right but do know why.
Yes.
I think you may have miscopied the other question in your initial post. What exactly is the question?
Oh I did, didn't even notice:
A rectangular wire loop is lying on the page with one of its edges parallel to the right side of the page. A clockwise current of 1 A is flowing in the wire loop. A magnetic field lies in the page pointing from left towards right side of the page, the torque on the current loop is a) points to the top of the page, b) to the left, c) to the bottom of the page, or d) into the page
Where the current is parallel to the magnetic field, what do you expect the torque to be (in general)?
How about when it's perpendicular?
Look up "magnetic dipole moment" if you have no idea.
